how do I
Hello All,
To vastly reduce the number of my coding headaches, I'd really love
to be able to refer to the I/O pins by different names. Currently,
I'm using the CON keyword to set up statements like:
armup con 0
high armup
which works but since it only creates an alias for the number it's
pretty limiting in the expressions I can use (for output functions,
have to use HIGH and LOW instead of pin = value, etc.).
I'd really rather set it up so I could, for example, use:
armup=1
in place of:
out0 = 1
If I'm reading the manual correctly, the BS1 looks like it can
create a pointer to a specific bit with the SYMBOL command (which
would solve my problem) but the BS2 seems to be lacking this
ability. Is there any way to either create an alias for or a
pointer to a specific I/O bit on the BS2? It seems like this should
be possible somehow.
thanks!
John
armup con 0
high armup
armup=1
in place of:
out0 = 1
thanks!
John
directive):
armup var out0
armup = 1
regards
Adrian
the BS2, you use the CON and VAR declarations separately. So you can do
this:
armUp VAR Out0
...and later:
armUp = 1
We generally refer to this as aliasing a variable.
In PBASIC 2.5 (available with the new compiler that you can get as a beta
release) there is a new directive called PIN. This directive is specifically
for IO pins and allows the compiler to intelligently handle IO pin
definitions. The reason is that some parts of the language want the pin
number as a constant (i.e., 0) , other commands want an IO bit (i.e., In0 or
Out0). So now you can do this:
ArmUp PIN 0
... and later:
HIGH ArmUp ' ( compiler converts to HIGH 0 )
ArmUp = 1 ' ( compiler converts to Out0 = 1)
-- Jon Williams
-- Parallax
In a message dated 5/22/2003 2:47:14 AM Central Standard Time,
jjghost@t... writes:
> Hello All,
> armup con 0
> high armup
> armup=1
> in place of:
> out0 = 1
> thanks!
> John
