Buried Fence Detector
My friend has a buried fence system for keeping his dog within the yard. He
never installed it, and it has been in his garage for the past few years.
We are trying to build a mower-bot with the BS2. I found a circuit in an
old Projects book from Radio Shack that uses an Op-Amp and a Power-Amp. We
built the circuit and connected the input to an Inductor. The circuit has a
speaker, so we are able to hear "Clicks" as we move the circuit closer to
the wire loop that is connected to the signal generator.
The "Clicks" are soft when the circuit is far away from the wire loop, and
gets louder as the circuit is moved closer.
We have tried using the COUNT command to calculate the frequency, and also
tried using the RCTIME command. The frequency jumps all around the place.
We don't know the actual frequency that the signal generator is putting
through the wire loop - and placing a finger near one of the capacitors in
the circuit picks up on a radio station. There is always noise through the
speaker. I have a Tone Decoder ( but as I mentioned, we don't know the
frequency ).
When I tried the RCTIME, I put a .1 uf capacitor to +5 in series with a 5k
resistor going to ground. I had a 220 ohm resistor going from the stamp to
the midpoint junction of the capacitor and the resistor.
Does anyone have any suggestions as to how we can have the BS2 to know that
the circuit is getting close to the wire loop ?
frequency ).
www.friendlyrobotics.com . I installed the Robomower perimeter wire
around my yard 2 weeks ago, and the mower works like a charm. I haven't
checked out the wire's signal characteristics, but the separate control
box must be on before the mower will move at all, and the mower doesn't
cross the wire. Pretty exciting the first time it stopped 6 inches from
the edge of the pool. [noparse]:)[/noparse]
Dennis
Original Message
From: Bryan Smith [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ibYtpWFSrsPo2CQkMK_IrOcvUCA-P_wdW7gF6IDqDbxz1YpvJvvyNIx82p8eseFiF3zjHAos2wZHaeA]bsmith@w...[/url
Sent: Thursday, March 20, 2003 12:27 PM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Buried Fence Detector
He never installed it, and it has been in his garage for the past few
years. We are trying to build a mower-bot with the BS2. I found a
circuit in an old Projects book from Radio Shack that uses an Op-Amp and
a Power-Amp. We built the circuit and connected the input to an
Inductor. The circuit has a speaker, so we are able to hear "Clicks" as
we move the circuit closer to the wire loop that is connected to the
signal generator. The "Clicks" are soft when the circuit is far away
from the wire loop, and gets louder as the circuit is moved closer.
also tried using the RCTIME command. The frequency jumps all around the
place. We don't know the actual frequency that the signal generator is
putting through the wire loop - and placing a finger near one of the
capacitors in the circuit picks up on a radio station. There is always
noise through the speaker. I have a Tone Decoder ( but as I mentioned,
we don't know the frequency ).
5k resistor going to ground. I had a 220 ohm resistor going from the
stamp to the midpoint junction of the capacitor and the resistor.
that the circuit is getting close to the wire loop ?
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject
and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
bsmith@w... writes:
> a
> frequency ).
Just curious if you figured out a way to detect the loop?
Tim
Neither of of are very good on the electronics side of things, but we have
An Inductor and Capacitor in series that feeds into an Op-Amp that feeds
Into a Power-Amp. We think the frequency of the dog fence is 10 kHz, but
We are not for sure. We have setup another circuit using a 567 tone
decoder.
We are hoping to use it to hone in on the signal and ignore the radio
reception.
We have experimented with a 555 to generate a 1 kHz signal and feed that
into the
567 tone decoder. The output of the tone decoder, we sent to our BS2 and
made use
Of the COUNT command; and read the value of IN1. We then placed a POT on
the 555
and varied the frequency. The IN1 goes hi/low depending on the frequency.
We are getting a range of maybe 8 inches so far. Using a speaker, we can
hear the
Signal up to 3 feet away We want to detect the fence up to 2 feet.
Our detector circuit as I said before has an Inductor and a Capacitor that
forms
A filter. If we knew for sure the frequency of the wire fence - maybe we
could
Get better performance out of the circuit.
