File Merging with BS2sx
Here it goes -- I am working on my Thesis in Computer Engineering,
and I've encountered some limitations with the Basic Stamp 2sx.
If any of you can get this I will be very impressed:
My program is too big for one slot, so I have decided to break it up
into multiple files. One is the 'main' loop - containing all 'IF ...
THEN function1' type statements. The other files contain the
functions. The problem is that I cannot get the if statements to
goto functions in the other files.
I have already done the linking in the header, and it works fine, but
they will not call each other directly.
The error is as follows...
"Error...undefined label"
Thank you in advance for your response. I'll check back often to see
if there are any questions about it.
Thanks again,
Tulane University
New Orleans, LA
Thanks again,
Tulane University
New Orleans, LA
to another bank you have to "Run" it and the program starts at the
beginning in that bank. Of course, you can vector to somewhere in the
bank using a variable. Then the return is also problematic because you
have to run back to the original bank.
Peter Verkaik was nice enough to contribute a lot of work he did on this
a while back to the unofficial Basic Stamp FAQ:
http://www.wd5gnr.com/stampfaq.htm?qframe=1&faq=1&article=60
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
Original Message
> From: MBW [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lmGb2hMi9cP4A0nuIGBBWZHuRWDBZNrkRq3X4SoQ2N7V0aQfqF-AJIMOzDuVOM-MRnxUy08aQo9aRkGIzw]walker@e...[/url
> Sent: Thursday, April 03, 2003 5:31 PM
> To: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] File Merging with BS2sx
> Thanks again,
> Mike
> Tulane University
> New Orleans, LA
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
(functions) based on these flags once you get to the other slot.
Original Message
Go to our web site and download my Nuts & Volts article #87 on multi-bank
programmer. Download the code too. It shows how to call external [noparse][[/noparse]in
another slot] subroutines from a main program using the scratchpad RAM to
pass data back and forth.
-- Jon Williams
-- Parallax
In a message dated 4/3/2003 5:33:19 PM Central Standard Time,
walker@e... writes:
> Thanks again,
> Mike
> Tulane University
> New Orleans, LA
http://www.emesys.com/BS2SX.htm#Crossbank
- Tracy
literature that you suggested.
I'm sad to say that it didn't help solve the problem. I'll try to
explain it further if you have the time...
Ok, I have a series of 6 light emitting and detecting diodes that
are being sent as inputs [noparse][[/noparse]IN0 -> IN5] to the stamp. The entire
memory of the first file is taken up with IF...THEN statements
depending on the reading of those diodes. There is no room for
subroutines in this file (maybe one or two short ones {consisting of
just a few instructions} if absolutely necessary.
Depending on the inputs, the machine should respond respectively by
outputing a code to pins 6-10 [noparse][[/noparse]OUT6 -> OUT10] and manipulating the
appropriate varaibles and such.
The problem is that all of the subroutines are called from the main
loop, and unless they can be put into another file, the main file
must have all of the subroutines in it. Does this make sense?
Thank you guys again,
Mike.
up
all 'IF ...
but
see
> Thanks again,
> Mike
> Tulane University
> New Orleans, LA
coding problem that could be made more efficient with something like a state
machine.
I've written some pretty big programs with lots of subroutines and only run
out of memory in once.
Original Message
From: MBW [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PWwTkJ21L41JLwelRVMMJeIMo-OmgT777j5ugG4m-APW7KeAPN5yGz_XqSEre5sarF6xWRMXoY08ZF5t]walker@e...[/url
Sent: Saturday, April 05, 2003 1:21 PM
Subject: [noparse][[/noparse]basicstamps] Re: File Merging with BS2sx
Thank you all very much. It has taken me a day to go over all of the
Mike.
up
all 'IF ...
but
see
> Thanks again,
> Mike
> Tulane University
> New Orleans, LA
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Original Message
| If 6 sensors takes up all your code in a segment I'm betting you have a
state
| machine.
run
Same here...
Even with very inefficient coding, I've only run out of code space once, and
that was with 5 separate lookup tables and a fairly complex user interface
with lots of Debugs. This was for a very complex project with 5 sensors, an
LED display, autonomous decision making, and an interface to a data radio.
possibilities of if statements which would be too much to jsut post
here) but one can easily see how I'm running out of space. I
realize that it is probably something that I am programming wrong.
