PIC, AVR, or BS? — Parallax Forums
PIC, AVR, or BS?
ArchiverArchiver Posts: 46,084
edited 2003-06-11 03:53 in General Discussion
Hi,
I'm interested in building a 1st project and am looking for the
appropriate platform. I don't want to spend megabucks on compilers,
programmers etc. In all, I would be willing to shell out about $75 from
start to finish.
Requirements:
4-6 LED outputs
4-6 switch inputs
4-5 A/D inputs (is 4 the magic # here?)
1 Piezo speaker output
I could do it in assy. but would prefer Basic (or C). If I go with one
of the Basic-supported devices, then how does the capacity of the
device relate to lines of Basic code? Does a 100 line Basic program
compile into 1.5k of used up memory in my device? Lots of gray areas
here.
I've been told that a PIC (16F876) would be the perfect device given
the I/O I'm looking for. I start looking closer at BASIC STAMPs and
find that an AVR might be best. Could someone give me a short
description of the differences between PICs, AVRs, and BSs? I've only
seen A/D I/O on the PICs, not on the AVRs or BSs. I'd expect them all
to have A/D inputs.
Thanks in advance for any advice you could provide.
Rance (trying not to talk out the side of my head)
  • ArchiverArchiver Posts: 46,084
    edited 2003-06-09 02:23
    Hi
    I'm also just starting out with micro controllers.
    What I've found is that the pics require very
    expensive interpreter software. The AVR has
    inexpensive interpreter but all models are not readily
    available in my area. What both lack is what the stamp
    has and that is a huge amount of designs already
    worked through and fantastic support online. If you
    read other news groups you will find that the answers
    that are offered as help are like a wiener feeding
    another wiener kraft dinner. There may be a lot of
    bulk but it is mainly inert and lacking of substance.
    The stamp costs more initially but thats where it
    ends. All documetation is shared and there are a lot
    of interface boards available right here. Follow this
    and other groups for a while and see what I mean.
    Regards
    --- Rance/Pat <rupps@t...> wrote:
    > Hi,
    > looking for the
    > out about $75 from
    > start to finish.
    > Requirements:
    > 4-6 LED outputs
    > 4-6 switch inputs
    > capacity of the
    > line Basic program
    > Lots of gray areas
    > here.
    > BASIC STAMPs and
    > me a short
    > and BSs? I've only
    > I'd expect them all
    > to have A/D inputs.
    > head)
    > To UNSUBSCRIBE, just send mail to:
    > from the same email address that you subscribed.
    > Text in the Subject and Body of the message will be
    > ignored.
    > Your use of Yahoo! Groups is subject to
    > http://docs.yahoo.com/info/terms/
    __________________________________
    Do you Yahoo!?
    Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
    http://calendar.yahoo.com
    edited 2003-06-09 03:10
    Rance,
    Here is my take on it, your mileage may vary.
    Stamps are great for getting into microcontrollers. They are rock solid,
    easy to use and program, and take a lot of abuse. As well, Parallax's
    support is top notch, and this forum is great resource as well. The Stamp
    can be easily programmed in circuit. This is a big plus.
    PICs are very cool. They have more built in features like ADCs. They are
    faster. They are also quirky, require MUCH more time poring through
    documentation, and many more pitfalls await the beginner. For example, I
    didn't know that on some PICs, that the chip comes with an individual
    oscillator calibration. If you program the chip without writing down the
    calibration, and marking the chip, you have to figure out how to manually
    recalibrate. And then they don't seem to work quite as well. Ugh! Guess why
    I know that ;-)
    The better BASIC compliers are expensive, and you have to make or buy a
    programmer. Some PICS can be programmed in-circuit, but it is a PITA. They
    are also more prone to mysterious problems. Never order just one PIC when
    starting a project, get a few.
    I use both PICs and Stamps. It depends on what I am doing. Firstly, I
    develop most of my more complex projects on a Stamp. Then I may migrate the
    project over to a PIC. Smaller projects, like a hot tub controller I made
    recently, I used a PIC from the start. It's a very simple job, and I don't
    want to waste an expensive Stamp on it. One thing I wish Parallax would do
    is come out with a smaller micro, like the PIC12F675. 8 pin dip, can run at
    20mHz, has 4 channels of ADC. Perfect for a hut tub controller and all sorts
    of small jobs, and dirt cheap.
    On the other hand, I am working on a hydrogen fuel cell powered robot with
    some high school students. I wouldn't *think* of using a PIC for this. The
    time consumed teaching students how to use PICs just isn't worth it, and
    then there are the support and in-circuit programming benefits too.
    As to AVRs, I just got my hands on a development board and programmer. I'll
    know more soon ;-)
    So, I would say that if this is your first micro, you can't beat a Stamp.
    Jonathan
    www.madlabs.info
    Original Message
    To: <basicstamps@yahoogroups.com>
    Sent: Sunday, June 08, 2003 5:09 PM
    Subject: [noparse][[/noparse]basicstamps] PIC, AVR, or BS?
