GPS to servo program?
Anyone know of a program that will take GPS info to a BS2 and MiniSSC
to control a servo? Found one, but can't seem to get it to work.
Have no experience so was hoping to work on something I had an
interest in. Not much on the web that I can find.
thanks
mike m
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Monday, May 26, 2003 12:12 PM
Subject: [noparse][[/noparse]basicstamps] GPS to servo program?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
wrote:
> can you link to the site with the code to see what it is like?
> thanks
> mike m T
Original Message
> From: "wsmalley2001" <wsmalley@c...>
MiniSSC
Subject and
> >The link is www.stoneflyers.com/program.htm. Any comments
appreciated. BIll S.
program again. Couldn't find much wrong. Put the
serial servo controller on output 7, and serial signal
from GPS coming in on input 8.
Under the serout commands the servo at position "0" is
the steering servo. The servo at position "1" is the
speed servo, hence it stays at a constant speed. You
can change the output to both servos depending on your
vehicle.
Matt Klarich
GPS guided R/C Truck Project
www.stoneflyers.com
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
where did will's code appear? Can you send a copy of the code out?
thanks
mike m
Original Message
Sent: Monday, May 26, 2003 7:01 PM
Subject: Re: [noparse][[/noparse]basicstamps] GPS to servo program?
> Will, I looked over your email and looked at the
> vehicle.
> Matt Klarich
> www.stoneflyers.com
> Do you Yahoo!?
the NMEA
strings used.
> MiniSSC
> > > interest in.