Thank you again.
Mike.
'{$STAMP BS2sx}
DIRS = %1111111111000000
svo con 0
sync con 255
pos var byte
n24n con $43FD
emergencyr VAR BIT
emergencyl VAR BIT
emergencyrr VAR BIT
emergencyll VAR BIT
sensor0 VAR BIT
sensor1 VAR BIT
sensor2 VAR BIT
sensor3 VAR BIT
sensor4 VAR BIT
sensor5 VAR BIT
right VAR BIT
left VAR BIT
inter VAR BIT
image43 VAR BIT
image32 VAR BIT
image02 VAR BIT
emergencyr = 0
emergencyl = 0
emergencyrr = 0
emergencyll = 0
sensors VAR BYTE
sensor0 = 0
sensor1 = 0
sensor2 = 0
sensor3 = 0
sensor4 = 0
sensor5 = 0
right = 0
left = 0
inter = 0
image43 = 0
image32 = 0
image02 = 0
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 0
OUT15 = 0
pos = 130
serout 6,n24n,[noparse][[/noparse]sync,svo,pos]
PAUSE 2000
'OUT8 = 0
'OUT9 = 0
'OUT10 = 0
'OUT11 = 0
'OUT12 = 1
'OUT13 = 0
'OUT14 = 1
'OUT15 = 0
main:
sensors.BIT0 = IN0
sensors.BIT1 = IN1
sensors.BIT2 = IN2
sensors.BIT3 = IN3
sensors.BIT4 = IN4
sensors.BIT5 = IN5
if (sensors = %00111111 AND emergencyr = 0 AND emergencyl = 0 AND
emergencyrr = 0 AND emergencyll = 0) THEN goforward
if (sensors = %00111110) THEN turnlefte
if (sensors = %00111101 AND (emergencyl = 1 OR emergencyll = 1)) THEN
turnlefte
if (sensors = %00111011) THEN turnleft
if (sensors = %00110111) THEN goforward
if (sensors = %00101111) THEN turnright
if (sensors = %00011111) THEN turnrighte
if (sensors = %00111111 AND emergencyr = 1) THEN turnrighte
if (sensors = %00111111 AND emergencyl = 1) THEN turnlefte
if (sensors = %00111111 AND emergencyrr = 1) THEN turnright
if (sensors = %00111111 AND emergencyll = 1) THEN turnleft
if (sensors = %00000000) THEN stop1
'Images
if (sensors = %00010111 AND sensor3 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00001111 AND sensor5 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00101011 AND sensor2 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00110011 AND sensor2 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00110101 AND sensor1 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00111010 AND sensor0 = 1 AND left = 0 AND right = 0)
THEN image02f
if (sensors = %00111001 AND image02 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00110000 AND image02 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00100111 AND sensor4 = 1 AND left = 0 AND right = 0)
THEN image43f
if (sensors = %00100001 AND image43 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00000011 AND image43 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00110011 AND sensor3 = 1 AND left = 0 AND right = 0)
THEN image32f
if (sensors = %00110001 AND image32 = 1 AND left = 0 AND right = 0)
THEN leftimage
if (sensors = %00100011 AND image32 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00110101 AND sensor3 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00111001 AND sensor1 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00101011 AND sensor4 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00010111 AND sensor5 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00111010 AND sensor2 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00111100 AND sensor1 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00111100 AND sensor0 = 1 AND left = 0 AND right = 0)
THEN rightimage
if (sensors = %00001111 AND right = 1) THEN goright
if (sensors = %00010111 AND right = 1) THEN goright
if (sensors = %00011011 AND right = 1) THEN goright
if (sensors = %00011101 AND right = 1) THEN goright
if (sensors = %00011110 AND right = 1) THEN goright
