New Stamp user question
I need to measure 12 pulses that are between 220ms and 470 ms and
output a signal if any of them are not in this range. Can I do this
with the basic stamp modules and which one would you recommend?
function. You could write code and manually fine-tune it to get the accuracy
you need.
-- Jon Williams
-- Parallax
In a message dated 2/17/2003 6:02:05 PM Central Standard Time,
mhutch02@h... writes:
