closed loop control using basic stamp
Hi everyone,
I'm new to the group and just learning about the basic stamp. Before
going further with this technology, I'd like your opinion on wheather
or not the basic stamp is capable of doing what I intend.
I need an inexpensive way to automatically control the pressure
within a vacuum chamber. Process gas is introduced into the chamber
and the pressure is controlled by adjusting a "throttle" valve
between the chamber and the vacuum pump (currently done by hand with
reference to the pressure guage). The guage has a 0-5V linear output
which I monitor with a DVM. I would like to use a pc and Visual Basic
to provide the brains but don't know where to go from there. Stepper
motor to actuate the valve?, motor controller required?,other
hardware needed?
Does anyone know of a similar application that has been developed
that is published on the web or somewhere else? Any help would be
greatly appreciated.
hardware needed?
Your description is a touch vague, but I think you can
accomplish what you're looking for. The main
consideration is the feedback-loop speed. But, since
you mentioned adjusting the valve by hand, I guess
loop speed is not a big issue. The BASIC Stamp would
work for what you want by measuring the 0-5 volt
output and acting accordingly. But, acting accordingly
begins the tough (and potentially expensive) part.
First, I think you have to determine the electrical
requirements for the valve control. Could this be done
with an R/C servo? If not, I've seen motorized valves
in Product Design and Developement magazine (search
the web). But this is industrial type stuff and not
cheap. Would it be possible to attach a DC
gear-reduction motor to the valve shaft? These motors
are on eBay for around $10.00. Once the determination
is made about the valve control, then comes the signal
to control the valve. This would likely involve a
motor controller and appropriate power supply and
control signal. From there, a series of if-then
statements, plus adequate dead-band time (to avoid
"hunting") is what's required.
You mentioned PC and VB control. You could use a PC,
loaded with a simple VB application in conjunction
with a USB I/O controller to do the job. Look into the
LabJack U12 controller. It is plug-n-play USB
connected, had 8 x analog inputs, and 2 x analog
outputs along with 20 x digital I/O channels and
timers. You could easily establish a closed-loop
control system with this. I use one for a robot and it
is slick. At $119, it's a bargain and is compact and
robust. With this type of digital controller, you
could monitor the 0-5 volts directly, and use a 0-5
volt output to drive a Curtis DC motor controller
(eBay @ $47) to drive the DC motor. Very doable.
Dr. Diode
--- cskjdk <jkostura@s...> wrote:
> Hi everyone,
> basic stamp. Before
> opinion on wheather
> intend.
> the pressure
> into the chamber
> "throttle" valve
> done by hand with
> 0-5V linear output
> and Visual Basic
> from there. Stepper
> required?,other
> hardware needed?
> been developed
> help would be
> Thanks
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
the stamp should have all the "brains" you require.
I will do some looking thru some info at work... might have something on
a servo operated valve. I know I have something on a motor actuated ball
valve. What are the flow requirements, medium, temperature, etc. etc?
On Mon, 26 May 2003 06:59:47 -0000 "cskjdk" <jkostura@s...>
writes:
> Basic to provide the brains but don't know where to go from there.
Stepper
> hardware needed?
________________________________________________________________
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
Only $14.95/ month - visit www.juno.com to sign up today!
again: Initially, the vacuum chamber is evacuated to around 10E-3
Torr (760 Torr = 14.7psi or one atmosphere pressure). Process gasses
are then let into the chamber at a very low flowrate with the vacuum
pump operating. If the gas is introduced faster than it can be pumped
away, the chamber pressure rises, but the system is designed to allow
the necessary gas inflow and still maintain a low pressure (vacuum)
in the chamber. The chamber pressure varies by plus or minus 5% of
setpoint due to the process taking place within the chamber (a
metal/gas plasma). In order to control the chamber pressure with a
given (constant) gas inflow rate, a "throttle valve" is placed
between the chamber and the vacuum pump. A vacuum gauge reads out the
chamber pressure and provides a 0-5 V output proportional to the
pressure (linear). I wish to use this signal to automatically tweak
the throttle valve so as to maintain a set pressure. The valve is
a "butterfly" type (6" dia.) and the valve shaft can easily be
rotated using two fingers. During the process, the control range
required for the shaft is less than 10 degrees of rotation.
