Using BS2sx in a car
I am using a BS2sx and a Javelin stamp in a project in a car, and I
need to have the following things:
1. Detect the presence of +12VDC and represent it as +5vdc to the
stamp.
2. Detect the presence of chassis GND and represent it as GND to the
Stamp.
3. Ability to control a 5VDC 30mA relay coil using either a GND or
+5vdc source.
4. Noise resistant two way communications on a twisted pair shielded
cable.
I have ideas on what to use for these problems, but I figure that
others are using stamps in automotive apps, and I am curious on how
it is being done with the smallest component count.
What I have figured out so far:
regarding #1 I think an optoisolator will do the best job, but how do
I do these things, does anyone have a schematic for my specific
application. I dont want to fry parts, or worse, have the parts fry
over time while I am driving down the road...
Regarding #2 It seems that stamps like to work using ground, it draws
virtually nothing from the stamp, and is a great way to provide
signals to the stamp with relative safety. one question - how do I
keep noise and transient spikes out of this circuit?
Reagrding #3 ULN2803 seems to be able to drive a relay? no extra
parts needed? just a diode on the coil leads?
Regarding #4 - RS485? anyone have luck with this? In my situation I
only have 2 signal wires and a ground to work with.
I am looking for workable schematics of these circuits involving
working in a 12VDC environment. I am also looking into viable
power sources for the BS2 and have found that the 7805A seems to fit
the bill, has anyone found a schematic with 12VDC in, 5VDC out? I
know these are all simple questions, but I just want to make sure I
am completely headed in the right direction. thanks in advance for
any advice, feel free to tell me I am doing it all wrong [noparse];)[/noparse]
Brian
stamp.
Stamp.
+5vdc source.
cable.
Brian
briancase1972@y... writes:
> stamp.
> Stamp.
> +5vdc source.
> cable.
> Brian
You are on the right track. You can reply off the post directly to me with a
fax # and I can send a schematic.
volts but usually up to 14.5 volts dc or so when the engine is running. A
7805 regulator is OK to cut the voltage down if you use a heat sink or a
resistor to drop some of the voltage coming in to keep the heat down on the
chip. Stamp ground should be at vehicle ground potential. Optical
isolators would work for incomming 12 volt signals to convert to 5 volts but
a simple voltage divider will also work for less cost and complexity. Pick
values to see 4 volts at the junction of the two resistors with 14.5 volts
in and you should have no problems. Place a .1 uF cap to ground on the
input to the stamp to knock down some of the high frequency noise. You can
eliminate a relay on the output and just switch a transistor instead and
save the cost of the relay. You can also talk to the stamp serially if you
wish and have it respond to external serial commands or transfer data out to
your computer. For some controller applications and schematics, and links
to parts suppliers where you can get data sheets, check my web site:
http://www.geocities.com/jimforkin2003
Jim
Original Message
From: Brian [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZgvS-FYBEuSYrWLTcJd6ED0NOZKcOQELMDLw-l8U_kX_Id8jQMbityo-3hlEW6V1Jq57rlarHjOlDGybxoOs]briancase1972@y...[/url
Sent: Tuesday, April 08, 2003 11:49 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Using BS2sx in a car
stamp.
Stamp.
+5vdc source.
cable.
Brian
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I would also like to add that during starp up, there can be very
large spikes on the nominal 12V supply. These spikes can be up to
40V and carry enough energy to damage unprotected eqiupment.
This can also happen if there happens to be a 'loose battery'
terminal, which means that the alternator can be intermitantly
disonnected from the battery resulting in a large spiked, again
posing damage to the verlunerable parts.
So, keep these facts in mind when designing a power supply.
Best Regards
Ashfaq
--- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
> Brian, A few items need to be mentioned. In a vehicle, 12 volts
is not 12
running. A
or a
down on the
volts but
complexity. Pick
14.5 volts
the
You can
instead and
serially if you
data out to
and links
> Jim
Original Message
> From: Brian [noparse][[/noparse]mailto:briancase1972@y...]
> stamp.
the
> Stamp.
> +5vdc source.
shielded
> cable.
do
draws
I
> Brian
Subject and
writes:
> A
> chip.
Beware of using a resistor in series with the input to a 7805 regulator. If
the current consumption is constant, there will not be a problem.
However, if you install an in-series resistor to the regulator is "minimal"
circuit current, then some loads draw more current, the voltage drop across
the in-series resistor will increase and reduce available voltage to the
regulator, which may fall out of regulation.
In summary, if you use an in-series resistor, be sure its value is chosen for
the worst case current consuption.
Somebody please correct me if I don't see the entire picture here. A certain
amount of power will be dissipated dropping the vehicle voltage to the
regulator.
You can choose to have the regulator dissipate all the power, or share some
of the dissipation with a resistor, regardless, a certain amount of power
must be dissipated. What is the advantage to an in-series resistor????? The
high wattage resistor is cheaper than the heat sink for the
regulator??????That is the only advantage I see.
If using the resistor however, it must be chosen using the worst case current
consumption, otherwise the regulator may fall out of regulation when the
regulated current increases due to some load being controlled on.
Ken
(7805) has a maximum temprature that is easy to exceed when regulating 15
volts. Of course, the amount of voltage drop in heat is the same, it
however is shared between the regulator and resistor. Remember that in an
automotive application you are starting with a high ambient temperature. A
better choice would be a switching regulator that runs more efficiently.
The load seen by the regulator would be the stamp current and drive to the
transistors and they should be darlingtons or mosfets for low drive
requirements. Relays or sensors should be powered by 12v.
Jim
Original Message
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T2wMcPfI2qA6koYkUcbcQ6bpq-MTsh6Z0jaQ2ECx9gEkUTNPLl7GPk0feFjphGwL3Z6lY4GmGUg]smartdim@a...[/url
Sent: Wednesday, April 09, 2003 11:44 AM
Subject: Re: [noparse][[/noparse]basicstamps] Using BS2sx in a car
In a message dated 4/9/2003 8:01:35 AM Pacific Daylight Time,
jjf@p...
writes:
> A
the
> chip.
for
regulator.
current
Ken
jjf@p... writes:
> The advantage of the external dropping resistor is that the linear regulator
> Jim
Thanks for the explanation
