tap-to-on switch :)
Hi guys,
Toying around with some house appliance.
Am looking to convert a lamp I got to be LED driven (most prob a
stamp to prototype and if costs permit, for final "run") I don't like the
idea of having an external switch and the lamp's pretty heavy to mounth a
switch below (i.e. like how apple's optical mice are pressed)
The lamp I'm converting is made of glass (frosted), I was thinking
of putting a vibration sensor or something to that extend so I can just
tap on the light to switch it on (or change colors, since with leds i can
have a nice variety of colors to play with)
Any one got any recommendation for such a sensor/switch ?
I dont want it to be too sensitive (so when i drop some stuff on
the table, it will not trigger), but not too hard to use (I hate the idea
of having to use a mallet to switch it on)
I was thinking of a capacitative switch (I've seen such around,
but the contacts seem to be of metal not glass), or even a light sensor
(i.e. those door chimes, but the glass is pretty heavily frosted)
Thanks in advance [noparse]:)[/noparse]
Elvin
Elvin
>Hi guys,
>Elvin
Elvin -
You might want to look into the use of one of the QPROX Sensors as found here:
http://www.qprox.com/products/touch.php
These sensors are designed to work behind glass as well as for other
applications.
Bruce Bates
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Got a comment from a friend to do it wireless, gonna skip the expensive
options of AM data kits, since its basically "on/off", any one knows of
kits to do it cheap and easily ? (RF based ideas are way above me for this
one)
Elvin
On Sat, 10 May 2003, Alf wrote:
> Hi guys,
would be easy to use if you just want on-off switching (you won't
have to worry about accurate data transfer, any junk received at the
rws would mean the tws tried to send something). Although the wire
antennas need to be about a foot long (maybe you can hide it
soemwhere).
--- In basicstamps@yahoogroups.com, Alf <elvin@e...> wrote:
> Hi,
expensive
knows of
for this
> one)
> Elvin
> > Hi guys,
prob a
like the
mounth a
thinking
can just
leds i can
activate an outdoor system (just on/off) from 30-40 feet away. also, is it
okay to just listen for "junk" on the channel? it seems like it would be
safer to listen for some sort of simple, repeating pattern from the
transmitter (like SOS or something) to keep noise from causing a false
triggering.
thanks,
d...
Original Message
> From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=exlV3aP3fNOhu8RYzxvJ_qMqVoW2obMDYmZW0THKAnM5-yabVzJ4-Rrr9-OVJwS-CmB69_sq6CowKwc3]hard-on@t...[/url
> Sent: Sunday, May 11, 2003 7:36 AM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: tap-to-on switch [noparse]:)[/noparse]
> tws-434 RF transmitter and rws-434 RF receiver are 8 bucks each and
> soemwhere).
> > Hi,
> expensive
> knows of
> for this
> > one)
> > Elvin
> > > Hi guys,
> prob a
> like the
> mounth a
> thinking
> can just
> leds i can
> Subject and Body of the message will be ignored.
are sensitive to triggering from other sources, since they share frequencies
with other devices. I had a clock with a remote wireless thermometer that
would periodically blast my receiver. Drove me nuts until I found out what
it was.
Original Message
> What's the typical range on those things? I need to be able to remotely
it
> triggering.
> > soemwhere).
> > expensive
> > knows of
> > for this
> > > one)
>triggering.
>thanks,
>d...
Dave -
Do us all a favor, and yourself as well. Keep SOS as a repeating pattern
out of your mind COMPLETELY. You're asking for nothing but trouble in the
possible confusion something like that might case. We're speaking FEDERAL
GOVERNEMNT REGULATIONS here !
Bruce Bates
alzheimer's moment, probably should have put it in quote's or something). I
was just thinking about some unique, repeating string of bits. Again, sorry
about the confusion. Is there a "smiley" for a dope-slap?
d...
Original Message
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7mki6qWTgqvQwE_PSk7ZH73sN9CgTXR4XWiCpftTvQzVwp1tF2WBdEFB4Bf3sPQ8B7esM4PeuGq6AkK752a1CfI]bvbates@u...[/url
> Sent: Sunday, May 11, 2003 8:23 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: tap-to-on switch [noparse]:)[/noparse]
> also, is it
> >triggering.
> >thanks,
> >d...
> Dave -
> Regards,
> Bruce Bates
switching.
On Sat, 10 May 2003, Bruce Bates wrote:
> At 05:24 PM 5/10/03 +0800, Alf wrote:
> >Hi guys,
> >Elvin
> Elvin -
> applications.
> Regards,
> Bruce Bates
> from the same email address that you subscribed. Text in the Subject and Body
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
