R/C channel mixing
Classic R/C channel mixing. I need to mix two R/C channels, just as
is used in v-tail mixing.
Here's my problem, I have 3 R/C channels coming into my stamp. I
have a fourth controlling where those channels go. I've figured this
out. However, I am almost out of I/O pins, and I also don't want to
have to buy a R/C channel mixer. If I can mix two of the channels,
it solves alot of my problems.
Thanks in advance, Jim
I have two R/C channels that I want to mix together. Classically,
this idea is used airplanes, but I have hopes of using it in a two
wheeled robot.
I was hoping someone out ther would have the math behind such a
problem. Maybe even source code... I have the hardware now I need
the software.
Thanks, Jim
wheeled robot.
the software.
Thanks, Jim
>I was hoping to get some help with a servo problem I have.
>wheeled robot.
>the software.
>Thanks, Jim
Depends on how you want to mix the channels... i.e. A mathematical
relationship, a lookup table, etc.
Basically you read in BOTH (or more) channels with the PULSIN command.
(typical range is 1ms -2ms)
Perform your DSP (Digital Signal Processing)
output the result using the PULSOUT command.
Using a lookup table the relational output can be almost endless
x - servo CH1
y - servo CH2
o - servo combined output
Example1:
y o
y o
y o
y o
y o
y o
y o
y o
y o
y o
x x x x x x x x x x
Example2:
y o
y o
y o
y o
y o
y o
y o
y o
y o
y o
x x x x x x x x x x
Example3:
y o
y o
y o
y o
y o
y o
y o
y o
y o
y o
x x x x x x x x x x
--- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
> >wheeled robot.
> >the software.
> >Thanks, Jim
command.
> x - servo CH1
> y - servo CH2
> Example1:
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> x x x x x x x x x x
> Example2:
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> x x x x x x x x x x
> Example3:
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> y o
> x x x x x x x x x x
Eudora:
Tools-->Options-->Fonts-->Message-->Fixed-width = Fixedsys
Use proportional font by default =
unchecked
Otherwise just cut-n-paste into NotePad...
>How sad, your beautiful spacing was removed by the group presenter...
> > >wheeled robot.
> > >the software.
> > >Thanks, Jim
>command.
> > x - servo CH1
> > y - servo CH2
> > Example1:
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > x x x x x x x x x x
> > Example2:
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > x x x x x x x x x x
> > Example3:
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > y o
> > x x x x x x x x x x
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> wheeled robot.
> the software.
> Thanks, Jim
This depends on which end of the RC device you want to add the Mixing.
I am mixing the Collective and the Throttle for a Helicopter. In
Moving the collective Joystick the Throttle will track above the
Collective.
High 14 'Force +5 volts on Pin 14
RCTIME 14,1,Collective 'Pot is 5000 ohm
PotOut = (Collective */ 2500) - 200 'Store it in PotOut For Serial
Servo = "1" 'Servo 1
Gosub Display
High 13 'Force +5 volts on Pin 13
RCTIME 13,1,Throttle 'Pot is 10000 ohm
Throttle = (Collective */ 2500) + 50 + (Throttle/2) - 310 'Add to
Collective
PotOut = Throttle 'Store it in PotOut For Serial
Servo = "2" 'Servo 2
Gosub Display 'Send Throttle Information
Hope this helps.
Ken Smith
> wheeled robot.
> the software.
> Thanks, Jim
Alright, I may have figured it out, but can somebody look at this so
my robot doesn't get up and kill me?
'Channel1, Channel2 are outputs
'Accel and Turn are the readings from Rx. - 1100 (Center)
Channel1 = Accel - Turn / 2
Channel2 = Accel + Turn / 2
Does this make sense? Is it going to go insane and lose control? Is
this possibly my last post because my robot has killed me?
