1-Wire issues dealing with DS1991
Hey,
I have no problem reading the ID's of any 1-wire device, but how
ever, I'm having a problem using the DS1991 MultiKey iButton. I
can't seem to read/write/copy the scratch pad, nor read/write data
block keys properly. I have downloaded the charts for most of the
iButtons, I have the commands, grate, what do I do from there? How
can I make a program to read this 1-wire device (DS1991) using a
Basic Stamp 2P40?
Also this is a minor question but, why does the BS2P40 have a pin
arrangement of MAINIO 0-15, AUXIO 0-15, and not just pin 0-30? I
would be alot easier to control then to always be swaping back and
forth like that. =\
Matt
Basic Stamp 2P40?
forth like that. =\
Matt
The DS1991 is a secure device. Have you set the passwords for the
subkeys?
From the data sheet I also see that it has a command structure that is
a little different than non-secure 1-wire devices. The commands
require 3 bytes to initiate: the first byte is the command, the second
byte is specific information for the command, the third byte is a ones
complement of the second byte (command integrity check). Are you
sending the DS1991 specific 3-byte commands or using the standard 1-2
byte commands that other 1-wire devices use?
Get the DS1991 data sheet. It seems the DS1991 does things a little
different than other simple 1-wire devices (like thermometers, digital
pots, switches, etc).
Chuck Chargin Jr.
--- In basicstamps@yahoogroups.com, "Matt" <defiletech@y...> wrote:
> Hey,
> Basic Stamp 2P40?
> forth like that. =\
> Matt
reading the ID's) with the DS1991
--- In basicstamps@yahoogroups.com, "cchargin" <cchargin@e...> wrote:
> Hello,
> subkeys?
that is
second
ones
1-2
little
digital
> Chuck Chargin Jr.
> > Hey,
data
the
How
> > Basic Stamp 2P40?
pin
and
> > forth like that. =\
> > Matt
Nab the DS1991 data sheet:
http://pdfserv.maxim-ic.com/arpdf/DS1991.pdf
I have not used the DS1991, but I am familiar with other 1-wire devices
(DS18B20 thermometer, DS2409 microlan switch, etc...). Check out the data
sheet and look at the command flow charts. You will notice that they are a
little different than other non-secure 1-wire devices.
If you are just learning 1-wire stuff on the stamp I would suggest starting
out with the digital switches and thermometers first. They are easy to
work with while you learn the 1-wire protocols.
I put together the steps below just from looking at the data sheet. I do
not have a DS1991 to try it out with. I must say that compared to other
1-wire devices this DS1991 makes you jump through a lot of hoops to get
simple operations done! But I guess that is the price for security.
From the data sheet it seems that to write data to a the scratch pad, then
copy it to a subkey you would do the following:
Please remember that I couldn't actually verify that this will work since I
don't have a DS1991.
First you have to set a password for the subkey:
' i am not going for efficiency here, I want to show a variety of ways to
send data.
romdata VAR byte(8) 'put your DS1991 ROM ID in here
key0 VAR byte
... (key1 to key6 also dimensioned as bytes)
key7 VAR byte
'reset the bus, send match rom command, then the ROM (romdata is an array
of 8 bytes)
owout 15, 1, [noparse][[/noparse]$55, STR romdata\8]
'dont reset bus, and send the 3-byte command (write password, subkey %10,
third byte is 1s complement) the subkey is padded at the end with 6 zeros
owout 15, 0, [noparse][[/noparse]$5A, %10000000, %01111111]
'dont reset the bus, read in the 8 subkey ID bytes
owin 15, 0, [noparse][[/noparse]Key0, Key1, Key2, Key3, Key4, Key5, Key6, Key7]
'This "read/write back" step is so you look at Key0 to Key7 and verify that
this is the key you want
'dont reset the bus, write the subkey ID bytes back to the DS1991
'this step will erase ALL data in the target subkey!
owout 15, 0, [noparse][[/noparse]Key0, Key1, Key2, Key3, Key4, Key5, Key6, Key7]
'dont reset bus, send new identifier for subkey
owout 15, 0, [noparse][[/noparse]"MyNewID!"]
'Send the new password (as a sysadmin I have to say that you should NEVER
actually use this password [noparse]:)[/noparse] ), then rest the bus
owout 15, 2, [noparse][[/noparse]"Password"]
Okay now we will write data to the subkey (this is a long way to do it):
'first we will write the data to the scratch pad
of 8 bytes)
'dont reset bus, and send the 3-byte command (write scratchpad, address,
third byte is 1s complement of the address). Our address will be %00101010
= $2A (42 of course!), but we have to pad the 2 most significant bits with
1. So our address becomes %11101010 = $EA. The 1s complement is %00010101
= $15
owout 15, 0, [noparse][[/noparse]$96, $EA, $15]
'send the data then rest the bus
owout 15, 2, [noparse][[/noparse]"Data!"]
'now we copy the scratch pad to the subkey
of 8 bytes)
'dont reset bus, and send the 3-byte command (copy scratch pad, subkey
%10, third byte is 1s complement) the subkey is padded at the end with 6 zeros
owout 15, 0, [noparse][[/noparse]$3C, %10000000, %01111111]
'now we have to tell the DS1991 which block to copy. the block selector
code scheme is odd. You can only write in 8 byte or 64 byte blocks. Each
block has a weird 8 byte identifier. This identifier is for the range $28
to $2F
owout 15, 0, [noparse][[/noparse]$65, $9A, $4C, $9D, $64, $91, $69, $B3]
'now send the (really weak) password, then reset the bus
Chuck Chargin Jr.
At 10:13 PM 5/25/2003 +0000, you wrote:
>Here's the thing, I don't know how to do that, nor anything (besides
> > Hello,
> > subkeys?
>that is
>second
>ones
>1-2
>little
>digital
> > Chuck Chargin Jr.
> > > Hey,
>data
>the
>How
> > > Basic Stamp 2P40?
>pin
>and
> > > forth like that. =\
> > > Matt
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
with my basic stamp, unfortunatly it does not work properly. I
cannot seem to read the secure data after the unsecure data gets
coppied over from the scratch pad. Either I'm not reading it
properly, or I'm not writting properly (or both), but I cannot read
the same data I enter in to the DS1991. I don't know why this
ibutton is giving me so much trouble. Also, yes I have worked with
many different 1-wire devices in the past such as 1-wire transister
switchs, tempature sensors, digital pot's, etc. Yet still I have
trouble with this one. =(
--- In basicstamps@yahoogroups.com, "Chuck Chargin Jr."
> Hi,
devices
the data
they are a
starting
easy to
sheet. I do
other
to get
security.
pad, then
work since I
ways to
> send data.
> key0 VAR byte
bytes)
> key7 VAR byte
an array
> of 8 bytes)
subkey %10,
6 zeros
verify that
should NEVER
do it):
an array
> of 8 bytes)
address,
00101010
bits with
00010101
> = $15
an array
> of 8 bytes)
subkey
with 6 zeros
selector
blocks. Each
range $28
> to $2F
> Chuck Chargin Jr.
(besides
wrote:
> > > Hello,
the
> > > subkeys?
> >that is
commands
> >second
is a
> >ones
you
standard
> >1-2
> >little
> >digital
> > > Chuck Chargin Jr.
wrote:
> > > > Hey,
how
iButton. I
> >data
> >the
there?
> >How
using a
> > > > Basic Stamp 2P40?
> >pin
30? I
back
> >and
> > > > forth like that. =\
> > > > Matt
Subject and
