Javelin -BS2 serial communications
Hello,
I am having trouble interfacing the Javelin Stamp to the Stamp2. I
am able to both send and recieve data to and from both when I am
using the Stamp's I/O pins, but not on the dedicated serial
connecor. I was hoping someone could point out the obvious error
that I am doing.
Here is my original system:
A Javelin Stamp on a breadboard. The stamp has the propor debug
serial connections to one of my PC's. Pin1 is being used to send
serial data and Pin2 is being used to recieve serial data. Using the
UART commands:
this.XMIT=new Uart(Uart.dirTransmit,CPU.pin1, Uart.dontInvert,
Uart.speed2400,Uart.stop1);
this.Rcv = new Uart(Uart.dirReceive, CPU.pin2, Uart.dontInvert,
I also have a Stamp2 on the 'activites' board. With a second PC
hooked into the on-board serial connector. I am also recieving
serial data on pin 15, and Sending serial on pin 14. Using the
commands like:
SERIN 15, 396, [noparse][[/noparse]WAIT ("%"), CC1]
SEROUT 14, 396, [noparse][[/noparse]"%", CC1]
Both boards are on a common power supply. Two wire, with 22K ohm
resistors (in serial) connect each recieve line to their respective
send line.
Using the code i wrote, this systems works great.... But
New setup:
Now I have changed the commands to the following:
Javelin:
Uart.speed9600,Uart.stop2);
Stamp2:
SERIN 16, 84, [noparse][[/noparse]WAIT ("%"), CC1]
SEROUT 16, 84, [noparse][[/noparse]"%", CC1]
I have removed the stamp debug cable (after progamming) and inserted
the two serial lines from pins 14 and 15 into pins 2 and 3 (the
propor pins) of the on-board serial connecotr (DB-9). Both lines
still have the 22k Oum resistors.
This system will not work with my code.
I have heared that the stamp will 'echo' characters back. This
should not affect my code. (I recieve garbage on the javelin serial
buffer).
Any ideas on what I should try? I think that the Stamp activities
board ground DTR and GND on the stamp, so those shouldn't be an
issue. I really just need to know what settings I should be using.
please help..
-Jim
that I am doing.
UART commands:
commands like:
send line.
New setup:
Javelin:
Stamp2:
buffer).
please help..
-Jim
>>inserted the two serial lines from pins 14 and 15 into pins 2 and 3
>>(the propor pins) of the on-board serial connecotr (DB-9). Both
>>lines still have the 22k Oum resistors.
The BASIC Stamp setup wasn't very clear to me. Since you're using the
Activity Boards DB-9 connector and a Rpin of 16, I'm not sure what
you are doing by inserting the 2 serial lines from pins 14 and 15
into pins 2 and 3.
Ed
1. Using
'SEROUT 16, SerBaud, [noparse][[/noparse] Data ] '
(the DB-9 connector)
requires an Inverted baud mode, when
talking to a non-Invert Stamp
(or Javelin) port.
2. The BS2 'pin-16' port (tied to the
DB-9) requires the OTHER port talking
to it to provide the +- 12 volts for
232 communication. You might try
running the Javelin in Invert mode,
and the BS2 in non-invert, to see
if that makes a difference.
3. You MUST have a common signal
ground between the Javelin and the
BS2 -- which from reading your post
you may or may not.
4. If you DIDN'T use the BS2 '16' port,
this should work with both chips on
non-invert, as long as you have put
in a common ground.
The conclusion is that by moving to
'port 16', you added a 232 driver into
the mix that wasn't there from BS2
pins 14 and 15, and so you need to
tell one side to send/receive 'Invert'.
Even then, this may not work depending
on the voltage requirements of 'port 16'.
--- In basicstamps@yahoogroups.com, "capstone32000" <jp@b...> wrote:
> Hello,
I
> that I am doing.
the
> UART commands:
Uart.dontInvert,
Uart.dontInvert,
> commands like:
> send line.
> New setup:
> Javelin:
Uart.dontInvert,
Uart.dontInvert,
> Stamp2:
inserted
serial
> buffer).
> please help..
> -Jim
looking for. First thing I will try when I get home is to invert the
Javelin. I was curious about the signal Ground Tie. I have both
units operating off of the same bench-top power supply, so both
stamps are at the same ground. Is this adaquate? In otherwords,
because there is no specified pin for signal gnd, I am assuming that
if the two chips are operating off of the same ground they do not
need an extra ground wire. Is this true?
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Aha! Several things.
> 1. Using
> (or Javelin) port.
> you may or may not.
> in a common ground.
With the stamp2 in the activites board, pin2 and pin3 on the DB9 are
connected directly to SIN and SOUT pins on the stamp. (Pins 1 and 2).
I was curious if anything special had to be done with pins 3,4 or 5
on the db9.
-someone had suggested that it may only be that the javelin needs to
be operating in 'inverted' mode. I will try this tonight.
-Jim
--- In basicstamps@yahoogroups.com, "amulet_ed" <edsandoval@h...>
wrote:
> Hi Jim,
3
the
> into pins 2 and 3.
> Ed
routinely swap BASIC Stamps and a Javelin Stamp in and out of the same activity
board with no problems.
-- Jon Williams
-- Parallax
In a message dated 5/28/2003 2:35:07 PM Central Standard Time, jp@b...
writes:
> Thanks for the reply
> on the db9.
> Thanks
> -Jim
should both be on the same ground. I was not sure if the 'power
supply' was two wall-warts plugged in to the same AC line -- in which
case, the 'ground' for each could be different enough to have an
effect.
It's easy enough to check with a voltmeter. Put one lead on one
board's ground, and the other lead on the other ground. You should
not have any DC voltage (OK, 10 milli-volts is not a problem). Check
for AC voltage also, again, it should be 0.
> Thank you very much for this reply... It is exactly what i was
the
that
> > 1. Using
> > (or Javelin) port.
> > you may or may not.
> > in a common ground.
a serial I/O cable at the same time? Check out:
http://www.geocities.com/jimforkin2003/
Original Message
From: amulet_ed [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LhIHdvBw8_xizzbLwib_FLsPK4HF2BAyNfF2TWK_KH_zgdx39fylV5slGBbCUR4qkxP3Xdc4QC69wV_MoyA]edsandoval@h...[/url
Sent: Wednesday, May 28, 2003 12:57 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Javelin -BS2 serial communications
Hi Jim,
into pins 2 and 3.
Ed
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
