[[basicstamps] power-consumption question/issue]
If the 9V is being regulated to 5V with a linear regulator, about half of the
power is being wasted.
"donnmoidaho" <donnmo@l...> wrote:
> I've built a simple circuit on the SuperCarrier board. My power
> source is a 9Volt Alkaline duracell that's attached to the batter-
> receptacle on the board. The circuit is built around the BS2.
> The circuit consists of a single ADC0831CCN chip that monitors an
> input device's voltage. When this voltage increases momentarily from
> 1.27V to 1.99V, I begin a brief transmission over the BS2 serial
> port. (A total of 3 send/receives.)
> The circuit operates as expected with one exception, the 9V battery
> is drained in a few short hours. (When I check the board after
> running overnight, the green LED on the SuperCarrier board is no
> longer lit. In addition, the battery registers 6.8V on a multimeter.)
> I've tried inserting both SLEEP and NAP commands in my code in hopes
> of increasing battery-life; however, these commands appear to be of
> little/no-consequence.
> Does anyone have any tips regarding how I should go about
> troubleshooting the circuit to determine why I'm depleting the
> battery so rapidly? (Also, would I prolong battery life if I
> bypassed the LM2940 on the Super Carrier board? (If memory serves,
> there's a voltage regulator on the BS2 as well...))
> Thanks,
> --Donn
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> Thanks,
> --Donn
2. The LED may be pulling anywhere from 6 to 20 mA, all the time.
You should de-solder it if possible (socket it?).
Parallax people-- it's a resistor-LED, what current?
3. Is there any other load?
--- In basicstamps@yahoogroups.com, Fred Kerr (usa.net) <fkerr@u...>
half of the
from
battery
multimeter.)
hopes
of
serves,
> > Thanks,
> > --Donn
Subject and
