pleaze any one can answer me what is the difference between...
In a message dated 7/3/2003 11:40:29 PM Pacific Daylight Time,
rme90@y... writes:
> plz tell me the difference between pin 4(Vss)and pin 23 (Vss)?
> thx for helping...........Romero
Romero,
The two pins are the same.
rme90@y... writes:
Romero,
> rme90@y... writes:
> Romero,
Well, they are different numbers and on different sides of the chip
so there is some great schematic and layout differences, so although
electronically they are the same, physically, they are different.
and if you have ever had to run a trace over the mountain and thru
the woods, you do appreaciate the difference.
Dave
placed for connection to a serial port, and the other's with the power
circuitry. No technical difference, just placed for convenience I guess...
- Robert
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, July 04, 2003 9:23 AM
Subject: Re: [noparse][[/noparse]basicstamps] pleaze any one can answer me what is the
> rme90@y... writes:
> Romero,
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
is to reduce the amount of noise on the
ground lines.
Digital logic has high-frequency switching
transients. If you have a long single ground
wire, it looks like a (small) inductance.
(An inductor is like a small coil. It maintains
a magnetic field while current is flowing.
When the circuit is broken, the collapse
of the magnetic field makes current continue
to flow. Thus inductance slows the
instantaneous change of current.)
(Even if the 'inductor' is a long straight
wire, there is a little of this magnetic
effect.)
When you have a switching transient, a lot
of current is needed for a very short time.
The inductance of the wire means that there
is a ramp-up time for the current to get to
the chip. While this ramp-up is occurring,
the voltage at the chip drops -- thus giving
you a downwards voltage spike, (called
ground bounce) which in turn
affects how fast the chip can switch.
One way to prevent this is to have multiple
connections to ground. This reduces the
effective length of the ground wire, and
thus reduces the inductance of the connection
to ground.
This also allows 'high-current'
devices to have a different path to ground
than lower current devices, which reduces
the amount of ground-bounce noise coupled
between devices.
--- In basicstamps@yahoogroups.com, "Dave Mucha" <davemucha@j...>
wrote:
> > rme90@y... writes:
> > Romero,
although
> Dave
(no "language lawyer" flames, please...It just struck me as funny at the
time...)
>Message: 15
> Date: Fri, 4 Jul 2003 22:09:18 -0600
> From: "Robert Ussery" <uavscience@f...>
>Subject: Re: pleaze any one can answer me what is the difference
between...
>Yah, they're linked to the same silicone inside, just one's conveniently
>- Robert
The information transmitted is intended only for the person
or entity to which it is addressed and may contain confidential
and/or privileged material. If you are not the intended recipient
of this message you are hereby notified that any use, review,
retransmission, dissemination, distribution, reproduction or any
action taken in reliance upon this message is prohibited. If you
received this in error, please contact the sender and delete the
material from any computer. Any views expressed in this message
are those of the individual sender and may not necessarily reflect
the views of the company.