    > Hi,
    > start to finish.
    > Requirements:
    > 4-6 LED outputs
    > 4-6 switch inputs
    > here.
    > to have A/D inputs.
    > from the same email address that you subscribed. Text in the Subject and
    > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-06-09 04:52
    As for AVRs, the 2313 is pretty cheap, has similar features to the
    pci16F84, more memory and a built in UART. Best of all, MCS makes BASCOM,
    which is BASIC for AVRs. It's real easy to use and FREE - the demo version
    will program the 2313 with no problem. It also has a downloader/programmer
    that will program from the BASCOM IDE. The schematic for the programmer is
    in the HELP file. It only needs a few resistors and a DB25 cable. It's a
    real easy alternative.
    chris in napa
    Original Message
    Sent: Sunday, June 08, 2003 7:10 PM
    Subject: Re: [noparse][[/noparse]basicstamps] PIC, AVR, or BS?
    > Rance,
    why
    > I know that ;-)
    the
    at
    sorts
    I'll
    > know more soon ;-)
    > Jonathan
    > www.madlabs.info
    Original Message
    > From: "Rance/Pat " <rupps@t...>
    > > Hi,
    > > start to finish.
    > > Requirements:
    > > 4-6 LED outputs
    > > 4-6 switch inputs
    > > here.
    > > to have A/D inputs.
    and
    edited 2003-06-09 12:07
    I recommend starting with Basic Stamp 2. I did, and I know I made
    the right decision.
    Later you may want to migrate to a PIC if you need interrupt or
    internal timer.
    But BS2 is the perfect place to begin because of the support and
    information that is freely available.
    --- In basicstamps@yahoogroups.com, "Rance/Pat " <rupps@t...> wrote:
    > Hi,
    from
    > start to finish.
    > Requirements:
    > 4-6 LED outputs
    > 4-6 switch inputs
    one
    areas
    > here.
    given
    only
    all
    > to have A/D inputs.
    edited 2003-06-09 13:48
    check out this web site for a simple stamp platform.
    jim
    http://www.geocities.com/jimforkin2003/
    Original Message
    From: Rance/Pat [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7T_hpbbZv1jJB9-Vo-4r_S7nUeQNwMtlDWEaN4FNJgeuCUbd2XNfGORfwiVQZKwxJc3m9M4jWDUI05_e]rupps@t...[/url
    Sent: Sunday, June 08, 2003 8:10 PM
    To: basicstamps@yahoogroups.com
    Hi,
    start to finish.
    Requirements:
    4-6 LED outputs
    4-6 switch inputs
    here.
    to have A/D inputs.
    edited 2003-06-09 14:02
    In a message dated 6/9/2003 4:08:57 AM Pacific Daylight Time,
    basicstampede@y... writes:
    > the right decision.
    > internal timer.
    All very true!!!!
    I now use AVRs exclusively but I wouldn't recommend anything other than a
    stamp for starting out on. AVRs are excellent but had I started with them, I
    probably would have given up trying in the first month. There are a lot of
    conceptual hurdles that are fairly easy to get over using the stamp and
    Parallax's un-rivaled support. I used the Earth Measurements kit with a
    board of education and BS2 to get started. It was pricey but I'm glad I
    spent the bux.
    You can do without the board of education and use a breadboard instead. If I
    had it to do all over again, I probably wouldn't have purchased the BOE.
    There are schematics around for hooking up power and the programming/serial
    cable.
    Stamps don't have ADC built in but the Earth measurements kit demonstrates
    RC time as a form of ADC - works quite well actually. You don't mention what
    the ADC is for though so its hard to recommend anything. I've found that the
    built in 10 bit ADC functionality of the AVRs is pretty well useless for my
    application. 10 bits isn't quite enough resolution and there isn't enough
    control over the sampled voltage range e.g. 0-2.5v is the minimum and the 0
    isn't negotiable. I use a TLC2543 ADC instead. 12 bits, 11 channels, has
    both ref+ and ref- ability (supply both a high and a low voltage reference
    so you can sample between the two, instead of the low end having to be
    zero).
    If you don't need that much resolution for your ADC, there are plenty of
    dirt cheap 8 bit ADCs out there. ADC08031 is a single channel 8 bit and it
    has a 4 channel equivelent (ADC08034 of course). There are very common,
    every electronic store/supplier should have plenty in stock. Here's the
    datasheet http://cache.national.com/ds/AD/ADC08031.pdf
    Check the parallax website before you purchase anything as well. They have
    tons of online PDF experiments available free.
    Remember, microcontrollers aren't like home computers. You have no reason to
    purchase one type and "stick" with it forever. They're consumable in fact.
    Make a project and its gone, you need another for the next project. No
    reason the next project *must* be the same controller.
    Meridian 59 is back! Sacred Haven - server 200
    www.skotos.net
    Original Message
    > Hi,
    > start to finish.
    > Requirements:
    > 4-6 LED outputs
    > 4-6 switch inputs
    > here.
    > to have A/D inputs.