Original Message
From: Trkeenan@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=r9FX3BBtrDAACevSc112oH01ZI5dBaCB0KaQr5Pypbpvfeh2V3AlViDlitBXFQemwFtkrGvf5QE]Trkeenan@a...[/url
Sent: Tuesday, April 08, 2003 5:53 AM
Subject: Re: [noparse][[/noparse]basicstamps] Buried Fence Detector
In a message dated 3/20/03 2:29:34 PM Mountain Daylight Time,
bsmith@w... writes:
> yard. He never installed it, and it has been in his garage for the
> past few years. We are trying to build a mower-bot with the BS2. I
> found a circuit in an old Projects book from Radio Shack that uses an
> Op-Amp and a Power-Amp. We built the circuit and connected the input
> to an Inductor. The circuit has a speaker, so we are able to hear
> "Clicks" as we move the circuit closer to the wire loop that is
> connected to the signal generator. The "Clicks" are soft when the
> circuit is far away from the wire loop, and gets louder as the circuit
> is moved closer.
> the place. We don't know the actual frequency that the signal
> generator is putting through the wire loop - and placing a finger near
> one of the capacitors in the circuit picks up on a radio station.
> There is always noise through the speaker. I have a Tone Decoder (
> but as I mentioned, we don't know the frequency ).
> a 5k resistor going to ground. I had a 220 ohm resistor going from
> the stamp to the midpoint junction of the capacitor and the resistor.
Tim
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
ballpark range for your own fence brand, whatever it is.
I too am extremly interested in this topic. I have tried going to the Mux
lawnmower website many times in the past, and either cannot get on the site,
or the english documents are corrupted, or not even there. Maybe you could
just buy another dog collar on ebay for your fence, and hack the collar. I
was thinking of doing that since my electronic skills are not the best
either. Of course the price factor is always an issue, for me as well. My
Dog collars are potted, but I was hoping I could get at the circut somehow.
Another idea I had was using an external microphone pickup near the collar.
I could listen for the beep tone the collar makes as it is in the detection
mode.
Please keep us informed of your progress.
-Kerry
At 09:27 AM 4/8/03 -0500, you wrote:
>Yes, we can detect it. I have several Radio Shack project books by Mims.
>decoder.
>reception.
>into the
>made use
>the 555
>hear the
>forms
>could
Original Message
>From: Trkeenan@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eWjrIoZdTHUfD_FWN81ZaNPQiBYEeOnskZxWruj3nqJeWpYY8sPD0Qvd00Kc2hVKkzra7MKGRA_2DQ]Trkeenan@a...[/url
>bsmith@w... writes:
>> is moved closer.
>Tim
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
He gives schematics of his buried wire sensors. We will keep you posted as
to our progress.
Original Message
From: Kerry Barlow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W7nZR_QApdAc4KvaMEdiWGigL5N_Z20NCe0M5KIp7JzHGkKxgVf7FAOfyUGiiKFrHzE_ICw_hc8]admin@m...[/url
Sent: Tuesday, April 08, 2003 10:08 AM
Subject: RE: [noparse][[/noparse]basicstamps] Buried Fence Detector
The Petsafe brand radio fence uses a 10.65KHz signal. This may give you a
ballpark range for your own fence brand, whatever it is. I too am extremly
interested in this topic. I have tried going to the Mux lawnmower website
many times in the past, and either cannot get on the site, or the english
documents are corrupted, or not even there. Maybe you could just buy another
dog collar on ebay for your fence, and hack the collar. I was thinking of
doing that since my electronic skills are not the best either. Of course the
price factor is always an issue, for me as well. My Dog collars are potted,
but I was hoping I could get at the circut somehow. Another idea I had was
using an external microphone pickup near the collar. I could listen for the
beep tone the collar makes as it is in the detection mode. Please keep us
informed of your progress. -Kerry
>Mims. Neither of of are very good on the electronics side of things,
>but we have An Inductor and Capacitor in series that feeds into an
>Op-Amp that feeds Into a Power-Amp. We think the frequency of the dog
>fence is 10 kHz, but We are not for sure. We have setup another
>circuit using a 567 tone decoder. We are hoping to use it to hone in on
>the signal and ignore the radio reception.
>that into the 567 tone decoder. The output of the tone decoder, we
>sent to our BS2 and made use
>the 555
>can hear the Signal up to 3 feet away We want to detect the fence up
>to 2 feet.
>that forms A filter. If we knew for sure the frequency of the wire
>fence - maybe we could
Original Message
>From: Trkeenan@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jRmpffyWP7quo9CmzZed3S2SU9XaA6v87jR3NJOgvIwm3aVSwhYIS7W46pnzp0eLmYKZETVGXjYD6Q]Trkeenan@a...[/url
>bsmith@w... writes:
>> is moved closer.
>> know
>Tim
>and
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1575
