SEROUT and Tri-State Data pin
Allan-
From the _BASIC Stamp Programming Manual Version 1.8_ description:
"Dpin is a variable/constant (0-15) that specifies the I/O pin that
will be connected to the synchronous-serial device's data input.
This pin's I/O direction will be changed to output and will remain
in that state after the instruction is completed."
FWIW, I always insert an INPUT instruction between a SHIFTOUT and
SHIFTIN which target the same pin for this reason.
Steve
On 3 Mar 03 at 17:48, Allan Lane allan.lane@honeywe wrote:
> ...Does anybody know what 'SHIFTOUT' does to its Data pin once the
> command completes?
Steve
> command completes?
I've got them working, no problem.
My concern is that I'm using a 'SHIFTOUT' to command the 1302
followed by an immediate 'SHIFTIN' command to read its response --
and I don't know the state of the 'Data' pin to the DS1302 in between
the two commands.
If the 'SHIFTOUT' leaves its data pin in OUTPUT state, then when the
1302 grabs the pin to drive it for the first data bit back to the BS2
there is a possibility of contention on the pin, at least until the
BS2 'SHIFTIN' turns the 'Data' pin into an input.
I've searched the 2.0c Programming Manual without success. Does
anybody know what 'SHIFTOUT' does to its Data pin once the command
completes?
Thanks in advance, Allan.
>I recently connected my BS2 and a DS1302 Clock chip.
>the two commands.
>completes?
Use a 470 Ohm resistor on the BS2 I/O pin. Worst case scenario you
will only be sinking/sourcing about 10.6mA
Install a resistor (220 to 1000 ohms) between the two pins. That
way, the short period of contention won't matter. SHIFTOUT does
leave the pin an output.
-- Tracy
>the two commands.
>completes?
Thanks to all. I'm amazed Parallax 'simplified' their manual to the
point where it became silent (or ambiguous) on this point. This is
not to flame anyone, I'm very impressed by their products and support.
Original Question:
If you connect a Stamp and a DS1302 Clock chip directly, and use the
SHIFTOUT and SHIFTIN commands to talk to the 1302, isn't there
contention on the Data pin when you want to read something from the
1302?
Answer: Yes, the SHIFTOUT command leaves its Data pin set HIGH, until
the SHIFTIN command executes and turns the Data pin into an input
(around 600 uS). The DS1302 will have been trying to drive the pin
HIGH (no problem), or float it LOW (through an internal 40K ohm
resistor, also no problem) during this time.
A cautious designer will put a 200 to 1000 ohm series resistor in the
data line, to limit the contention current during this time (thanks
Tracy!)
Next Question: Why doesn't the 1302 driver burn out without this
resistor?
Answer: Because the DS1302 protocol was cleverly designed to ALWAYS
have a '1' as the last bit sent for a command. I believe the 1302
data driver WOULD burn out IF the last sent bit was a 0, and the 1302
tried to drive a 1 (result, short circuit). BUT, since this 'never'
happens in normal use, the 1302 is preserved. Caution suggests
putting in the series current limiting resistor just in case.
Thanks all!
>A lesson learned:
>Original Question:
>1302?
>Tracy!)
>resistor?
>Thanks all!
I should point out....."Caution suggests putting in the series current
limiting resistor just in case" ...Unless speed becomes an issue.
You don't have to worry about high speed issues with the BS2 or 1302,
but in other applications it might be something worth considering.
As resistance increases, slew-rate decreases. See attached GIF...
