Integrate me
I have a rotational rate sensor which outputs a voltage proportional to
rotation speed (.11 mv per degrees / second). I want to integrate the
rate over time to give position (i.e. North, South East West and the
points in between). The BS2P will be performing other simultaneous
functions so how do I establish a known and steady sampling rate to
achieve an accurate integration? If possible I'd like to sample at about
10 Hz. Any ideas?
Chris
________________________________________________________________
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
Only $14.95/ month - visit www.juno.com to sign up today!
10 Hz. Any ideas?
Chris
Where did you get it? How much was it? Thanks!
- Robert
angular position is difficult at best, because any DC voltage offsets
will also be integrated to result in positional errors. The longer the
integration time, the more cumulative error. I attempt to do this
computation, using Murata angular velocity sensors, for a project
measuring human postural sway, but I limit the integration time to about
20 seconds, and also detrend the positional data to remove the offset
errors. This takes advantage of the "boundary conditions" of human
postural sway, in order to limit the cumulative errors. So a steady
smapling rate, for A/D conversion can be easily done, but it is not the
main problem.
An alternative approach is to use a digital compass, which has the
advantage that it has an external positional reference (magnetic north
pole), and interface that to a stamp. Other list members, and also Nuts
& Volts, have experience with these.
Dennis
Original Message
From: Christopher Dundorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TZPk3BpzRpP9NIB5RCbMYPqH64lz5TtKJlWYQYMq7ypr_HI2r4rMeHWIfUB8421jxFZHQdhmHoci]cdundorf@j...[/url
Sent: Monday, April 28, 2003 2:43 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Integrate me
about 10 Hz. Any ideas?
Chris
The best thing to hit the internet in years - Juno SpeedBand! Surf the
web up to FIVE TIMES FASTER! Only $14.95/ month - visit www.juno.com to
sign up today!
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
I'm using a through-hole version of the MuRata Gyrostar -- 03JA and
03JB, but with the same sensor characteristics as the SMD versions in
your web reference. I had to buy these in quantity (A & B versions)
about 3 years ago when they were first marketed. Yes, I reset the
integration. One method is based on using the MuRata in combination
with Analog Devices ADXL202 linear sensors, using the latter to watch
for a "null point" of human sway where the standing human as an
"inverted pendulum model" passes through a vertical axis.
I also have the ADXRS150, but haven't compared it with the MuRata yet.
My guess is that it will have lower drift, because of the on-board
temperature sensor, and the capability to then apply a temperature
compensation table for drift in a Stamp or PIC. The trade-off is that
you have to contend with a BGA (ball grid array) form factor.
For accurate sampling rates using PICs, I use an external crystal
oscillator, and divide down by 2s to reach a particular sampling rate.
For example, using a PIC16C622A, I use an oscillator at 4.096 MHz, and
divide down to a sampling rate of 1000 or 500 to trigger interrupts in
the PIC. To get an accurate rate of 10 Hz, my approach would be to
oversample at 500 Hz, apply some digital averaging (sliding boxcar
filter) and then store every 50th point (decimation by 50) for an
overall rate of 10 Hz. I don't know if this approach will work with a
Basic Stamp, given its lack of a true interrupt capability, but others
on this list will have some alternative approaches for the Stamp.
Only reason I mentioned a digital compass, is that I've been impressed
watching a robotic mower, which has a built-in compass, graze around my
lawn.
Dennis
Original Message
From: cdundorf@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4uYi7-JXmfy7fPizycV-rQMH2kNKcKE-BgmwcfTzDwv-zTLMQG5QtfQQvJ7Fd3zkoKPvpXDJXk0]cdundorf@j...[/url
Sent: Tuesday, April 29, 2003 7:01 AM
Cc: doleary@u...
Subject: [noparse][[/noparse]basicstamps] RE: Integrate me
Dennis,
Unfortunately, a digital compass is not an option. It's sound like
you've already spent sometime in this arena. I too am concerned about
offset bias. Do you use the boundry conditions as "trip wire" to reset
the intergration?
You mentioned MuRata, are you using the MuRata GyroStar
http://www.murata.com/catalog/s42e3.pdf? I'm running the Analog Devices
ADXRS150. I am interested in your thoughts on how they compare, namely
drift. I could find much else on the GyroStar specs.
As for gathering the data integrate, do you have suggestions for how
achieve a steady 10 Hz sampling rate using a Basic Stamp?
Chris
Subject: RE: Integrate me
Accurate numerical integration of an angular velocity sensor to produce
main problem.
Dennis
Original Message
From: Christopher Dundorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4uYi7-JXmfy7fPizycV-rQMH2kNKcKE-BgmwcfTzDwv-zTLMQG5QtfQQvJ7Fd3zkoKPvpXDJXk0]cdundorf@j...[/url
Chris
sign up today!
Unfortunately, a digital compass is not an option. It's sound like you've
already spent sometime in this arena. I too am concerned about offset bias. Do
you use the boundry conditions as "trip wire" to reset the intergration?
ADXRS150. I am interested in your thoughts on how they compare, namely drift.
As for gathering the data integrate, do you have suggestions for how achieve a
Chris
main problem.
Dennis
Original Message
From: Christopher Dundorf [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TYMU4re7rALyD6Su7duMEq1py_A8hYDCQCp_BsAbA1ucdjS44CWVPDwmY-Ws52mj7cO85FzkVN2u]cdundorf@j...[/url
Chris
I'm using the Analog Devices ADXRS150. The evaluation board is about $40 and
easy to use. Check out
http://www.analog.com/Analog_Root/productPage/productHome/0,2121,ADXRS150,00.htm\
l
Good Luck,
Chris
I don't know that I can help you, but that sounds like a neat sensor.
- Robert
using a dedicated PIC (or BS1 if you want to stick with P-BASIC) for
the sampling and just have the BS2 talk to the PIC. - John
I like that sensor idea, btw!
--- In basicstamps@yahoogroups.com, Christopher Dundorf
proportional to
the
the
at about
> 10 Hz. Any ideas?
> Thanks,
> Chris
without using the evaluation board, the BGA structure of this chip
presents problems, as compared with other available SMD or through hole
sensors.
Dennis
Original Message
From: cdundorf@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1jkVMpaT-AfPtZblGipPPnntZ40TS9Yr17v2IiaBVvDinNb6jyiZvuT6fkCFe2hCi5nCzXJx-_cRbIs]cdundorf@j...[/url
Sent: Tuesday, April 29, 2003 7:07 AM
To: uavscience@f...
Cc: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Re: Integrate me
Hi Robert,
$40 and easy to use. Check out
0,00.html
Good Luck,
Chris
- Robert
sign up today!
> I have it also and I agree. However, for building into a project
> hole sensors. Dennis
AD's WEB site says $50, $100! from Newark.
> Hi Robert,
> 15 0,00.html
> Good Luck,
> Chris
Yes, there's always a solution. Last time I checked, a BGA machine cost
about $35K. [noparse]:)[/noparse]
Dennis
Original Message
From: Mike DeMetz [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3ZnvGx67fD6TSGHweSXDkbanRs11tMxntGe4YN_JqCR6sWjtlg8PsJjjSPvJ9XhZNt49y04Ah2g]miked@e...[/url
Sent: Thursday, May 01, 2003 1:13 PM
Is there an adapter or other solution?
> Hi Robert,
> 15 0,00.html
> Good Luck,
> Chris
