DS1305 Help
Hello again.
I'm using a dallas semicondoctor DS1305 Real Time Clock within a
project that I am working on and I am trying to get the backup system
to work. The main question I have is this. When the DS1305 loses
primary power and switches to backup, is the oscillator supposed to
keep running?
I am using a super cap which I know is charging properly. I have set
the trickle charge register and confirmed its value. I also know
that in order for the oscillator to operate, the oscillator enable
bit must be reset (0) in the control register. After doing some
tests, I have found that the DS1305 will keep timing, as expected, if
I remove power to the DS1305 only, BS2 still has power. If I remove
power from the entire system (BS2 and DS1305), as would be expected
in a power outage, the DS1305 retains its memory but stops
incrementing the time. Unfortunately, I can't reinitialize the
oscillator once the DS1305 has switched to backup power.
I know that Parallax has a AppKit which uses the DS1302, I have
referenced that but no help there. The DS1305 is almost identical to
the DS1302 other than more onboard RAM, two alarms, and the
addressing is different. However, as far as I can tell, the trickle
charge system is identical.
I know this is a lot to read through but any assistance anyone gives
will be much appreciated. Also, doesn't it seem pointless to have a
backup on a RTC that doesn't keep the correct time if power fails.
This is my cause of confusion.
Help Please
Kevin
keep running?
Help Please
Kevin
and yes, the timing oscillator keeps running
even when main power is down. I havn't used
a SuperCap yet, so can't address how long one
should run. The Timer should keep running
as long as VCC1 is greater than 2 volts.
(assuming you've put a 32.768 Khz crystal
across pins 2 and 3)
'Main' power (same as stamp) should go into
VCC2 (pin 1), while backup power goes into
VCC1 (pin 8) -- which is also the charge out pin.
"When VCC2 is greater than VCC1 + .02V, VCC2 will
power the 1302. When VCC2 is less than VCC1,
VCC1 will power the 1302".
I thought the oscillator stop bit was ONLY
for a low-power (100 nA) mode -- usually I set
it to 0 (RUN clock) and leave it alone.
The 1305 sounds interesting -- I wanted a timer
driver interrupt for another project, this could
help.
--- In basicstamps@yahoogroups.com, "nofinger22" <nofinger22@y...>
wrote:
> Hello again.
system
> keep running?
set
if
remove
to
trickle
gives
a
> Help Please
> Kevin
that the 1302 has 40 KOhm pull-downs on its
SPI pins -- the 1305 looks like not.
Perhaps you need pull-downs to insure the
SPI pins stay inactive when you power off
the Stamp? (Data, Clock, ChipSelect)
better beings it shouldn't ever have to be replaced, unlike the lithium
cell. I may have to try it with the lithium cell. The DS1305 uses three
different power pins, one for primary, one for trickle charged backup, and a
third specifically for a non-rechargable battery.
Like you, I had planned, and still planning, on enabling the oscillator and
then leaving it alone. I was just trying a few things to see if I could
keep the oscillator running after RTC lost primary power.
What has me baffled is the fact that the oscillator continues running
normally without primary power if the BS2 has power and is still connected
to the RTC. Remove power from the BS2 and the RTC stops keeping time. I
have checked voltages on the RTC, while the unit is running off of backup
power and the BS2 has power to see if somehow the RTC is getting supply
voltage from the BS2 but I can't find anything.
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Friday, March 28, 2003 9:59 AM
Subject: [noparse][[/noparse]basicstamps] Re: DS1305 Help
> Hmm! I used the 1302 with a 3 volt coin cell,
> help.
> wrote:
> > Hello again.
> system
> > keep running?
> set
> if
> remove
> to
> trickle
> gives
> a
> > Help Please
> > Kevin
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
your saying put a 40Kohm resistor from the I/O pins to ground.
Original Message
Sent: Friday, March 28, 2003 10:51 AM
> Just looked at the 1305 datasheet -- noticed
The Clock Pin, the Data Pin, and the Chip Select Pin.
3 resistors total. (maybe 4, if you have separate
DataOut and DataIn pins)
--- In basicstamps@yahoogroups.com, "Kevin Novinger"
<nofinger22@y...> wrote:
> I see that too. I will give that a try and let you know. Just to
clarify,
Original Message
> From: "Allan Lane" <allan.lane@h...>
Subject and
