Reading a self clocking synchronous IO Device
What would be the best way to read data from a 3 wire synchronous serial
device? Preferably I would like to watch 16 devices with a 32 port BS2p
40. ShiftIn unfortunately has the basic stamp doing the clocking. I
need the basic stamp to listen to the clock and read the data wire when
it receives a clock. Any help would be great!!
Josh
Josh
You would write a '1' bit into the first chip, to use
as a 'divide by 8' signal. You would use the second
595 as a shift register on the 3-wire synch line.
Shift both 595's with the same clock.
When the '1' bit comes out of the first 595, use
that signal to latch the second chip's data.
Monitor that pin with the Stamp, and when it goes
low, read the 8-bits in parallel from the second
595.
This will only monitor a single data line -- a second
data line requires another '595. This is a mostly
hardware solution -- because I don't think the
Stamp has anything built in to do this.
--- In basicstamps@yahoogroups.com, "Joshua Perry" <jperry@1...>
serial
BS2p
I
when
> Josh
'POLLWAIT' feature set:
PollClockPin CON 0
PollDataPin CON 1
PollVar VAR BYTE
NumBits VAR BYTE
POLLIN PollClockPin, 1 ' Look for a high
POLLMODE 2 ' Mode 2 means use a PollWait
MAIN:
PollVar = 0: NumBits = 0
Loop:
PollVar = PollVar << 1
POLLWAIT 8 ' Wait for clock high (mid-bit)
' Response time < 160 uS (Page 235)
PollVar.Bit1 = PollDataPin
NumBits = NumBits + 1
IF NumBits < 8 THEN Loop
' ELSE
' Save data in PollVar, or do whatever...
GOTO MAIN ' Get the next byte...
I don't know how fast this will work -- the
circuit I described earlier will give you
more time to get the data.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> You could use 2 74HCT595 chips.
> 595.
> serial
port
> BS2p
clocking.
> I
wire
> when
> > Josh
great with it. Well it turns out that the hardware I am using isn't clock/data,
its Weigand. Weigand uses 2 data lines that sit high. One line is the 1 line
and the other is the 0 line. When data is sent the 1 or 0 line will pulse low
for 50 us. There is at least a 2 ms pause between each pulse. If the 1 line
pulses it is a high bit in the data string, if the 0 line pulses it is a low bit
in the data string. Obviously the stamp is too slow to pick up a 50us pulse.
So I thought I could change this to a clock/data system.
DATA0
ORGATE
>CLOCK ANDGATE
>DATA
DATA1
|--NOTGATE
Then I can use the CD4031 to stor the data and clock it out with the basic
stamp. Could anyone experienced in hardware design give some input on whether
this would work? If a picture with a waveform would help, just let me know. I
wasn't sure if picture attachments are allowed on the list.
Thanks a ton!
Josh
Original Message
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tUiuktcBo044q6WaL2qdfwzVvPWhqkqVkjJ8eJtTIqQCUjkSNagjCqQDSnaPPnTHF2TvmwyHdwWfShqkeRKxZy2A0bMDsCA]allan.lane@h...[/url
Sent: Wed 3/19/2003 3:19 PM
To: basicstamps@yahoogroups.com
Cc:
Subject: [noparse][[/noparse]basicstamps] Re: Reading a self clocking synchronous IO Device
OK, after more reading, the 2P DOES have a
PollClockPin CON 0
PollDataPin CON 1
PollVar VAR BYTE
NumBits VAR BYTE
MAIN:
Loop:
' ELSE
> 595.
> serial
port
> BS2p
clocking.
> I
wire
> when
> > Josh
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
