It can be done, but the buffer is only eight bytes and you'll need some
handshaking. There is a master-slave example in the documentation; it
can be modified to send text.
Can the IR buddy send and receive simple text messages from one stamp
user to another across the room?
To UNSUBSCRIBE, just send mail to: basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Yes, the IR buddy can send text messages
using IR across a room -- at 300 bits/sec.
The IR-Buddy uses the Phillips 'RC-5' remote
control handset standard. This allows your
remote control to send key-presses to your
TV or Stereo.
So, the IR-buddy sends a 'key-press' and
'mode' -- two 8-bit values -- for each key
pressed on a remote. I havn't done a lab
yet to find out exactly how fast you can
send multiple key presses, and have them
recognized. Note the 'key-press' identifies
the key you pressed, and the 'mode'
identifies the device (TV, CD Player,
Stereo) you are trying to control.
The IR-buddy also receives these 'key-presses'
and returns up to 8 bytes ( 4 key-presses,
since each one is 2 bytes) to the caller.
It uses the 'SERIN/SEROUT' protocol.
You are allowed 0..63 for 'command' code
(the key) and 0..31 for the 'system' code
(the device). If you limit yourself to
uppercase ascii, and manipulate the values
a little, you can fit them into the 64
values of the 'command' code, and use
the 'system' code to 'select' a particular
device (or robot).
The IRBuddy also can transmit and receive
arbitrary 8-byte 'packets',
each value 0..255 -- this would be the
best mode for text.
--- In basicstamps@yahoogroups.com, "pstrittmatter"
stamp
Thank you, that was very helpful. Could the packet transmit recorded
audio (voice) for playback at the other stamp? If this is not the
most economical way to send audio data at short range via IR, what
would you suggest? Also, are there better alternatives using RF?
Pat
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
> TV or Stereo.
> device (or robot).
> best mode for text.
> It does take 25 mSec per byte (320 bits/sec).
> Go to the downloads section of Parallax, and
> get the IRBuddy docs.
> http://www.parallax.com/Downloads/Documentation/IR_Buddy_Demo_Kit.pdf
> stamp
Wow, audio data.
To make sense of audio, you need to play it back
at up to 2,000 HZ. This means you need to sample
it at 4,000 HZ. 300 bits/sec means you can only
do 'packets' of sound. The BS2 doesn't have that
much memory on it to store these packets.
So, to do this, you'll need more external memory,
or play it back real-time at 150 HZ (which won't
be legible).
They do make longer range, higher baud rate RF
hardware (approx $100 for a transciever) which
may make this approach more practical. See the
Parallax RF link, or other posts discussing
cheaper RF approaches.
recorded
> Thanks
> Pat
> > TV or Stereo.
> > device (or robot).
> > best mode for text.
> > stamp
-- Jon Williams
-- Parallax
Original Message
From: pstrittmatter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0pw5Jehg1UFX0KpZyOgbMu6T5YEWeFhE5En1fULu3tZ7_JhC7sT3aNVqdZpvm4_nD7AUgoqV4tkrYIifq9yYaRkI]pstrittmatter@y...[/url
Sent: Wednesday, June 25, 2003 11:51 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] IR test messaging
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
TV or Stereo.
device (or robot).
best mode for text.
stamp
Pat
> TV or Stereo.
> device (or robot).
> best mode for text.
> stamp
be legible).
recorded
> Thanks
> Pat
> > TV or Stereo.
> > device (or robot).
> > best mode for text.
> > stamp
