Quick Question...
Hi everyone! I'm new to the group, and to the stamp.
I have a quick question. Has anyone done a temperature data logger. With say
256k of EEPROM? Maybe two sensors?
I've been looking at the DS1516 and it's pretty cool but logging for a year
would be really handy. Just set it and forget it [noparse]:)[/noparse]
If anyone has some Websites or info they would like to point me to that would be
great!
Thanks in advance!
Tim
great!
Thanks in advance!
Tim
to sense data (one "local" and one "remote"), set up as a voltage divider
with a 1K resistor (the thermistors are 1k at 25C). I ave a lookup table
stored in the EEPROM of the stamp to convert the voltage I get via an ADC to
temperature, also interfaced to an RTC, then save this data to an EEPROM
(right now, I use an I2C EEPROM with only 2048KB to log the data, but
replacing with more memory would be simple. I have yet to develop the
software for the PC to download the data, but everything else works. I have
an LED display to display time, and the temperatures as well. The software
can log temps in increments of 1 minutes to 60 minutes....
While this seems uninteresting to my friends, It does work, and I built it.
Very satisfying!
Steve
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, July 02, 2003 10:42 PM
Subject: [noparse][[/noparse]basicstamps] Quick Question...
say 256k of EEPROM? Maybe two sensors?
year would be really handy. Just set it and forget it [noparse]:)[/noparse]
would be great!
> Thanks in advance!
> Tim
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
one of the reasons I joined the group, so I can chat with people who understand
what I'm saying!
Sounds like your almost done, getting the data back into the PC might not be so
hard. They have DAQ software that can store your Debug output for ya.
My project may end up in my house. Sensor1 outside, #2 in the attic, #3 near
the air return, #4 on a vent and maybe one on the Water heater. With a year of
data logging.....is that to much to ask? [noparse]:)[/noparse] Maybe I'll start out small with
just one or two sensors [noparse]:)[/noparse]
And I agree with you, building it yourself is far more satisfying. Cheaper
too!!
Tim
>>> zman97211@y... 07/02/03 04:06PM >>>
I'm currently working on my first "real" BS2 project. I use two thermistors
Very satisfying!
Steve
Original Message
would be great!
> Thanks in advance!
> Tim
from the same email address that you subscribed. Text in the Subject and Body
life. It has an I2C interface which is pretty easy to use - lots of I2C
examples around.
One gotcha for these memories is that you have to watch auto-incrementing
write addresses. First time I used one it seemed to work great when doing
short tests but when I left it running and went away, the data would be
filled with seemingly spurious values (my line graph had regular jumps in
it).
Took me a while but I noticed it was happening every 128th byte (or was it
256th?). I was writing 13 bytes every log event and taking advantage of the
auto-incrementing adresses. The address counter doesn't appear to be able to
roll over in the middle of a write. So if the write starts at the 125th
byte, the 126th and 127th would be put in the proper place but the 128th
would end up nowhere near where I wanted.
My solution was to change my log format and save 16 bytes at a time which
divided evenly and never invoked the roll-over problem.
The other way around it is to supply the address for each byte written.
Slower and a bit more work but safe.
Oh yes, one more thing that I didn't find readily apparent when using I2C -
Writes are pretty straight forward as shown in this pseudo-code:
I2CStart /*Initiate conversation*/
I2CWriteByte EEpromWriteAddress /* Tell it which chip and which mode *
I2CAddressHighByte /* Address to write to */
I2CAddressLowByte /*Address to write to */
I2CWriteByte var1, Ack /* Write a byte - Ack if its not the last byte */
I2CWriteByte var2, Ack /* Write a byte - Ack if its not the last byte */
I2CWriteByte var3, Nack /* Last byte don't Ack */
I2CStop /*End conversation */
Reads are a bit different. You have to do a write conversation in order to
send the starting address then start another conversation using a read
conversation - without issuing a stop.
I2CStart /* Start again, don't use Stop! */
I2CWriteByte EEpromReadAddress /* Tell it which chip and which mode *
I2CReadByte var1, Ack /* Write a byte - Ack if its not the last byte */
I2CReadByte var2, Ack /* Write a byte - Ack if its not the last byte */
I2CReadByte var3, Nack /* Last byte don't Ack */
Original Message
Sent: Wednesday, July 02, 2003 2:23 PM
Subject: Re: [noparse][[/noparse]basicstamps] Quick Question...
> I know the feeling. My friends and wife are completely uninterested.
That's one of the reasons I joined the group, so I can chat with people who
understand what I'm saying!
be so hard. They have DAQ software that can store your Debug output for ya.
near the air return, #4 on a vent and maybe one on the Water heater. With a
year of data logging.....is that to much to ask? [noparse]:)[/noparse] Maybe I'll start out
small with just one or two sensors [noparse]:)[/noparse]
Cheaper too!!
> Thanks,
> Tim
thermistors
to
have
it.
> Very satisfying!
> Steve
Original Message
> From: "Tim Hart" <tim.hart@h...>
With
> would be great!
> > Thanks in advance!
> > Tim
and
and stored the results in a 24c02.
Only 256bytes of EEPROM, but the principle is basically the
same for your needs?
Take a look at it here, and see if it gives you any ideas:
http://www.lennard.net.nz/lennardelectronics/electronics/ad.html
#datalogger2
cheers,
Ben,
Windy Wellington,
New Zealand.
--- In basicstamps@yahoogroups.com, "Tim Hart"
logger. With say 256k of EEPROM? Maybe two sensors?
for a year would be really handy. Just set it and forget it [noparse]:)[/noparse]
me to that would be great!
> Thanks in advance!
> Tim
