Do I *need* a socket for putting a stamp in a
Sam-
You don't _need_ a socket. We are talking about a 24-pin module
measuring about 15x30 mm, yes? You need to push the module's pins
into the breadboard so that the module's "belly" rests on the
breadboard's surface. If you're still having trouble describe in
detail your serial cable, how you're connecting it to your Stamp, and
your PC.
Steve
your PC.
Steve
> Sam-
and
> your PC.
> Regards,
> Steve
The module is 15x30mm but the pins thicken near the top (near the
belly) preventing the chip from being inserted as far as you
describe. The pins are very thin at the bottom and get wider near the
chip... I've tried applying a lot of pressure to force the chip into
the breadboard but it doesn't insert. All the pins are correctly
alligned and I've bent them slightly to be at a 90 with the chip
belly.
Have you checked for continuity from the board to all pins? I've never had a
problem using a 24 pin module on a breadboard, done it many times. I have
one in a breadboard on my desk right now, no troubles.
Jonathan
www.madlabs.info
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, March 01, 2003 7:44 PM
Subject: [noparse][[/noparse]basicstamps] Re: Do I *need* a socket for putting a stamp in a
> --- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> > Sam-
> and
> > your PC.
> > Regards,
> > Steve
> belly.
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
that the pin-belly angle was a little less than 90 degrees. Thanks a
lot guys.
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Hi,
never had a
I have
> Jonathan
> www.madlabs.info
Original Message
> From: <hard-on@t...>
in a
wrote:
> > > Sam-
pins
in
Stamp,
> > and
> > > your PC.
> > > Regards,
> > > Steve
the
into
> > belly.
Subject and
