spst switch as input device
Hi,
I am very new to stamps, so please excuse my ignorance. I am
building a kinetic sculpture, and want to use a SPST switch as an
input device. Can this be done??
V++
O O----+
> Input Pin
\ 10k
V
When the switch is open, the input pin will read 0.
When the switch is closed, the input pin will read 1.
--- In basicstamps@yahoogroups.com, "kailip" <lou@u...> wrote:
> Hi,
> Thanks
I'll try again
<tt>
V++
O O----+
> Input Pin
\ 10k
V
</tt>
> > Hi,
> > Thanks
--- In basicstamps@yahoogroups.com, "selket_10027"
<selket_10027@y...> wrote:
> Sorry about that, the browsers doesn't display my ASCII art
properly.
> I'll try again
> <tt>
> V++
O O----+
> Input Pin
> \ 10k
> V
> </tt>
> > > Hi,
an
> > > Thanks
lou@u... writes:
> Hi,
> Thanks
yes
switch is open. Its usually bad juju to leave a processor (or Stamp) pin
flapping in the breeze.
Original Message
> Sorry about that, the browsers doesn't display my ASCII art properly.
> I'll try again
> <tt>
> V++
O O----+
> Input Pin
> \ 10k
> V
> </tt>
circuit. Not sure what Rodent meant, because the circuit as shown pulls
the pin down when the switch is open, and the pin goes high when the the
switch is closed. See the instruction for BUTTON in the BS1 manual,
showing two configurations of your circuit.
Dennis
Original Message
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9FhZ3Gvj_jy1vB0ECUj-sDy3_jwK71nJq7vGnT88LzD2GwKqhpKd5DEarKD4CZLgOBDqyxzHl3xwbTk]daweasel@s...[/url
Sent: Sunday, June 01, 2003 2:42 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Re: spst switch as input device
I think you actually want to have the pin itself pulled up or down when
the switch is open. Its usually bad juju to leave a processor (or Stamp)
pin flapping in the breeze.
Original Message
> I'll try again
> <tt>
> V++
O O----+
> Input Pin
> \ 10k
> V
> </tt>
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
On Sunday, June 1, 2003, at 02:33 PM, kailip wrote:
> Hi,
> Thanks
Anyway, you should never leave a pin unconnected or tie the pin direct to +5
or ground.
Original Message
> You might also use the command BUTTON to debounce the switch, with your
jim
http://www.geocities.com/jimforkin2003/
Original Message
From: Mark Marpet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NDdMkDbYJj6XUpkgYoyWB3D-3Vz9Jl5W94re7hL-CayBccnfaNPO4t_wVFVLcmoJBC3Sv35R9-wFy2I]marpetm@s...[/url
Sent: Sunday, June 01, 2003 6:55 PM
Subject: Re: [noparse][[/noparse]basicstamps] spst switch as input device
It certainly can.
> Hi,
> Thanks
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
