Binary To Decimal Conversion
HELP!
I need to write a program to convert a binary number to a decimal
number and visaversa. It can either be in BASIC or JAVA.
Ultimately, I need to port it to the Javelin (Java Stamp by
Parallax), but I am not that sharp on Java, so I will probably get
it running on my BasicII stamp, first.
Any code ideas using pure math (no special BIN2DEC.EXE routines)
would greatly be appreciated.
Matts Persic
mpersic@p...
Matts Persic
mpersic@p...
alot of info on this.
but basically, its easy to go from dec to bin. just get the value to the
stamp then output it using DEC, HEX, BIN.
variablea var byte
variablea = 137
debug "DEC: ", DEC variablea, CR, "HEX: ", HEX variablea, CR, "BIN: ", BIN
variablea
outputs:
DEC: 137
HEX: 89
BIN: 10001001
-Rob
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, February 26, 2003 4:33 PM
Subject: [noparse][[/noparse]basicstamps] Binary To Decimal Conversion
> HELP!
> Thanks,
> Matts Persic
> mpersic@p...
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
