SERIN, WAIT and String or Constant
HI:
I am using SERIN to wait for a certain Letter, the letter being "K"
before it can receive the rest of the transmission.
The code looks like this:
SERIN RX\FLO, I9600, 40, SENSOR, [noparse][[/noparse] WAIT ("Y"), DEC receiveVar]
IT waits 40 milliseconds for a "Y" to be sent from a trasmitter then
attains the number after the Y (receiveVar)and applies it to another
process. If it does not receive a Y in 40 milliseconds it goes to a
subroutine called SENSOR.
The problem that is happening is that I am sending a "Y"...the sender
shows its sending. But no matter what my receiver is not recognizing
the letter. PUtting STR for string to anything doesn't work either.
I've also testing using ASCII characters instead of Y but it has not
worked either.
Any suggestions?
Alison
worked either.
Any suggestions?
Alison
recognized as you say, or it could be that "Y" is seen and the
problem is in receiving the variable data.
Try this:
SERIN RX\FLO, I9600, 40, SENSOR, [noparse][[/noparse] WAIT ("Y")]
DEBUG "Got a Y"
STOP
If you see the DEBUG message, then the WAIT part is OK and try this:
SERIN RX\FLO, I9600, 40, SENSOR, [noparse][[/noparse] WAIT ("Y"),receiveVar]
DEBUG "Got ", HEX2 receiveVar
(Note no DEC.) That will show you what followed the "Y".
It may be that ending your SERIN argument list with DEC receiveVar is
a problem. The DEC modifier tells SERIN to keep accepting ASCII
numerics forever until something else appears. But in your case it's
not clear that would ever happen, so the statement may be waiting
patiently for more data before it passes control on to the next
instruction.
Steve
Thank you. Right now it's not getting past the SERIN...
SERIN RX\FLO, I9600, 40, SENSOR, [noparse][[/noparse]WAIT("Y"), receiveVar]
HIGH 12
I made a "HIGH 12" to turn on a light when if it passes the
serin...it naver makes it past the serin.
I also tried this:
'''from transmitter
SEROUT TX\FLO, BAUD, [noparse][[/noparse]"Y"]
''' receiver
SERIN RX\FLO, BAUD, 40, SENSOR [noparse][[/noparse]WAIT("Y")]
HIGH 12
The above didn't work either. Any Thoughts?
--- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> From your description, it could be that the "Y" is not being
> Try this:
> DEBUG "Got a Y"
> STOP
is
it's
> instruction.
> Regards,
> Steve
add complexity:
> '''from transmitter
loop:
DEBUG CR,"Sending"
> SEROUT TX, BAUD, [noparse][[/noparse]"Y"]
PAUSE 500
GOTO loop
> ''' receiver
LOW 12
loop:
> OUT12 = 1 - OUT12
> SERIN RX, BAUD, [noparse][[/noparse]WAIT("Y")]
GOTO loop
You should be able to see the data blips if you hook up your LED to
the transmitter's TX pin. When you get that working, add the
timeout and flow control features (one at a time) until you have
everything working right.
How have you defined TX, TX and BAUD and what models of Stamp are
you using? Also, you mentioned in your first message that SENSOR is
a subroutine. If by that you mean you exit that subroutine with a
RETURN, that's another bug waiting to bite you, since the timeout is
essentially a GOTO operation.
How is the TX pin connected to the RX pin? Do the two Stamps share a
common ground?
Load your program up with DEBUG statements to see where you're
going or not going. If all else fails, post your entire programs
for review.
Steve
I think your problem is that the SERIN times out after just 40ms
(no matter whether you use flow control or not).
If your "Y" arrives shortly before execution of the SERIN or
briefly after SERIN timed out (after 0.04s) it is just missed and
your program continues with SENSOR (or whatever timeout target).
As the stamp does not buffer serial IO, all characters get lost
if they do not arrive exactly inside the SERIN read interval.
I also believe that it is not the code that fails here, but rather
the concept - you should probably redesign that part.
Of course you could also "simply" add a buffer to that IO line.
Regards
Adrian
