OT: Inventory Program
I have written a little QBasic Inventory Program which might help keep track
of things on hand.
The "Item' entry is limited to 15 bytes, including spaces, and the "Quantity"
entry is limited to 5 bytes. When searching or changing an entry, the
program will search for the first four to fourteen letters of the item entry.
Quantity can be changed up or down by selecting "Search or Change" from the
menu, then following screen instructions.
If you would have QBasic and would like a copy contact me off-line.
Sid Weaver
W4EKQ
Port Richey, FL
of things on hand.
Sid Weaver
W4EKQ
Port Richey, FL
writes:
> Sid Weaver
> W4EKQ
> Port Richey, FL
Send it on sid.....
