serial control of robot from computer console....
How can I program the stamp to take realtime input from a computer
connected to it via the serial cable to controll a robot? (ofcourse
the robot will not be going far from the computer)
thanks
thanks
In principle it could work something like the program fragment below.
Of course this example is just an outline which has yet to be
enhanced upon your needs. One important aspect is, that you have to
signal to the computer when the stamp is ready to receive (as the
stamp has no input buffer).
Regards
Adrian
'{$STAMP BS2}
Rx con 16 'use the programming port
Tx con 16 ' dito
ACK con $ff 'or whatever
BAUD con 16468 'BS2:9600,8,N,1
wdata var word
cmd var wdata.NIB3
loop:
'wait for and receive data from the computer.
'of course this can be more than just a word.
serin Rx,BAUD,[noparse][[/noparse]wdata]
'execute whatever code, according to 'wdata'
'e.g. using the high nibble if wdata as a command
branch cmd,[noparse][[/noparse]c1,c2,c3,c4]
goto nop
c1:
'code from cmd 1
c2:
'code from cmd 2
c3:
'code from cmd 3
c4:
'code from cmd 4
nop:
'send acknowledgement to the computer to
'signal that the stamp is ready to receive again.
serout Tx,BAUD,[noparse][[/noparse]ACK]
goto loop:
(serial in) and look for an ascii character. When it grabs the character,
do an if/then comparison and jump to a subroutine to do the function
associated with the character and then return to the serial input routine.
I've done this several times for controlling spray heads and air cylinders
and motors. I've developed a board to do this. Check out this page;
Jim
http://www.geocities.com/jimforkin2003/
Original Message
From: nestlerv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cUYSJIiiEgaf0JM2TsXHoOvnGkiV7Rx-f6r9AOJ9qhYpY0m8lb9xoH7Y5hJlDnKErlNIAbLIzvfrAwY]nestlerv@a...[/url
Sent: Wednesday, June 25, 2003 12:56 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] serial control of robot from computer console....
thanks
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I want to use the serial port of the computer the same way I use the
serial cable to program the bs2sx.
Are the serin commands the same as coding rx con 16, tx con 16?
Your board looks interesting. I actually have a remote control car in
mind that I picked up from radio shack. I want to remove the controls
it has, put the basic stamp in, connect a computer to the stamp and
then have the computer control the car.
Do you think your board could do that? I have the schematics for the
car if that would help.
--- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
> It's really pretty simple, just program the stamp to look at an
input
character,
routine.
cylinders
> Jim
Original Message
> From: nestlerv [noparse][[/noparse]mailto:nestlerv@a...]
console....
> thanks
Subject and
it refers to the stamp's SIN contact, when used with serout it refers
to the stamp's SOUT contact.
This way you can use the same cable and setup for your own control as
for programming the stamp (I am always doing this). Don't forget that
the stamp's programming port is fixed to 9600/8/N/1.
Regards
Adrian
the port at any supported baud rate for your own applications. Just
keep in mind that the hardware design echoes any character sent to it
from the outside -- you'll need to filter this externally.
-- Jon Williams
-- Parallax
Original Message
From: Adrian Schneider [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_WS-9KCr104qZxhYxsoNBGUPKJ4aOZRYkJWqe3LrN6DzKQXes_bFgyj_SU2iiCVIGuaZYKck8S-EDib4KUoWlVoBNhDGHbU]adrian.schneider@t...[/url
Sent: Thursday, June 26, 2003 1:44 AM
Subject: [noparse][[/noparse]basicstamps] Re: serial control of robot from computer
console....
Port number 16 ist somewhat different than others: if used with serin
Regards
Adrian
and Body of the message will be ignored.
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
you MUST use 'inverted' baud mode, and
you refer to it as:
SERIN 16, serbaud, [noparse][[/noparse]Data]
SEROUT 16, serbaud, [noparse][[/noparse]Data2]
where 'serbaud' refers to the INVERTED mode
baudrate selector.
--- In basicstamps@yahoogroups.com, "nestlerv" <nestlerv@a...> wrote:
> First, I am fairly new at this, so pardon my ignorance if it
surfaces.
the
in
controls
the
> input
> character,
function
> routine.
> cylinders
page;
> > Jim
Original Message
> console....
(ofcourse
> > thanks
> Subject and
