I have following problem and hope can help along myself you:
I have actuates the OSCAR-MP3-Player of that a 4x20-Zeichen point
matrix display. The display is actuated over a 4bit-Bus. Because I
would like to incorporate the Players gladly in the trunk of my car,
br
Despite my somwhat limited knowledge of German,
I hope I can help Luemmel.
"I have the following problem and hope you can help me.
I have an OSCAR MP3 player that drives a 4x20
character PointMatrix display .
The display is connected through a 4-bit bus. As I want to
install the player in the trunk of my car, I need a circuit
to connect a serial 4x20 character display with the 4-bit
bus.
As a solution I considered simply programming a PIC
to handle the parallel to serial conversion or a UART.
However, I don't know how to make a workable circuit.
It'd be nice if you could help me."
Marylou
_________________________________
--- In basicstamps@yahoogroups.com, "luemmel1" <dugt2@g...> wrote:
> Hallo an alle hier im Forum :-)
> Ich habe folgendes Problem und hoffe ihr k
I don't know how well I have the point of the question, but it appears that
Luemmel1 is attempting to interface a 4x20 display, with an onboard 4 bit
bus, to an MP3 player in his car, and needs some advice on how to interface
the two, implementing a parralel to serial converter, using UARTS, with
BasicStamp control. I don't speak German, but learned a little from my
Grandparents, when they were still alive. If anyone can elaborate on this,
or correct my interpretation, please do.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, May 07, 2003 10:24 AM
Subject: RE: [noparse][[/noparse]basicstamps] Adapter 4bit-Bus auf Seriell-LCD-Display?
OTS, but is this the result of one of the translation pages on the web? I
never bothered to look at one of them before (one of the [noparse][[/noparse]dis?]advantages of
being a native English speaker is not needing to translate much), and always
wondered how well they do.
Original Message
Sent: Wednesday, May 07, 2003 1:54 PM
Subject: [noparse][[/noparse]basicstamps] Re: Adapter 4bit-Bus auf Seriell-LCD-Display?
Here you go guy's this should help.
Hello at everyone here in the forum: -)
br
Hmmm. Better than my knowledge of German, Marylou. But one question, since
you probably didn't have a chance to read my sorry post, yet. Is it the
circuit he needs, or is it the program to control the circuit? And what word
or phrase in his post corresponds to the circuit/program? My German stinks,
maybe you can improve it here, on the cheap.
Original Message
Sent: Wednesday, May 07, 2003 3:23 PM
bus.
Marylou
The words schaltung/beschalten imply wiring so I assume he needs
help with a parallel to serial conversion circuit. Maybe Luemmel can
clarify this - Wir brauchen eine bessere Klarstellung.
Marylou
--- In basicstamps@yahoogroups.com, "Mike Duerksen"
question, since
the
what word
stinks,
> Thanks
> Mike
Original Message
> From: astumpf999 <astumpf999@y...>
> bus.
> Marylou
If I got this right you want to replace your original LCD (which
is hooked up by a 4bit bus) by a 4x20 serial LCD (the ones we
all know here). So you need some circuitry and software to convert
signals and protocol. I think this is feasible with a stamp or
PIC. But you need to be more specific on that 4bit bus (kind of
parallel or serial?)
And in german:
Wenn ich das recht verstanden habe, willst du das originale LCD
(angeschlossen
Halfway down the page is a simple 74LS164 circuit
to talk to a LCD with a 2-line interface.
The LCDProc project was to interface an LCD with
Linux -- however, the 74LS164 circuit is fine for
moving the LCD long distances from the BS2.
I would put an RS485 driver/receiver in the
channel, though, and use shielded cable.
I
> br
In the 4-bit modus the data should be clocked first with the high
nibble (bits 4-7 (D4-D7)) followed by the low nibble (bits 0-3 (D0-
D3)).
Thanx
luemmel
--- In basicstamps@yahoogroups.com, "Adrian Schneider"
<adrian.schneider@t...> wrote:
> Hi everybody
> And in german:
> (angeschlossen über einen 4bit bus) mit einem seriellen 4x20 LCD
> (so eins, wie wirs alle kennen) ersetzen. Folglich brauchst du
> eine Schaltung/Software um vom 4bit protokoll ins serielle zu
> konvertieren. Ich denke das ist machbar mit einem Stamp oder PIC.
> Du solltest vielleich diesen 4bit bus genauer beschreiben (ist das
> eine Art parallele Schnittstelle?).
> _______
> ---->! stamp !
> ---->! or !
> ---->! PIC !
>[noparse][[/noparse]serial LCD]
> ---->!_______!
> Regards
> Adrian
Thank you, Marylou. Can you give me an exact translation of each of the
words schaltung and beschalten. I realize from the structure that they are
probably declensions of the same root, but what root?
Original Message
Sent: Wednesday, May 07, 2003 11:53 PM
Marylou
question, since
the
what word
stinks,
> Thanks
> Mike
Original Message
> bus.
