Stamp Editor V2.0 Beta 1
This is not a serious issue, but I am primarily running the Basic
Stamp Editor version 2.0 Beta 1 on a Windows Me machine and I noticed
that the Memory Map window does not display correctly. It wasn't
until I ran the same version on a 98 and even a 95 machine that I
realized that the Me machine was not display the window correctly.
I am curious to know if anyone else has noticed this or if maybe
something just didn't install correctly. I have checked display
settings on all machines thinking that may have something to do with
it, but no. I know that this is a Beta version so I'm not
complaining, but at the same time, this is a Beta version so there
may be some minor bugs.
Any suggestions are appreciated.
Kevin
Kevin
I run the Stamp Editor V2 Beta 1 on a Windows ME machine at 800*600
16 bit color.
The Memory map window seems correct.
What problem do you have?
Regards
ECO
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Thursday, March 27, 2003 5:32 AM
Subject: [noparse][[/noparse]basicstamps] Stamp Editor V2.0 Beta 1
> Thanks,
> Kevin
The problem with mine is, one, the condensed EEPROM map is cut in half
vertically, two, EEPROM addresses are being clipped, and three, the RAM
addresses are being clipped. I may just try reinstalling. Thanks for the
suggestion.
Kevin
Original Message
Sent: Thursday, March 27, 2003 3:13 AM
Subject: Re: [noparse][[/noparse]basicstamps] Stamp Editor V2.0 Beta 1
> Kevin
> 16 bit color.
> Regards
> ECO
Original Message
> From: "nofinger22" <nofinger22@y...>
> > Thanks,
> > Kevin
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
formatted to work with small fonts only. Once I changed that everything
displays fine.
Original Message
Sent: Thursday, March 27, 2003 7:59 PM
> After your message I tried mine at 800x600 16bit color but no difference.
> suggestion.
> Kevin
Original Message
> From: "Eco" <ecourt@b...>
> > Kevin
> > 16 bit color.
> > Regards
> > ECO
Original Message
> > > Thanks,
> > > Kevin
and