if (sensors = %00100111 AND right = 1) THEN goright
if (sensors = %00101011 AND right = 1) THEN goright
if (sensors = %00101100 AND right = 1) THEN goright
if (sensors = %00101110 AND right = 1) THEN goright
if (sensors = %00110011 AND right = 1) THEN goright
if (sensors = %00110101 AND right = 1) THEN goright
if (sensors = %00110110 AND right = 1) THEN goright
if (sensors = %00111001 AND right = 1) THEN goright
if (sensors = %00111010 AND right = 1) THEN goright
if (sensors = %00111100 AND right = 1) THEN goright
if (sensors = %00001111 AND left = 1) THEN goleft
if (sensors = %00010111 AND left = 1) THEN goleft
if (sensors = %00011011 AND left = 1) THEN goleft
if (sensors = %00011101 AND left = 1) THEN goleft
if (sensors = %00011110 AND left = 1) THEN goleft
if (sensors = %00100111 AND left = 1) THEN goleft
if (sensors = %00101011 AND left = 1) THEN goleft
if (sensors = %00101100 AND left = 1) THEN goleft
if (sensors = %00101110 AND left = 1) THEN goleft
if (sensors = %00110011 AND left = 1) THEN goleft
if (sensors = %00110101 AND left = 1) THEN goleft
if (sensors = %00110110 AND left = 1) THEN goleft
if (sensors = %00111001 AND left = 1) THEN goleft
if (sensors = %00111010 AND left = 1) THEN goleft
if (sensors = %00111100 AND left = 1) THEN goleft
goto main
goright:
pos = 70
pause 600
goto main
goleft:
pos = 150
pause 600
goto main
image02f:
image02 = 1
goto main
image32f:
image32 = 1
goto main
image43f:
image43 = 1
goto main
stop1:
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 0
OUT15 = 0
pos = 130
emergencyr = 0
emergencyl = 0
emergencyrr = 0
emergencyll = 0
goto main
goforward:
'was 130
pos =130
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 1
OUT13 = 0
OUT14 = 1
OUT15 = 0
emergencyr = 0
emergencyrr = 0
emergencyl = 0
emergencyll = 0
sensor0 = 0
sensor1 = 0
sensor2 = 0
sensor3 = 1
sensor4 = 0
sensor5 = 0
if (inter = 1) THEN resetinter
goto main
resetinter:
right = 0
left = 0
inter = 0
goto main
turnleft:
'was on 150
pos = 150
OUT8 = 1
OUT9 = 0
OUT10 = 1
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 1
OUT15 = 0
sensor0 = 0
sensor1 = 0
sensor2 = 1
sensor3 = 0
sensor4 = 0
sensor5 = 0
emergencyl = 0
emergencyll = 1
goto main
turnlefte:
'was 177
pos = 190
OUT8 = 1
OUT9 = 0
OUT10 = 1
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 1
OUT15 = 0
emergencyl = 1
emergencyll = 0
if (IN1 = 0) THEN setsensor1
if (IN0 = 0) THEN setsensor0
goto main
turnright:
'was on 60
pos = 70
OUT8 = 1
OUT9 = 0
OUT10 = 1
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 1
OUT15 = 0
sensor0 = 0
sensor1 = 0
sensor2 = 0
sensor3 = 0
sensor4 = 1
sensor5 = 0
emergencyrr = 1
emergencyr = 0
goto main
turnrighte:
'was 30
pos = 50
OUT8 = 1
OUT9 = 0
OUT10 = 1
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 1
OUT15 = 0
sensor0 = 0
sensor1 = 0
sensor2 = 0
sensor3 = 0
sensor4 = 0
sensor5 = 1
emergencyr = 1
emergencyrr = 0
goto main
rightimage:
right = 1
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 0
OUT15 = 1
image43 = 0
image32 = 0
image02 = 0
pause 2000
goto main
leftimage:
left = 0
pause 500
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 0
OUT15 = 0
image43 = 0
image32 = 0
image02 = 0
pause 2000
goto main
setsensor1:
sensor0 = 0
sensor1 = 1
sensor2 = 0
sensor3 = 0
sensor4 = 0
sensor5 = 0
goto main
setsensor0:
sensor0 = 1
sensor1 = 0
sensor2 = 0
sensor3 = 0
sensor4 = 0
sensor5 = 0
goto main
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> Please post your code
going to list a couple.
