Solder wick
fine braid versus coarse......what's the advantage to each?
smartdim@a... writes:
Fine braid has more surface for the solder to adhere to, and holds flux
better. I can think of no advantage to the coarse braid.
Sid Weaver
W4EKQ
Port Richey, FL
I don't know but if it works and sucks up all the unwanted solder who cares?
I think the stuff I use is fine, but then I never knew I had a choice. Im
still using a roll I got from a place I worked in 1986. Maybe I should make
more mistakes and get a chance to shop for Solder Wick.
Actually I use a good solder sucker. Mine cost $14 it is an aluminum one not
one of the cheap plastic ones. This works better for pulling all the solder
from IC pins. The wick seems to leave a small bond, and when trying to pull
it up, more often than not, the trace/pad comes up with it. I still have Bull
in the China Closet Syndrome.
Alan Bradford
Plasma Technologies
and thus requires clipping off, to be replaced by more, quicker. The overall
result is that you heat a junction less, but use more braid cleaning it. I'd
use the fine stuff for very heat sensitive junctions, and the thick stuff
for any components with power handling cases, and any discretes such as
resistors and capacitors.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Tuesday, May 13, 2003 12:06 PM
Subject: [noparse][[/noparse]basicstamps] SOLDER WICK
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
michael_duerksen@c... writes:
> Fine braid wicks better at lower temperatures overall, but loads up faster,
> overall
> I'd
> Mike
Thanks for the explanation...
> In a message dated 5/13/03 12:12:02 PM Eastern Daylight Time,
who cares?
choice. Im
should make
aluminum one not
the solder
to pull
have Bull
> Alan Bradford
> Plasma Technologies
Beats my blow torch and wack it on concrete method ! Of course that
is for salvaging multiple parts off junk boards. probably shoud get
a hot air gun.....
Dave
And, it eliminates someone peeling off 2' of solder, using 3", and the
rest getting so messed up that no one can use it<G>.
