Two quick questions
Hi all,
I just started to incorporate a voltage monitoring system into my
project using the adc8031, BS2, and a 4.8 v battery.
I was running it and the voltage was coming up fine, but I noticed that
it was extremely hot, I touched it and was almost blister hot.
Is this standard?
My other question was, I'm running out of I/O pins and I have an lcd
screen and I read some where that you can tri-state one of the data bus
lines.
What does this mean and can I do it? I just want to add a sharp Gpd02-4
to my project, and just need one more pin.
-Mike
Is this standard?
lines.
-Mike
laxboy687@e... writes:
> Hi all,
> Is this standard?
> lines.
> -Mike
"blister hot" is not normal! Some part of your circuit is pulling too much
current.
Also, what was extreemly hot, the stamp, the adc???
What input voltage are you running to power the stamp?
being run by a 9v battery, and the adc was connected to the battery that
my robot is going to use.
Original Message
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DjeviEx8cszLD7zZSMOsuA5lbB1w1XgRceXYcodtq8vuwwA2uVpwldfks6-nEB5WS01sbV0A7odTURw]smartdim@a...[/url
Sent: Tuesday, April 29, 2003 8:35 PM
To: basicstamps@yahoogroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Two quick questions
In a message dated 4/29/2003 5:07:54 PM Pacific Daylight Time,
> Hi all,
that
> Is this standard?
bus
> lines.
Gpd02-4
> -Mike
much
current.
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
are you measuring direct or thru a voltage divider ?
Dave
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> The adc was hot, I have a board of education so the board and stamp
were
that
Original Message
> From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
> > Hi all,
> that
> > Is this standard?
lcd
data
> bus
> > lines.
> Gpd02-4
> > -Mike
too
> much
> current.
Subject
Original Message
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wVdsn-XoiWIGOR7ejCpI6aT98JUcJNkmZ-G9bEzhVPmgFLco3PkfxhckLy0uoMdMnJngPfHg9cZi]davemucha@j...[/url
Sent: Tuesday, April 29, 2003 9:15 PM
Subject: [noparse][[/noparse]basicstamps] Re: Two quick questions
did you put in a 10K resistor to limit the current ?
Dave
were
that
Original Message
> > Hi all,
> that
> > Is this standard?
lcd
data
> bus
> > lines.
> Gpd02-4
> > -Mike
too
> much
> current.
Subject
Original Message
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SAzxeWsTerIV_Nv6T4_OSSpXpJdUDcZ07veOOdZlBcwnOgc797EUgym-KheRBJqQpcVxKJHX1qoJbQ]davemucha@j...[/url
Dave
were
that
Original Message
> > Hi all,
> that
> > Is this standard?
lcd
data
> bus
> > lines.
> Gpd02-4
> > -Mike
too
> much
> current.
Subject
> > Hi all,
noticed that
> > Is this standard?
lcd
data bus
> > lines.
Gpd02-4
> > -Mike
Are you powering the ADC from +5V or from the 9V? I don't have the
specs in front of me, but I power the ADC's from the 5V available
from the Stamp.
too much
> current.
