BS2p-24 cloner problems
Greetings,
I am trying to make a cloner from a BS2p-24 to write to another BS2p-
24. I have the program almost working but it only works with two of
the six BS2p-24's that I have. I started with the clone.bs2 program
from Tracy Allen's emesystems.com web pages and have modified it to
send data from the clone's bank 1 to the target's bank 0. The other
banks are programmed in the same manner, 2 goes to 1, 3 goes to 2.
The clone program is in bank 0 and not transmitted.
Is there a format for the header that is sent? I suspect I have a
timing issue with not receiving the 's' character. Yes, these chips
send out an 's' not an 'r'. If its not propriatary could someone
share it? (or give a link to it?)
Paul
Paul
>Thanks
>Paul
I think the change from "r" to "s" happened with the firmware upgrade
from 1.2 to 1.3 (BS2pe only). It is still possible that you have
both firmware versions? BTW, the codes for the BS2p-40 are "R" and
"S", again "S" for the most recent firmware. I see my web page does
not reflect that upgrade.
Yes, there is a format, as described on my web page, and I think
Parllax has that information openly available somewhere now. But you
clearly have that right if your program works on at least one
BS2p-24--It should work on the others!
regards,
-- Tracy
it, a bank is just a 2K EEPROM image. The easiest way to "clone" is to send
the bytes of that image. Obviously, you want to use bank 0 as your control
program so you can setup some kind of exchange with the source of the "clone"
data [noparse][[/noparse]I was experimenting with a PC connection for a reprogrammable robot].
Once
the master program knows that a connection wants to be made and what back to
copy it to, it simply receives the stream of 2K bytes (you can use a
confirmation -- but this will slow things a bit) then writes them to the target
back.
Here's a spot where the STORE directive comes in handy. In pseudo-code, the
process looks like this:
1) Recieve target bank #
2) STORE target, then set eeAddr to 0
3) SERIN eeByte
4) WRITE eeAddr, eeByte
5) eeAddr = eeAddr + 1
6) IF (eeAddr = 2000) THEN Clone_Done
7) GOTO Step_3
The problem with my process for you is that it overwrites the entire bank --
so you can't overwrite bank 0 if you're currently running it it.
-- Jon Williams
-- Parallax
In a message dated 6/6/2003 1:02:32 PM Central Standard Time, prcoy@y...
writes:
> Greetings,
> Thanks
> Paul
