Getting parallel data on BS2... newbie
Hi... I have a Clare 8870-01 DTMF decoder that I want to interface
with my BS2 for a application that does stuff based on dial-tones.
The 8870 takes a touch-tone tone in, and outputs a corresponding
binary code on 4 outputs (Q0-Q3). Also, a Valid-Tone pin (ESt) goes
High when a valid DTMF tone is detected. Eg, I press a 7 and I get a
0111 parallel output on Q0-3 and a 1 on ESt until I release the 7
button.
The 8870 part of the circuit is working great and I'm pleased. But
now I want my BS2 to make some use of this. I'm trying to write some
code that watches ESt, and when ESt is HIGH the stamp looks at Q0-Q3
and says, "Ok, I see a 0111... I will set key=7".
Can anyone offer a code sample, or maybe point me to a good resource
(I did RTFM, and I'm sure I can hack my way through it, but I'd like
to hear what the pros think).
Thanks a bunch!
button.
Thanks a bunch!
the BS2, that shouldn't be too difficult at all.
key var byte 'define variable "key"
'Q0-Q3 to pin0-pin3
'ESt to pin4
loop:
if in4=0 then loop 'do nothing until ESt goes high
key=in3*8+in2*4+in1*2+in0*1 'convert to base 10 (pin3 is MSb)
if key=0 then...
if key=1 then...
if key=2 then... (etc.)
Hope that helps! - John
--- In basicstamps@yahoogroups.com, "iamlevis2" <iamlevis2@y...>
interface
goes
a
> button.
But
some
Q3
resource
like
> Thanks a bunch!
can't wait to get home and give it a try!
Thanks... I'm sure I'll be back
--- In basicstamps@yahoogroups.com, "max2451234" <jjghost@t...> wrote:
> Presuming you've got all five data lines you mentioned running to
> 'Q0-Q3 to pin0-pin3
> 'ESt to pin4
> loop:
> if key=0 then...
> if key=1 then...
> interface
> goes
get
> a
> > button.
> But
> some
> Q3
> resource
> like
> > Thanks a bunch!
using some of the Stamp's built-in variables. Like this:
key = InA
Ta da.... Done. No math required. InA is a nibble sized variable that is
affected by the input pins 0 - 3.
-- Jon Williams
-- Parallax
In a message dated 5/12/2003 1:35:07 PM Central Standard Time,
jjghost@t... writes:
to an epiphany that I'm sure will help me in my stamping.
> 'Q0-Q3 to pin0-pin3
> 'ESt to pin4
> loop:
> if key=0 then...
> if key=1 then...
> interface
> goes
get
> a
> > button.
> But
> some
> Q3
> resource
> like
> > Thanks a bunch!
