iButton question
All-
I am seriously thinking of incorporating i-button memory into a project that I
am
working upon, because the ability to have add-only EPROM memory (that is,
uneraseable memory), is quite desirable, as is the ability to swap a full-up
button
with a new one. I am looking at the DS1986.
I have two questions about the i-button memory:
(1) the EPROM write requires a 12 volt pulse appr 1/2 millisecond long to
permantly
change the memory. Does anybody out there have experience in shifting the TTL
level
signal of the Stamp to the 12 Volt level needed to write to the iButton?
(2) Is there any BS2 sample code for the iButton memory that out there anyone
has
seen.
-Mark
am
button
permantly
level
has
seen.
-Mark
can log temperature. The 12V question is easy just use a RTL or TTL
pullup circuit with a seccond 12V power supply. The code question is
a little trickier. I haven't seen any online but it wouldn't be to
hard to communicate with the ibutton using SEROUT and SERIN.
-Brian
--- In basicstamps@yahoogroups.com, "mmarpet" <marpetm@s...> wrote:
> All-
project that I am
(that is,
a full-up button
long to permantly
shifting the TTL level
iButton?
there anyone has
> seen.
> Thanks,
> -Mark
communicate with iButton devices without a serial-to-1-wire convertor. The BS2p
family has 1-Wire protocol built in.
-- Jon Williams
-- Parallax
In a message dated 6/5/2003 11:01:29 AM Central Standard Time,
selket_10027@y... writes:
Being a mechanical engineer, I have only a vague idea what you are
talking about. I think of a pull-up circuit as a pull-up resistor.
(DUH!) Don't I need to protect the stamp from the 12V? Can you point me
to some schematics? Thanks.
-Mark
> I'm a huge fan of the iButtons -- especially the thermochrons, which
> -Brian
>> All-
> project that I am
> (that is,
> a full-up button
> long to permantly
> iButton?
> there anyone has
>> seen.
>> Thanks,
>> -Mark
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
or the one-wire commands in the BS2P? I am using a 2P40 and have
already communicated with single 1-button devices (reading their serial
number) without additional hardware (just a resistor).
On Thursday, June 5, 2003, at 01:07 PM, jonwms@a... wrote:
> The iButton has its own protocol and you cannot use SEROUT and SERIN to
> The BS2p
> -- Jon Williams
> -- Parallax
like so:
The BS puts out 1-5 volts on a pin, and if you had two supplies sharing a
common ground, you could have an output pin tied to the base of an NPN
transistor, with the emmiter tied to ground, and the collector tied to the
+12V supply via a resistor (say, 1K ohm). With the pin high, the collector
of the transistor would be somewhere near .7 volts, but if you set the
output pin to low, the transistor will cut off, putting the collector at
+12V, making the transistor a switch. When the transistor is cut-off, the 1K
resistor will source (sink? I was taught current will flow from - to +, but
many others are taught current flow by holes...) 12V/1Kohms or 12 mA. Should
your iButton chip need more or expect less current on its input, you should
change the resistor accordingly.
Steve
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, June 05, 2003 7:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: iButton question
> Brian (and Stampland)-
> -Mark
> > -Brian
> >> All-
> > project that I am
> > (that is,
> > a full-up button
> > long to permantly
> > iButton?
> > there anyone has
> >> seen.
> >> Thanks,
> >> -Mark
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
connect with an iButton via SEROUT and SERIN. This is not possible without a
serial-to-1-wire convertor (which you don't need). Anyone using a non-P BASIC
Stamp can use the convertor and SEROUT and SERIN.
-- Jon Williams
-- Parallax
In a message dated 6/5/2003 2:07:00 PM Central Standard Time,
marpetm@s... writes:
> By "serial-to-1-wire convertor," are you referring to a hardware device
> > The BS2p
> >-- Jon Williams
> >-- Parallax
zman97211@y... writes:
> I think of a pull-up circuit similarly, however, I would solve the problem
> like so:
> Steve
"you could have an output pin tied to the base of an NPN
+12V supply via a resistor (say, 1K ohm)."
And a resistor between the stamp output pin and the base of the
transistor.....10k will do just fine. Otherwise, Mr. Stamp output pin will get
real mad
real fast.....
fooling around.
Thanks.
> problem
> like so:
> sharing a
> the
> collector
> at
> the 1K
> +, but
> Should
> should
> Steve
Original Message
> From: "Mark Marpet" <marpetm@s...>
>> me
>> -Mark
>>> -Brian
>>>> All-
>>> project that I am
>>> (that is,
>>> a full-up button
>>> long to permantly
>>> iButton?
>>> there anyone has
>>>> seen.
>>>> Thanks,
>>>> -Mark
>> and
On Thursday, June 5, 2003, at 04:29 PM, jonwms@a... wrote:
> You're fine with the BS2p-40. The post I responded to suggested on
> could
> without a
> non-P BASIC
> -- Jon Williams
> -- Parallax
>> device
>> serial
>>> to
>>> convertor.
>>> The BS2p
>>> -- Jon Williams
>>> -- Parallax
get real mad
> real fast.....
I understand this could be a problem, causing the pin to try to source too
much current. I currently have a BS2 hooked up directly to the base
directly, with the collector tied to Vcc and a resistor and an LED (2.2V,
30mA) from the emitter to ground, and have not noticed a problem. Could this
be because this allows the base to rise to a full 5 volts, instead of only
.7?
Steve
resistor in the emitter side circuit, or
you would have burned out the pin.
The earlier post assumed you tied the
emitter directly to ground -- in which
case you MUST have the current limiting
resistor in the base side circuit.
The 10K value of that post was to limit
the current through the transistor, as
well as through the stamp pin.
--- In basicstamps@yahoogroups.com, "Steve Ziuchkovski"
tied to the
pin will
> get real mad
> > real fast.....
source too
(2.2V,
Could this
of only
> .7?
> Steve
