Latching valve and back EMF spikes
Hi All,
I am wondering how I protect the Stamp from EMF spikes. I can't just put a
diode across the coil in the usual manner, as it would prevent operation in
one direction. Any ideas?
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
Ok, that sounds good. I had kind of hoped to run it directly off two Stamp
pins. The current is slightly higher than the pin rating, but it for 500mS
or so, so I thought I might get away with it. Is there anyway to protect
from EMF in this situation?
Thanks very much,
Jonathan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, July 03, 2003 12:55 PM
Subject: RE: [noparse][[/noparse]basicstamps] Latching valve and back EMF spikes
> The transistors in each leg of the h-bridge have a reverse diode which
> protects it no matter which direction the current is flowing as only two
of
> the transistors are on at any given time.
> Jim
> http://www.geocities.com/jimforkin2003/
Original Message
> From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7dXhte6G8CgqXX5yDQljq2eIaHvWd9FbAaxB9uYZP2XtI18Gczxc6H5ihNmcrK_LkJEvjvESyVJM0qatQSfWcQ]jpeakall@m...[/url
> Sent: Thursday, July 03, 2003 1:41 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Latching valve and back EMF spikes
> Hi All,
in
> Thanks,
> Jonathan
> www.madlabs.info
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
protects it no matter which direction the current is flowing as only two of
Jim
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=r8Tl9HuaZGhUK1Y49O_k937a__M02pCn9tu0fL9ZYpRoglmSJQK_XtBsiEZSnCIKmBMzo93Y2YkzLXg]jpeakall@m...[/url
Hi All,
Jonathan
www.madlabs.info
h-bridge gives you. Check out this web site for a schematic (and board)
which will isolate and protect the stamp and also give you an LED indication
of the status of the various pins from the stamp
Jim
Original Message
From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0-nDf0LA5yNu4mgjejL02Xi9vZ9G_Daz_gl6Xyjod4X_PMSFhY98HLWsuwHbURZhBOdNG2OGqFrJvHFIO4TDYw]jpeakall@m...[/url
Sent: Thursday, July 03, 2003 3:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] Latching valve and back EMF spikes
Jim,
Thanks very much,
Jonathan
Original Message
of
> Jim
Original Message
> Hi All,
in
> Thanks,
> Jonathan
> www.madlabs.info
would block the voltage forward (up to 6 volts)
so it would drive the coil, but then when the
coil shuts off, would limit the voltage
rise to 6 volts as the current collapses.
Just a thought -- perhaps an inept one, though.
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Hi All,
just put a
operation in
> Thanks,
> Jonathan
> www.madlabs.info
You have nerves of steel running Stamp I/O pins over the rated max -- even
for 1/2 second ;-) But I don't think it would work, and here's why...
When you draw anywhere near the max rated current from a Stamp/PICmicro pin,
there is a significant voltage drop across the internal driver transistor.
Let's say you are sourcing 20 or 25 mA from the I/O pin. You won't get
anywhere near 5.0 volts out. I haven't done this with the PIC 16C57 used in
the Stamp, but I have with some of the current PICmicros. My notes are
around here somewhere, but as I recall the voltage was getting down near 2.5
as the max rated current was reached. You would also have a similar
situation on the Stamp I/O pin used on the ground side, but not quite as
extreme. Bottom line: you wouldn't have anywhere near the 5 volts needed
for your solenoid if you attempt to drive it directly from the I/O pins.
You could build a small H-bridge from 6 dirt-cheap transistors if you
wanted. I think there was a link about this in one of the replies you got
last week. Here is another (schematic of the Furby) -- note the two
combinations of three transistors used to drive the motor. You could use
2N3904/2N3906, or any other cheap switching transistors.
http://www.hackfurby.com/schematic.html
Randy
www.glitchbuster.com
Original Message
Sent: Thursday, July 03, 2003 12:15 PM
> Jim,
> Thanks very much,
> Jonathan
Original Message
> From: "Jim Forkin" <jjf@p...>
> of
> > Jim
Original Message
> > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TiWvk97kWYkv3fQrwlMTfF4ig_vjQzZC6dC-nyCD6Ex_Hm03LTaaEptHT4gimlw2WaCglVY6k4q-GNb1piU]jpeakall@m...[/url
> > Hi All,
a
> in
> > Thanks,
> > Jonathan
> > www.madlabs.info
and
and