Adjustments are made every 15 - 30 sec. by hand and a typical
adjustment requires a shaft rotation of 2-3 degrees. This will
maintain a gauge output voltage typically, of say, 50 mV plus or
minus 1 mV. This is what I would like to accomplish with inexpensive
automation such as the stamp or a pc. Dr. Diode suggests a pc/USB I/O
controller/ DC motor controller/ DC motor with appropriate mechanical
linkage (gearing, etc.). Thanks for this info – I'll check out the
hardware you suggested. AMG AMG suggests going the stamp route –
thanks for your comments also. If my revised description of what I'm
trying to do is any more understandable than before and precipitates
further comments from the group I'd love to hear them. Thanks for
your patience with this control challenged plasma nerd.
ps - can this be true?
Someone named Rich Cook said "Programming today is a race between
software engineers striving to build bigger and better idiot-proof
programs, and the Universe trying to produce bigger and better
idiots. So far, the Universe is winning."
--- In basicstamps@yahoogroups.com, PH <drdiode2002@y...> wrote:
> Hi cskjdk,
> Dr. Diode
> > Hi everyone,
> > basic stamp. Before
> > opinion on wheather
> > intend.
> > the pressure
> > into the chamber
> > "throttle" valve
> > done by hand with
> > 0-5V linear output
> > and Visual Basic
> > from there. Stepper
> > required?,other
> > hardware needed?
> > been developed
> > help would be
> > Thanks
> > ignored.
> Do you Yahoo!?
to 20 ma inputs. This should not be a huge problem, also if your pump works
at a specific rate maybe a needle valve in the gas line set at the correct
flow rate and a solenoid or ball valve to open the line would work.
Larry Gaminde
Original Message
To: <basicstamps@yahoogroups.com>
Sent: May 26, 2003 9:46 PM
Subject: [noparse][[/noparse]basicstamps] Re: closed loop control using basic stamp
I agree - my original question was more than a touch vague. I'll try
linkage (gearing, etc.). Thanks for this info - I'll check out the
hardware you suggested. AMG AMG suggests going the stamp route -
> Hi cskjdk,
> Dr. Diode
> > Hi everyone,
> > basic stamp. Before
> > opinion on wheather
> > intend.
> > the pressure
> > into the chamber
> > "throttle" valve
> > done by hand with
> > 0-5V linear output
> > and Visual Basic
> > from there. Stepper
> > required?,other
> > hardware needed?
> > been developed
> > help would be
> > Thanks
> > ignored.
> Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
They have all sorts of neat (and expensive) stuff. You need a good valve if
you look at what it will cost you if the valve gets stuck open/closed. What
kind of damage can be done?
The stamp can monitor a sensor and operate a valve without any help. If you
want to use VB and a PC then forget the stamp and buy an I/O board for the PC
and do it directly.
Alan Bradford
Plasma Technologies
In a message dated 5/26/2003 9:35:16 PM Eastern Daylight Time,
controlsdude2000@j... writes:
> I don't really think you need a PC and VB. Based on your description,
> writes:
> Stepper
> >hardware needed?
a bit of gas !
My approach would be to add a bypass loop and a needle style valve.
these are considderably easier to control, and adjustments induce
considderably less system upset.
Since you are monitoring pressure, there is a very simple psuedo PID
contorl loop that the stamp can run will easily along with your
monitoring.
If you are forced to use the butterfly valve, considder your trig.
the farther your control point is from the valve axis, the more
movement you must impart to move it a distance.
a 1 inch lever will move a small fractin of an inch, whereas a 8"
lever will require over an inch to move the same degree of rotation.
The psuedo PID I wrote was for a PLC and is less than a few dozen
line in that format. if you have any programming experiance it would
be a piece of cake.
For simplicity, I would use a DC motor and an H-Bridge as the ammount
of control imparted on the motor is not that great.
Dave
try
gasses
vacuum
pumped
allow
the
inexpensive
I/O
mechanical
I'm
precipitates
> > Hi cskjdk,
> > Dr. Diode
> > > Hi everyone,
> > > basic stamp. Before
> > > opinion on wheather
> > > intend.
