hmm...
I am running some of the experiments in the Earth Measurements
'stamps in class' book. Here is the short one I am working on:
'{$STAMP BS2}
debug "here we go"
dit con 70
dah con 3*dit
i var nib
for i = 1 to 5
freqout 0,dit,1900
pause dit
next
pause dah
for i = 1 to 5
freqout 0,dah,1900
pause dit
next
If I do not put in the debug statement, I just hear 1 short beep. I have
noticed in other experiments that things are not working right without
at least 1 debug statement. I am using the NX-1000 experiment board.
Has anyone else run into this?
Kurt
'{$STAMP BS2}
debug "here we go"
dit con 70
dah con 3*dit
i var nib
for i = 1 to 5
freqout 0,dit,1900
pause dit
next
pause dah
for i = 1 to 5
freqout 0,dah,1900
pause dit
next
Kurt
conducting a BASIC Stamp training class in March. Change your serial buffer
FIFO settings to zero. That fixed the problem on two separate machines (I'm
betting you're using a notebook PC).
-- Jon Williams
-- Parallax
In a message dated 5/5/2003 6:12:50 PM Central Standard Time,
krp@t... writes:
> '{$STAMP BS2}
> debug "here we go"
> dit con 70
> dah con 3*dit
> i var nib
> for i = 1 to 5
> freqout 0,dit,1900
> pause dit
> next
> pause dah
> for i = 1 to 5
> freqout 0,dah,1900
> pause dit
> next
> Kurt
Thanks! That did the trick. This mailing list is a valuable
resource, and Parallax should take some bows for
maintaining a presence here! Thanks again Jon!
Kurt
>From: jonwms@a...
>Subject: Re: hmm...
>This is a weird serial port problem on your PC -- I saw this in Holland
while
>-- Jon Williams
>-- Parallax
>>krp@t... writes:
