Turn on a led for two minutes each 13 minutes all day ...
Of the millions of microcontrollers in use world-wide, most don't use
interrupts. I used to work in the irrigation business for a company the
sells tens of millions of sprikler timers every year. Every one of them had
a microcontroller in them, and only the top-of-the-line golf course
controller ($3500 ea) used a micro with interrupts.
I'm not saying that interrupts are never needed, but I am saying is that they
are rarely required -- and you won't find them on any BASIC language micro
because BASIC is NOT reentrant.
The best you can do is poll an input between instructions (BS2p and BS2pe
does this -- as well as competitive products that claim interrupts) or
structure your code so that the input can be polled with some frequency.
PBASIC is sturctured very nicely for embedded control and allows this.
Here's a "template" control structure that I like to use:
Main:
DO
' do critical item (like poll an input)
ON task GOSUB Task_0, Task_1, Task_2
task = task + 1 // 3
LOOP
With this sturcture, the critical item (like checking an input) gets
processed between each of the other program tasks. This is a very simplistic
approach; on more sophisticated projects each task is responsible for
updating the task pointer.
-- Jon Williams
-- Parallax
In a message dated 4/28/2003 8:28:54 AM Central Standard Time,
allan.lane@h... writes:
> I believe the DS1305 does have an alarm pin -- but this
> doesn't help much with the BS2, which has no interrupt
> inputs.
> One approach would be to set up a DS1302 time chip,
> 'sleep' the BS2 for some period, then on wake up ask
> the time chip what time it REALLY is, and cycle on
> that until the desired time occurs.
Main:
DO
LOOP
-- Jon Williams
-- Parallax
> inputs.
out something to be aware of. The BS2 is a very nice
package with a very nice feature set, especially
considering the price and simple learning curve.
There are some things it doesn't do very well,
but these things (like keeping accurate time) tend to
be easily added with minimal cost (like $5.00 for a
DS1302 based solution).
use
company the
them had
that they
language micro
BS2pe
frequency.
this.
> Main:
> DO
> LOOP
gets
simplistic
for
> -- Jon Williams
> -- Parallax
> > inputs.
thinking that since this project "runs all day long" that it must be
powered by an AC power supply. By carefully tapping into the
transformer secondary and using a few simple components such as a
resistor, diode, and NPN transistor to condition the 60Hz sine wave.
Apply the resulting square wave to one of the stamp pins and let the
software count like a clock. (If you are in Europe then its 50Hz,
still same principle).
Hal
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> But of course. I wasn't being critical, merely pointing
> use
> company the
of
> them had
course
is
> that they
> language micro
and
> BS2pe
interrupts)
> or
> frequency.
> this.
> > Main:
> > DO
> > LOOP
> gets
very
> simplistic
> for
> > -- Jon Williams
> > -- Parallax
> > > inputs.
can I get the seconds only from
the 1302 RTC?
I think that I could make blink a led
each 13 minutes (13x60=780 sec) but
somebody knows how can read the seconds only?
Sorry I am not an expert.
But it has been difficult to write
a program with seconds only.
My idea is to read the second number
780th and an write something like:
if nnn=780 then blink
blink
High 5
pause 1000
Low 5
return
But my problem is the nnn.
Thanks in advence
__________________________________
Do you Yahoo!?
The New Yahoo! Search - Faster. Easier. Bingo.
http://search.yahoo.com
59, so you'll have to create a separate counter. What you can do is read the
seconds register from the 1302, then check to see if it's the same as last
time. If it isn't, then a new second has passed and you increment your
counter. Then do your logic.
Something like this (pseudo-code):
Setup:
GOSUB Read_Secs_Reg
oldSecs = secsReg
Main:
GOSUB Read_Secs_Regs
IF (secsReg <> oldSecs) THEN
nnn = nnn + 1
oldSecs = secsReg
SELECT CASE nnn
CASE 0 TO 778
LOW LedPin
CASE 779
HIGH LedPin
nnn = 0
ENDSELECT
ENDIF
GOTO Main
-- Jon Williams
-- Parallax
In a message dated 4/29/2003 12:08:21 PM Central Standard Time,
joeterk@y... writes:
> Somebody knows how
> the 1302 RTC?
> blink
> High 5
> pause 1000
> Low 5
> return
> Thanks in advence
The 1302 uses hours, minutes, seconds.
HIGH RTCCS
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE,
[noparse][[/noparse]Seconds,Minutes,Hours,Date,Month,Day,Year]
LOW RTCCS
The above will read the values from the chip.
See '1302.bs2' in the 'Files' area for a full example.
Note the 1302 returns 'BCD' coded numbers.
Really, you need to look at the 'minutes' field, see
if it's 13, and output your blink.
--- In basicstamps@yahoogroups.com, Joe Terk <joeterk@y...> wrote:
> Somebody knows how
> the 1302 RTC?
> blink
> High 5
> pause 1000
> Low 5
> return
> Thanks in advence
> Do you Yahoo!?
Yes, I see the minutes too but
all is ok when I read until 9
, 10 is not allowed by the program.
Perhaps it is because there are two
digits. (That is my problem)
Many Thanks: Joe
--- Allan Lane <allan.lane@h...> wrote:
> I don't think you can.
> HIGH RTCCS
> LOW RTCCS
> example.
> > Somebody knows how
> > the 1302 RTC?
> > blink
> > High 5
> > pause 1000
> > Low 5
> > return
> > Thanks in advence
> > Do you Yahoo!?
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do you Yahoo!?
I assume that you have a RTC and you get the variable MINUTE with the sub.
RTC_Minute from it.
'{$STAMP BS2}
'{$PBASIC 2.5}
LED pin 0
COUNTER var nib
MINUTE var byte
OLD_MINUTE var byte
high LED
COUNTER = 0
MINUTE = 0
OLD_MINUTE = 0
Main:
gosub RTC_Minute
if (OLD_MINUTE <> MINUTE) then
OLD_MINUTE = MINUTE
COUNTER = COUNTER + 1
if (COUNTER > 3) then low LED
endif
if (COUNTER = 12) then
COUNTER = 0
high LED
endif
goto Main
' Of course the next isn't a RCT X-)
' but you can test if the code works...
RTC_Minute:
MINUTE = (MINUTE + 1) // 60
pause 59990
return
Luis.
Mensaje original
De: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IHfEvvHFdwrHZ4ltu3Q8YP_YRVdyVdUdvPqMaQBvL-Zl8ibRBleYq2hZmStf8DvTDm5sxryoCWHYALys]joeterk@y...[/url
Enviado el: martes, 29 de abril de 2003 21:50
Para: basicstamps@yahoogroups.com
Asunto: Re: [noparse][[/noparse]basicstamps] Re: Turn on a led for two minutes each 13
minutes all day ...
Many Thanks: Joe
LED=off, would be
'{$STAMP BS2}
'{$PBASIC 2.5}
LED pin 0
COUNTER var nib
MINUTE var byte
OLD_MINUTE var byte
low LED
COUNTER = 0
MINUTE = 0
OLD_MINUTE = 0
do
gosub RTC_Minute
loop until (MINUTE = 0)
high LED
Main:
gosub RTC_Minute
OLD_MINUTE = MINUTE
if (COUNTER = 3) then low LED
endif
if (COUNTER = 15) then
COUNTER = 0
high LED
endif
goto Main
stop
RTC_Minute:
debug DEC2 ? MINUTE
pause 59990
return
Luis.
Mensaje original
De: Luis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AgHIVT8Gu64DmgvqIEH9V2JzSthS1CSvkxqJiR-U9iArwFG3H1dP7YC8B8ekHxjKI-kmpI4YsN0]lullamas@y...[/url
Enviado el: miercoles, 30 de abril de 2003 00:41
Asunto: [noparse][[/noparse]basicstamps] Re: Turn on a led for two minutes each 13 minutes
all day ...
Try this.
RTC_Minute from it.
'{$STAMP BS2}
'{$PBASIC 2.5}
LED pin 0
COUNTER var nib
MINUTE var byte
OLD_MINUTE var byte
high LED
COUNTER = 0
MINUTE = 0
OLD_MINUTE = 0
Main:
gosub RTC_Minute
OLD_MINUTE = MINUTE
endif
COUNTER = 0
high LED
endif
goto Main
RTC_Minute:
pause 59990
return
Luis.
Mensaje original
De: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mXrDJs3lBfrc2CMChoQzkyNPQQzf90bXXmGkMARuHn9m1iWVZaoSlwRmUrT19Rz8wctKkTjitA]joeterk@y...[/url
minutes all day ...
Many Thanks: Joe
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