> > > the pressure
> > > into the chamber
> > > "throttle" valve
> > > done by hand with
> > > 0-5V linear output
> > > and Visual Basic
> > > from there. Stepper
> > > required?,other
> > > hardware needed?
> > > been developed
> > > help would be
> > > Thanks
> > > ignored.
> > Do you Yahoo!?
wrote:
> I think there called Proportional Valves, I have used them years
ago with 4
pump works
correct
> Larry Gaminde
ball valves are not good for proportinal control.
butterfly are nearly as bad, but the needle valve would be a huge
improvement.
considder also that in a bypass arrangement, the main range could be
controlled by the butterfly and the fine control by the much smaller
needle valve.
for instance, a 6 inch valve open 1/4 of the way may pass 100 CFM and
a needle valve selected for 20 CFM would then offer much much higer
resolution over it's range.
Dave
ago with 4
pump works
correct
> Larry Gaminde
improvement.
needle valve.
Dave
comments I received questioned the suitability of a 6" butterfly
valve for this application. Actually, in a high vacuum situation a
butterfly valve works fine. Remember that at 10E-3 Torr pressure
(about 1 millionth of an atmosphere) there aren't very many
(relatively speaking) gas molecules going past the valve so small
pressure changes can be handled quite well. I've decided to go with
the pc/I/O board concept suggested by Dr Diode. I checked out the
LabJack U12 controller and it looks like a promising candidate.
Thanks to all again for your help.
John (cskjdk)
> hardware needed?
IMO, you are attempting to create a "servovalve" the hard way.
Search for "servovalve" (and Pneumatics or vacuum) for some
technology hints.
OOC... Is this for a job, or a personal project? If for a job,
you'll probably find that once you've factored in your cost of time,
parts, assembly, etc, to reinvent the servovalve from scratch,
it would probably have been much cheaper to simply buy an off
the shelf one. (Hobby projects are different animals, though. :-)
I'll assume for now that you're still going to try it this way.
Your biggest problem if you try it this way is definitely
a HORRIBLY slow loop speed. Unless you are talking a LONG
time, or this system has a LOT of inertia, you could easily
end up with an oscillating pressure.
DVMs: First off, DVMs are IMO not the best way to measure this.
They take a long time to settle, sample, then EVENTUALLY
send it out serial. The date rate is LOW, and by the time
you've read it in, the latency for the data is significant.
Heck, you already have a 0-5V sensor. You are MUCH better
off directly interfacing your transducer to the micro via
a 0-5V A/D converter. You can always use your DVM as a
"local display" of the value for diagnostic purposes. <grin>
See the Stamp appnotes on parts and how to do that.
Next...
Under certain circumstances, instead of trying to make
a servo loop open and close a proportional valve, you MAY
be able to save money by using PWM and an on/off (bang-bang)
valve. This works very well for certain values of flow
rates, system inertial capacities, etc.. YMMV though
depending on the application.
To use a proportional valve, you'll need to mechanically
interface a servo to it. Otherwise, you'll ALSO have the
additional challenge of adding feedback to THAT, and
setting up an "inner" servo loop JUST for valve positioning
control, further slowing the system's response time.
BTW, If you DO decide to add a servo to a standard valve,
your programming may get a boost if you take the time to
measure and create an "opening command vs air flow rate"
lookup table in a test rig.
Lastly, to program this you should learn about PID Control
Loop technology, to understand how control loops work.
Bottom line:
IMHO, a Stamp / DVM / and motor driven valve will only work
if you're talking on the order of seconds to minutes loop
response times. If you need something faster (and aren't
buying a servovalve off the shelf), my advice is to use a
micro with a built-in A/D, and a good PID algorithm already
written and available in their applications library.
Good luck.
- Keith Mc.
"Bees aren't that busy, they just can't buzz any slower..."
Good luck with it.
--- In basicstamps@yahoogroups.com, "Keith Mc." <acti@P...> wrote:
Before
wheather
chamber
with
output
Basic
Stepper
> > hardware needed?
> technology hints.
> Next...
> Bottom line:
> Good luck.
> - Keith Mc.
