unknown 2.4 Second negative pulse
Hello,
I have a BS2. If I set an I/O pin high (like 'high 8')and then end
the prgoram, I notice on my scope that the I/O pin toggles from high
to low every 2.4 seconds. The duration of the negative pulse is
18.44mS. It will do this on every line I set high. Anyone
know/guess why?
Duane
know/guess why?
Duane
mtn_biker37@y... writes:
> Hello,
> know/guess why?
> Thanks,
> Duane
I think somebody posted this before, are you using the sleep command? I thing
the watchdog timer might me waking up the stamp at your interval. You will
probably get a definate answer on this from some stamper other than me who
knows the stam really well.
> know/guess why?
When the program is done and the BS has nothing else to do, it
automatically enters in sleep mode, even if you didn't include that
instruction in your code.
Please look at the SLEEP instruction on the BASIC Stamp Manual for an
explanation of this interruption.
The manual will provide a couple of ideas to solve this but keeping the
low power mode.
Another simple solution is keeping the BS busy (and awake), when you
finish the program:
Do_Nothing:
GOTO Do_Nothing
This will prevent the BS to enter in SLEEP mode, and is not a convenient
solution for battery powered applications.
Saludos,
Aristides Alvarez
International Education Program Developer
aalvarez@p...
Parallax, Inc. www.parallax.com
Rocklin, California
USA
NAP, POLLWAIT (BS2P), or if a program simply ends. The watchdog
timer wakes the Stamp up every 2.3 seconds and all the pins
configured as outputs become inputs for about ~18 milliseconds on the
BS2. If you put a pullup resistor on that pin that was set HIGH,
then you won't see the hiccup, that is, unless the pin is driving
something like and LED. If the hiccup is bad for your system, then
end the program with STOP instead of END. STOP keeps the clock
running. Or make a program loop at the end. Or use a pullup
resistor, or pullup resistor and buffer.
-- Tracy
>Hello,
>know/guess why?
>Thanks,
>Duane
tonight when I get home. Thanks for the help.
Duane
--- In basicstamps@yahoogroups.com, "Aristides Alvarez"
<aalvarez@p...> wrote:
> Hello Duane.
end
high
> > know/guess why?
an
the
> low power mode.
> finish the program:
> Do_Nothing:
> GOTO Do_Nothing
convenient
> Saludos,
> Aristides Alvarez
> aalvarez@p...
> Rocklin, California
> USA
or an infinite loop, and you won't see this.
However, the BS2 will remain in 'high-power'
mode, such as it is.
End your program with 'END', and you will
see this, but the BS2 will use less power.
--- In basicstamps@yahoogroups.com, "mtn_biker37" <mtn_biker37@y...>
wrote:
> Hello,
high
> know/guess why?
> Thanks,
> Duane
Duane
> Hello Duane.
end
high
> > know/guess why?
an
the
> low power mode.
> finish the program:
> Do_Nothing:
> GOTO Do_Nothing
convenient
> Saludos,
> Aristides Alvarez
> aalvarez@p...
> Rocklin, California
> USA
