Pausing and polling
This may seem elementary to all of you, but I need advice. I've done plenty
of programming in Java, C, C++, and Pascal, but embedded applications are
fairly new to me.
What is the best way, on a BS2, to pause execution while polling for a
button press? The best way I've come up with if using a FOR loop that does
absolutely nothing except run the BUTTON command. My program pauses
frequently for various lengths of time (in which the timing isn't all that
critical, although "about a second" or "about .25 seconds" is good enough.
This seems like a kludge, though. Is there a better way?
Steve
fairly new to me.
Steve
program loop you poll all your inputs one right after the other and set bits
in a variable according to their state. When you need to, check the status
of these bits and branch accordingly. This is how I process multiple sensors
on some of my robots.
Obviously the more statements you have in your loop, the less often you poll
your inputs, but you can tweak things and write your code to make things
work fairly fast.
Original Message
plenty
> fairly new to me.
multiple Pause statements, where I want nothing else to happen except
checking for the button press. So, it looks like I'll have to have subloops
that simply check for the press, and do nothing otherwise. I just don't like
a loop that simply increments a variable until it reaches a certain point.
As my code will always run on the same stamp, the timing of the loop is
predictable, but I guess I have something against this since I'm used to
programming for regular computer systems when the execution time can vary
widely (a FOR loop counting from 0 to 999 may take a second, or a
millisecond, or less, on a PC).
Steve
Original Message
> Assuming the button press (or whatever) is not very brief, within your
bits
sensors
poll
> work fairly fast.
Original Message
does
that
enough.
>fairly new to me.
>Steve
Hi Steve,
The button command is usually overkill, unless you need the
autorepeat function. It is usually more efficient to poll the pin
directly:
{PBASIC 2.5}
do until in0=0 ' waits for button low
nap 4 ' naps by 1/4 second, saving power
loop
If you don't need the power saving, you can use PAUSE 250 instead of
NAP 4. This does wait forever if the button is never pressed.
If you need a sure escape after ~1 second, then include a timeout:
{PBASIC 2.5}
watchdog=4
do until in0=0 OR watchdog=0 ' waits for button low or timeout
watchdog=watchdog-1
loop
On the BS2p and BS2pe you have another option, using pollwait:
pollmode 2 ' enable polling with wait action
pollin 0 ' pin p0 for the button, waiting for low
pollwait 4 ' wait for button low using 250 ms naps
' continue here
pollmode 0 ' disable polling
That can be configured to wait for activity from multiple pins and
achieves the lowest power drain, especially on the '2pe.
-- regards
Tracy Allen
electronically monitored ecosystems
http://www.emesystems.com
mailto:tracy@e...
specifying how many periods to wait for, instead of an arbitrary number for
a loop (oh, 1234 seems like a second). Like I said, exact timing isn't
critical, but this makes for a better convention.
Out of curiosity, if anyone knows, when a button is "tapped", approximately
what is the average time that a person actually makes contact? A bit of
trivia that may require some experimentation, but just a thought that came
to mind...
Steve
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Sunday, June 01, 2003 2:20 AM
Subject: Re: [noparse][[/noparse]basicstamps] Pausing and polling
plenty
> >fairly new to me.
does
that
enough.
> >Steve
> Hi Steve,
> directly:
> {PBASIC 2.5}
> loop
> {PBASIC 2.5}
> watchdog=4
> watchdog=watchdog-1
> loop
> ' continue here
> -- regards
> Tracy Allen
> mailto:tracy@e...
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Here is an example in psuedocode:
Main:
Clear Flag Byte
Check Pin 1:
If Pin 1 High
Then Set Bit 1 of Flag Byte High
Check Pin 2:
If Pin 2 High
Then Set Bit 2 of Flag Byte High
Check Flag Byte:
If Flag Byte > 0
Then Do Something
Else Goto Main
Original Message
> That would work fine if my code executed in a nice tight loop, but I have
subloops
like
> bits
status
> sensors
> poll
> > work fairly fast.
Original Message
> does
> that
> enough.
This is kinda what I do when looking for a key input from the pak6 keybd
chip, check a data available pin on another chip which indicates data wants
to come through on another pin. Is there a fairly simple string of
components that can keep his key press on the pin as a high or a low, until
the stamp answers with a high or a low to reset the string of components to
the un-pressed condition? If so maybe one line could be used and the
program wouldn't have to loop either. Would this be a hassle to do?
Cure Cancer and Smallpox with your computer.
It runs as a screen-saver Sponsored by Intel:
http://members.ud.com/download/gold/
Original Message
Sent: Saturday, May 31, 2003 8:31 PM
> Why use a for / next loop?
> Main:
> Clear Flag Byte
> Check Pin 1:
> If Pin 1 High
> Check Pin 2:
> If Pin 2 High
> Check Flag Byte:
> If Flag Byte > 0
> Then Do Something
> Else Goto Main
Original Message
have
> subloops
> like
point.
vary
set
> > bits
> status
> > sensors
you
> > poll
things
> > > work fairly fast.
Original Message
a
that
> > does
all
> > that
> > enough.
button-press needs a debounce of several milli-seconds,
(that is, when it changes you keep looking for it
to STAY changed -- the first press is going to
bounce for a few (1 to 3) milliseconds).
Also, a person percieves immediate response to
something he has pressed if it occurs within 100
mSec. (1/10 second).
Conceivably, you can lower this to 10 to 20 mSec.
The fastest a person can press a button, let go,
and press it again is around 60 mSec.
All measures are approximate, and should be
verified experimentally, but these will start
you in the right range, anyway.
--- In basicstamps@yahoogroups.com, "Steve Ziuchkovski"
<zman97211@y...> wrote:
> Ah, this looks like a better solution - Using pause for shorter
periods, and
number for
isn't
approximately
bit of
that came
> to mind...
> Steve
Original Message
> From: "Tracy Allen" <tracy@e...>
done
> plenty
applications are
> > >fairly new to me.
for a
that
> does
pauses
isn't all
> that
good
> enough.
> > >Steve
> > Hi Steve,
> > directly:
> > {PBASIC 2.5}
> > loop
of
> > {PBASIC 2.5}
> > watchdog=4
> > watchdog=watchdog-1
> > loop
> > ' continue here
> > -- regards
> > Tracy Allen
> > mailto:tracy@e...
Subject and