Your version:
sensor0 VAR BIT
sensor1 VAR BIT
sensor2 VAR BIT
sensor3 VAR BIT
sensor4 VAR BIT
sensor5 VAR BIT
.. then later:
sensor0 = 0
sensor1 = 0
sensor2 = 0
sensor3 = 0
sensor4 = 0
sensor5 = 0
Here's a way to save code:
sensFlags VAR Byte
sensor0 VAR sensFlags.Bit0
sensor1 VAR sensFlags.Bit1
sensor2 VAR sensFlags.Bit2
sensor3 VAR sensFlags.Bit3
sensor4 VAR sensFlags.Bit4
sensor5 VAR sensFlags.Bit5
.. then you can do this:
sensFlags = 0
In another case you're address all of the bits of OutH like this:
OUT8 = 0
OUT9 = 0
OUT10 = 0
OUT11 = 0
OUT12 = 0
OUT13 = 0
OUT14 = 0
OUT15 = 0
When you could have done this:
OutH = %00000000
What I will STRONGLY recommend is picking up the April issue of Nuts & Volts
magazine and read my column "Stamp Applications." The article this month is
called "Thinking Like an Embedded Programmer" -- it specifically goes into
memory manipulation and conservation tricks.
-- Jon Williams
-- Parallax
In a message dated 4/7/2003 5:51:50 PM Central Standard Time,
walker@e... writes:
> OK, this is one without every single case (there are about 500
Original Message
Well, I'm not sure how helpful I can be, but here goes...
First off, try using the new Select...Case statement. I'm not sure if this
will reduce actual size-on-chip, but it will at least make your code more
compact and more readable.
Secondly, you might try having an If-Then section for each sensor with a
subsumption architecture. For example:
If Sensor = On Then Take_Action
where Take_Action is turn left, right, or whatever. Then, have a segment to
analyze the results of each of these If-Then statements and determine which
are the highest priority to determine which action will actually be taken
for a given sensor input.
More specifically, if you have a bump sensor and a GPS on your robot, your
bump sensor could say "go backwards" while your GPS is saying "full speed
ahead, Captain." You would want to give the bump sensor priority, and the
ultimate action taken would be "go backwards."
The problem with your present code as I see it is that you try to decide
what to do for each possible combination of sensors. You should either give
certain sensors priority, or find a way of merging the results of each
sensor input to make the decision making much simpler. For instance, if you
have a ring of ten IR sensors, you would simply determine which set of
sensors indicate an object is present (say, right side sensors, left side
sensors, etc.) rather than saying,
If Sensor_Input = %0000000001 Then Take_Action1
If Sensor_Input = %0000000011 Then Take_Action2
If Sensor_Input = %0000000111 Then Take_Action3
If you had ten sensors you would have 2^10 If...Then statements (or is it
10^2? I never can remember [noparse]:o[/noparse]) ).
Sorry if this is not applicable in your particular case... if so, I guess
you're SOL, unless Dr. Allen can light the way.
- Robert
sensor:
'--- read sensors
GOSUB Read_Right_IR 'get the distance from the right I/R sensor
GOSUB Read_Left_IR 'get the distance from the left I/R sensor
GOSUB Ping_Ultrasonic 'get the distance from the ultrasonic sensor
'--- react to sensor readings
Sensor_Status = 0 'reset the sensor status
IF R_IR_Distance > R_IR_Threshold THEN Sensor_Status.BIT0 = 1 'if the
right I/R sensor reading is greater than the threshold
'set the right status flag
IF L_IR_Distance > L_IR_Threshold THEN Sensor_Status.BIT1 = 1 'if the
left I/R sensor reading is greater than the threshold
'set the left status flag
IF US_Distance > US_Threshold THEN Sensor_Status.Bit2 = 1 'if the
ultrasonic sensor reading is greater than the
'threshold set the ultrasonic status flag
SELECT Sensor_Status 'process the sensor status flags
CASE 0 'do this when no sensors triggered
'DEBUG "No Sensors Triggered",CR
CASE 1 'do this when right sensor triggered
'DEBUG "Right Sensor Triggered",CR
CASE 2 'do this when front sensor triggered
'DEBUG "Left (Forward) Sensor Triggered",CR
CASE 3 'do this when both sensors triggered
'DEBUG "Left (Forward) & Right Sensor Triggered",CR
CASE 4
'DEBUG "Ultrasonic sensor out of range",CR
CASE ELSE
DEBUG "Illegal sensor readings",CR 'otherwise don't do anything
ENDSELECT
Original Message
to
which
give
you
