Very small pump or equivilent for caustic chemicals
Thanks to invaluable assistance from Tracy Allen and others on this list, I
have successfully made a full fledged prototype of a pool chemistry controll
replete with 320x200 graphics LCD, trend log graphing (4000 sample history),
serial output, pushbuttons, the works. Its based around the AVR Mega32 now
(needed the memory and I/O) but the stamp and this list is what taught me
the majority of what I needed to learn. I'm just working on getting it off
the breadboard and onto a PCB at the moment.
As a stepping stone, I'm going back to an earlier design (no logging, no
clocks, just displayed numbers at a 4 line text LCD) as a tool for teaching
people how these controllers work. My BS2 will hopefully provide the brains
for it.
Anyway, I plan on using a 5 gallon bucket as to represent a swimming pool
and I'm looking for ideas on how to feed in sodium hypochlorite and muratic
acid. The amounts added will be very small and the solutions quite dilute. 1
oz should take between 5-10 minutes to add and the feed rate needs to be
variable. I need to simulate metering pumps (as used in real swimming pools)
to show the affects of mismatched pump speeds etc.
I've no experience with feeding these miniscule quantities other than using
an eyedropper... Any ideas? My only (half formed) thoughts so far is some
sort of miniature solenoid and gravity feed through a small plastic tube, or
a small pump (like the Earth measurements kit one) and using short pulses
spaced far apart.
Merci!
Meridian 59 is back! Sacred Haven - server 200
www.skotos.net
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, June 10, 2003 7:13 PM
Subject: [noparse][[/noparse]basicstamps] Play with DUALSHOCK 2
> For those interested in playing with the BS2P and the Sony
> DUALSHOCK 2 Controller, I created a small game.
> Please contact me and will send you a copy.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
for it.
spaced far apart.
Merci!
www.skotos.net
Original Message
single-stroke air pump forcing the chemicals out of a sealed container? Or
one of the roller pumps like they use on medical stuff?
Original Message
I
controll
history),
teaching
brains
> for it.
muratic
1
pools)
using
> spaced far apart.
I built a small project that required flows similar to yours. Your may
be slightly lower than mine, but the solution should be the same.
Check out:
http://www.clippard.com/
They have some great miniature solenoids, they advertise for use with
air, but water can go through them also (but I doubt acid).
Consider putting your liquid in a sealed container (I used 4" PVC pipe
with a 4" caps glued on) and use the solenoid to allow air to enter the
container, allowing liquid to come out. You may be able to create a
small enough orifice to reduce your flows, or turn the solenoid on and
off intermittently.
I purchased mine from www.McMaster.com but there are other resellers out
there too.
I also got tiny fittings that fit the solenoid from McMaster, they were
barb style hose connectors, and I put a small zip tie on the tubing to
keep it in place.
Let me know if you need part numbers, I'll look them up for you at home.
Hope it helps,
-John
Original Message
From: Pat M [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E1b0_tmJGBIFWE9uSWgSmYa1dxSMYrh44_qTH3kC_aEWohfhi_C8yEe3WAgSVqTFj56G4YKB]pmeloy@s...[/url
Sent: Tuesday, June 10, 2003 10:14 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Very small pump or equivilent for caustic
chemicals
list, I
controll
history),
now
me
off
teaching
brains
for it.
pool
muratic
dilute. 1
pools)
using
some
tube, or
pulses
spaced far apart.
Merci!
www.skotos.net
Original Message
and
and Body of the message will be ignored.
peristalic pump. the tubing is the only thing connected to the
chemicals and the pump is never near the stuff.
the tubing gets squished and pushes out the fluid, one 'unit' at a
time, and the squshed tubing regains it's shape and refils itself on
each pump cycle. each pump revolution is one unit of chemicals.
repeat to get the total quantiy you need.
not hard to build and not hard to find, e-bay " Peristaltic Pump "
and there are some great ones available.
I remeber having one on the dishwasher at the restauranut I worked at
as a kid for diswashing fluid.
McMaster has them for retail prices so they are a common device.
An alternative home brew would be to use an IV (think M.A.S.H.) with
the chemical in the air, and a solenoid on the tubing. NOT good for
true metering.
yet another idea is a syringe. squeeze the tubing and it shuts off,
unsqueeze and you get flow. a trio of solenoids could run in
sequence.
close ouput tubing
open inlet tubing
withdraw the syringe and it will fill.
close inlet tubing
open outlet tubing
push on syringe to push stuff into bucket.
repeat
Dave
paristalic pumps anywhere. Say one for $8,500.00 but I get the feeling thats
not the one you're talking about [noparse]:D[/noparse]
McMaster as in auto-parts place? I was searching there too and no paristalic
hits.
www.skotos.net
Original Message
Sent: Wednesday, June 11, 2003 7:47 PM
Subject: [noparse][[/noparse]basicstamps] Re: Very small pump or equivilent for caustic
chemicals
> forget any type of valve or windshield pump. go directly to a
> true metering.
