Difference between 16468 and 84???
What is the difference between the serial port settings 16468 and
84?? Could anyone please explain??
Sumana Garikipati
Sumana Garikipati
both are for a BS2 or BS2E.
True means when the data bits are zero, the Stamp pin is at zero volts, and
when the data bits are one, the Stamp pin is at 5 volts. Inverted is just
the opposite -- when the data bits are zero, the Stamp pin is at 5 volts,
and when the data bits are one, the Stamp pin is at zero volts.
Original Message
The 'Inverted' modes are for when you are using
an RS-232 driver between your Stamp and the other
device. You would use this on 'pin 16' for
instance to talk to your PC from the Stamp,
since the Stamp has a built-in 232 driver on
that pin.
--- In basicstamps@yahoogroups.com, "Rodent" <daweasel@s...> wrote:
> 16468 is 8 bit, no parity, inverted, and 84 is 8 bit, no parity,
true --
volts, and
is just
volts,
Original Message