> Marylou
Mike, Maybe Adrian can answer this. My knowledge of German grammer
isn't that good.
Marylou
_________________________________________
the
they are
> Mike
Original Message
> Marylou
> question, since
it
> the
> what word
German
> stinks,
> > Thanks
> > Mike
Original Message
Display?
> > bus.
> > Marylou
For being understood by wider audience I do this in english.
I think the wiring of the LCD for asynchronous serial communication
should be simple. HP and MB can be wired together as there may be
no need for handshakeing. Then you just need GND and RxD of your
LCD (I assume it is not required for the display to talk to the
stamp using TxD - but its up to you). An UART is probably not
needed as the LCDs are satisfied with TTL levels. Try your
LCD with a long (shielded) cable to verify that it works over the
required distance. I recommend to have your interface (stamp) near
the player and run the long cable between the interface and the LCD.
If you want to build an interface using a stamp I suggest to do some
experimentation first to find whether the stamp can handle the 4bit
protocol from the uC and how to work with the display (my experience
is limited virtually to the pure serial LCDs by SEETRON which are
really easy to use. I think your display is not all to different).
See the basic structure of an interface program below
LOOP:
clock_for_1st_nib
character.NIB1 = INP(D3..D6)
clock_for_2nd_nib
character.NIB0 = INP(D3..D6)
optional_further_conversion
send_LCD(character)
goto LOOP:
Hook up you LCD to the stamp and write a simple program to see whether
the minimal wiring (TxD and GND) works. Your display is pretty rich on
features and needs to be configured properly.
Then write another test program to implement the 4bit protocol. See
whether you are able to receive the characters from the uC which you
expect. In place of the LCD use just a few DEBUG statements first.
Then try to connect the two together. You may find that the interface
is not fast enough (which means that you may have to do it with a PIC)
or you might need some conversion e.g. for special symbols or control
characters (optional_further_conversion).
English bitte
Original Message
From: luemmel1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GQKPeZXXT07xHi3P5qR25TiyxQG7SQjYtVwXtw_DV4btzEC0lMXopC9xpB-pjoPCf4RSg20]dugt2@g...[/url
Sent: Wednesday, May 07, 2003 9:43 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Adapter 4bit-Bus auf Seriell-LCD-Display?
br
bus.
Marylou
Original Message
Sorry most of use cannot ready German.
English bitte
Original Message
From: luemmel1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=F2EekQRK8qWxO6D4orJuQFozgGWvAhphy46kk0mfZCPI4a6w_s0yd9mfrfD2L3v3xhKdzw]dugt2@g...[/url
Original Message
br
Original Message
bus.
Marylou
Marylou
question, since
the
what word
stinks,
> Thanks
> Mike
Original Message
> bus.
> Marylou
And in german:
(angeschlossen
See http://lcdproc.sourceforge.net/docs/0.4.4-docs-
html/drivers.html#HD44780-HOWTO
I
> br
Your translation is perfect !!!
The original display is wired as follows:
_____ ________________
! !-D0--->
RS-! !-Vcc
! !-D1--->--R/W(/WR)-! !-Brightnes
! !-D2--->----E(/RD)-! !-GND
! ! D0-! !
! ! D1-! 4x20 Character !
! µC ! D2-! Dot Matrix !
! ! D3-! Display !
! !-D3--->
D4-! !
! !-D4--->
D5-! !
! !-D5--->
D6-! !
! !-D6--->
D7-! !
!_____! !________________!
The serial display wiring diagram:
____ ______ _________
! !-D0->
RS---D0-! PIC !-RXD--->---TXD-! Serial !
! !-D1->-R/W(/WR)--D1-! (or !-CTS--->----MB-! VFD !
! !-D2->---E(/RD)--D2-! UART)! ! Display !
! !-D3->
D4--D3-! ! ! Module !
! !-D4->
D5--D4-! ! !_________!
! µC !-D5->
D6--D5-! !
! !-D6->
D7--D6-! !
!____! !______!
The timing diagrams can found here:
http://www.noritake-itron.com/EPages/Log.asp?
PCode=Specs/GU7000/GU140x32F-7806-04&PType=pdf
D3)).
Thanx
luemmel
> Hi everybody
> And in german:
> _______
> ---->! stamp !
> ---->! or !
> ---->! PIC !
> ---->!_______!
> Regards
> Adrian
Original Message
Marylou
question, since
the
what word
stinks,
> Thanks
> Mike
Original Message
> bus.
> Marylou
isn't that good.
Marylou
the
they are
> Mike
Original Message
> Marylou
> question, since
it
> the
> what word
German
> stinks,
> > Thanks
> > Mike
Original Message
Display?
> > bus.
> > Marylou
LOOP:
clock_for_1st_nib
clock_for_2nd_nib
send_LCD(character)
goto LOOP:
Regards
Adrian