> sequence.
> close ouput tubing
> open inlet tubing
> close inlet tubing
> open outlet tubing
> repeat
> Dave
That would be McMaster-Carr at http://www.mcmaster.com/, where you can get
practically anything from motors and gears to raw titanium.
Mike Sokol
mikes@m...
www.ModernRecording.com
"Yes, we're mum and dad - and good and bad -
and everyone's happy to be here.
Genesis-
Original Message
Sent: Thursday, June 12, 2003 8:07 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Very small pump or equivilent for caustic
chemicals
> I've been searching ebay and google. Can't actually find any small
thats
paristalic
> hits.
> www.skotos.net
Original Message
> From: "Dave Mucha" <davemucha@j...>
> chemicals
> > true metering.
> > sequence.
> > close ouput tubing
> > open inlet tubing
> > close inlet tubing
> > open outlet tubing
> > repeat
> > Dave
and
feeling thats
FlexiFlo III Digital Peristaltic Pump - Item # 2536966098 $49.00
Clinitec 2200 enteral peristaltic pump - 2536966852 $49.00
Peristaltic Pump - 2537187907 $25.00
LKB ReCyChrom PERISTALTIC PUMP TYPE 4912A -2537700420 $19.00
Rainin Rabbit-Plus Peristaltic Pump - 2537157965 - $9.95
This is what is currently on e-bay under p-E-ristal-T-ic pumps.
they are pretty large, but you can get smaller ones from different
places like McMaster, but new cost big $$.
If you are good at mechanical stuff, you can make one from a stepper
motor and get good control, or even a DC motor and just time a pulse
to get one-half rev or one cycle of pump per pulse.
Dave
Dave
paristalic
> hits.
> www.skotos.net
Original Message
> chemicals
on
Pump "
worked at
with
for
> > true metering.
off,
> > sequence.
> > close ouput tubing
> > open inlet tubing
> > close inlet tubing
> > open outlet tubing
> > repeat
> > Dave
Subject and
I have been following the responces to your question on what type
of pump to use for metering in the chemicals to a pool control
system. I would have to agree that the peristaltic pump would be the
best option for you. If it is possible I would recommend getting one
with a stepper motor rather than just a straight DC motor with speed
control. I have worked for a number of years in the medical device
industry and there are a number of instruments that use this exact
technology. You may be able to find some of the parts you are
looking for at an industrial liquidation store around you.
I have been wanting to write and ask what type of sensors are you
using in your system. We put in a pool last year and I have been
trying to figure out how to build a monitoring system so my cholorine
and pH don't get out of control. Your system sounds like exactly
what I have been looking for. Any information you could share would
be greatly appreciated.
Eric Warner
Warner Consulting
eric@w...
are too large for this application. I am going to pick up two of them later
on for my own pool - they seem better suited than the LMI reciprocating
pumps we use in the commercial setting (and cheaper believe it or not!).
Right now though I'm trying to feed a 5 gallon pail with a system that I can
lug around with me from facility to facility around the city.
Sensors are the easy part, though not cheap. I'll be using Acu-trol sensors
since they're available locally and aren't horrendously expensive - last I
saw they were about $250 CDN. There are knock-offs of these are around $170
as well but I just had one die at one pool after just a few years so I'm not
sure I trust them. (acu-sense I think the brand name was - close but not
actually from acu-trol). Acu-trol says to replace the sensors every three
years but I've had several in service for close to seven years and they
still work perfectly.
Just look up swimming pool dealers in your neighborhood - they'll have
sensors in stock.
As for the circuits - ORP sensors are easy - just hook them directly to an
ADC and away you go. Its the pH sensors that are tough - the output current
is in femto-amps so you have to run the signal through a couple of op-amps
for conditioning before the ADC.
Check out Tracy Allen's site for a pH sensor schematic
http://www.emesys.com/OL2ph.htm then have a boo at my site for where I've
gone with it http://members.shaw.ca/pmeloy/
www.skotos.net
Original Message
Sent: Sunday, June 15, 2003 10:40 PM
chemicals
> Pat -
> Thanks,
> Eric Warner
> Warner Consulting
> eric@w...
