Rotating Electrical Connection
I want to use my stamp to to make a sort of propeller type light
show, just using LED's... I thought about just using a battery and
counter balancing the unit, But then I thought with the speed I need
this to spin at it wouldn't work well. Now if I have 16 led's evenly
spaced all controlled by the stamp, I can properly balance this unit.
My only problem is getting the power from the "Base Station" to the
spinning unit. Does anyone have solutions? I thought about circular
friction contacts, but I was hoping for a component that would solve
my problem.
I hope this all made sense
Any help would be greatly appreciated.
Eric Sailer
my problem.
Eric Sailer
>my problem.
>Eric Sailer
Hi Eric -
This doesn't answer your question, but you might find it an interesting
propeller clock project:
http://www.bobblick.com/techref/projects/propclock/propclock.html
The telephone cord un-twisters might work for you at low RPM. I suspect
even Radio Shack may carry them.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Try this web site.
http://www.visi.com/~dc/slipring/index.htm
I've used this info a couple of times and it works pretty good.
Hiram
> my problem.
> Eric Sailer
> from the same email address that you subscribed. Text in the Subject and Body
here is site that manufactures and distributes
alternatives to sliprings. Their claims are that they
are superior to sliprings in all aspects, their FAQ is
pretty nice.
"The connection is made through a pool of liquid metal
molecularly bonded to the contact, which provides a
low resistance, stable connection."
i looked at a couple briefly, model 331 is 3 conductor
2@4 amp & 1@30 amp and rpms as high as 1800.
never used them though because my intended project
fell through. hope that helps.
ross
--- Hiram Cook <hiramcook@e...> wrote:
> Hi Eric,
> Try this web site.
> pretty good.
> Hiram
> using a battery and
> balance this unit.
> > my problem.
> > Eric Sailer
> Text in the Subject and Body of the message will be
> ignored.
> ignored.
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
more "Non Hacked" Approach.
Best Regards,
Eric
http://www.bobblick.com/techref/projects/hbridge/hbridge.html
click on 'propellor clock' in the right hand menu. It might be useful.
--- In basicstamps@yahoogroups.com, Klutch <klutch66@y...> wrote:
> http://www.mercotac.com/html/main.html
> pretty nice.
> ross
> > Hi Eric,
> > Try this web site.
> > pretty good.
> > Hiram
> > using a battery and
> > balance this unit.
> > > my problem.
> > > Eric Sailer
> > ignored.
> > ignored.
> Do you Yahoo!?
