PULSIN and RCTIME
Hello,
I'm TRYING to get a Polaroid sonar unit pulled fron a Polarois Sonar
OneStep camera (the one with the 45 degree connector)to work. I've
search the web and found the mod for the board and made them. My
problem is with the program.
'{$STAMP BS2}
'{$PBASIC 2.0}
'Polaroid SONAR programs for the Parallax Stamp II
'Copywrite Dennis Clark 9/2000, more or less.
DEBUG CLS
'SPKR con 1
'Polaroid SONAR one-step program
PWR con 13
XLOG con 14
MFLOG con 15
time var word
feet var word
inches var word
start:
'freqout SPKR,200,2000
pause 2000
onestep:
'Polaroid One-Step routine
input XLOG
input MFLOG
high PWR 'turn power off
DEBUG "power off", cr
srdng:
low PWR 'turn power on
DEBUG "power on ",cr
pulsin XLOG,0,time 'wait for XLOG (pulse started)
rctime MFLOG,1,time 'wait for MFLOG (ping returned)
'DEBUG "time is", time, cr
time = time*2 'actually 2us per count
inches = time/148 '1.78ms per foot transit time
inches=inches+2 'occasional hack needed.
DEBUG "power off",cr
DEBUG dec time,"uS ",dec inches," in",cr, cr
pause 1000 'seems to take a while to recharge...
goto srdng
end
My problem is with these two commands/lines:
I understand what they do and how they work, just NOT how you can use
them in the maner. Not with the same variable, 'time', in both.
Should the 'variable' be the same in both instructions?
Here is the link to the whole thing:
http://www.seattlerobotics.org/encoder/200010/dlcsonar.html
Duane
'{$STAMP BS2}
'{$PBASIC 2.0}
DEBUG CLS
'SPKR con 1
PWR con 13
XLOG con 14
MFLOG con 15
time var word
feet var word
inches var word
start:
pause 2000
onestep:
input XLOG
input MFLOG
srdng:
goto srdng
end
Duane
The code looks correct to me, However I'm no expert.
The time variable in the pulsin command is not used, it's just a way of
detecting when the sonar unit has sent its pulse train. The pulsin requires
a variable to store its data and so I guess to save valuable RAM the same
one was re used.
The useful one is the rctime command that also sets the time variable, but
this time to something meaningfull.
I hope I'm right and I hope this helps.
Cheers
Rohan
Original Message
From: mtn_biker37 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_S9ILTs0RNxtg-UT68_FBHs9YFqTArhCu1u3NHf1ByZyX5QlFMoVcFIf2eAkGvm39h0YqS4njyuVcZUJZrc]mtn_biker37@y...[/url
Sent: Sunday, 15 June 2003 9:20 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] PULSIN and RCTIME
Hello,
'{$STAMP BS2}
'{$PBASIC 2.0}
DEBUG CLS
'SPKR con 1
PWR con 13
XLOG con 14
MFLOG con 15
time var word
feet var word
inches var word
start:
pause 2000
onestep:
input XLOG
input MFLOG
srdng:
goto srdng
end
Duane
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
The program is really using "time" as a dummy variable in the first
statement, then the real business is done by the rctime.
When the power is turned on, there is a delay and then the ping is
sent out. The pulsin command immediately detects the outgoing ping
by going low and high. The actual time value (the duration of the
ping) does not matter. It just gets things started. The ping is on
its way. Now the rctime command gets started. When the echo ping
finally returns, MFLOG goes low and that is the value of time of
travel for the ping.
-- Tracy
be on the hardware side.
Duane
>Duane
An oscilloscope is indispensable for this kind of problem!
Ultrasound can take some really weird bounces, and it is possible to
see what is going on with the 'scope.
to just suck it up, spend the $35, and get one of the SR04 units.
All is not lost, yet, though.
D
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> >Gotcha! Thanks guys! The program doesn't seem to be working.
Must
> >Duane
to
