Linux, the stamp and the serial port
I have set up my basic stamp to monitor the input from serin ascii
text and based on the input, certain pins go high.
I am using linux as the machine communicating with the stamp. When I
use minicom and type the letter w the device works fine. However when
I try a command like
echo w >> /dev/ttyS0
it does not work.
I want to do this so that i do not have to go into another program
just to get the light to go on. If i can get the above line to work,
then script files will be a cinch.
Anyone have any ideas or leads. I tinkered with the stty util but i
was unsuccessful.
thanks
it does not work.
was unsuccessful.
thanks
You must configure the /dev/ttyS0 port characteristic (baud rate,
handshaking, parity bit, ...) before you can use the serial port and
send the first byte. This is what minicom do before sending the bytes to
serial port.
You also need write permission on /dev/ttyS0
Note that "echo" also add a LF (line feed) at end of line
Maybe you need a customized "echo" program or a small script file?
Bye
> it does not work.
> was unsuccessful.
> thanks
Arnaldo Braun
Consultoria em inform
and it did not work. I am not sure how to set it to no handshake or
no flow control.
The line feed is not a problem. I can reprogram the stamp to expect
the line feed right.
Any ideas?
--- In basicstamps@yahoogroups.com, Arnaldo Braun <abraun@t...> wrote:
> Hi
bytes to
> serial port.
> Bye
When I
when
> > it does not work.
work,
i
> > was unsuccessful.
> > thanks
> Arnaldo Braun
For more information look at
<http://www.easysw.com/~mike/serial/serial.html>
and
<ftp://sunsite.unc.edu:/pub/Linux/docs/HOWTO/Serial-Programming-HOWTO>
If you know Delphi or Kylix (Pascal language) look
<http://www.ararat.cz/synapse/> and download
<http://www.ararat.cz/synapse/files/synaser.zip> it is a free syncronous
serial library to make customized programs.
Bye
nestlerv wrote:
> Ok, but how would i do that, How can i set that? I tried with stty
> no flow control.
> Any ideas?
Arnaldo Braun
Consultoria em Inform
> Hi
> and
HOWTO>
syncronous
> Bye
> > no flow control.
expect
> > Any ideas?
> Arnaldo Braun
stty -F /dev/ttyS0 9600 raw -echo -hupcl
Regards
Adrian
