16 bit number from VB6 to Stamp/
Does anyone have any clues to save me some time in figuring out how to get a
numerical value out of VB6's MSCOMM to a stamp? When using MSCOMM out,
strings seem limited to numerical 255. How can I get a larger number, such
as 36360 into the stamp?
LTNS & TIA,
Chris
LTNS & TIA,
Chris
Original Message
a
I think I can send 8 at a time no problem. >> 8 places will get the high
byte. Just haven't figure out the low byte yet - it may have to be one at a
time. Hmmm....9 bytes for a 16 it word? ther has to be a better way.....Hey,
Doc, are you out there? I'd bet you could do this with your eyes closed...
In the meanwhile, I think I'll put a stamp & LCD on a carrier board an plug
it into my ThinkPad. Maybe Ill get this one figured out....It may be more of
a VB question...
C
> One digit at a time...
Original Message
> out how to get
> a
> MSCOMM out,
> larger number, such
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the
> Subject and Body of the message will be ignored.
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
When you send it serially it sends 8E and 08 (142 and 8 if you look at it in
decimal). In VB you have to re-construct the word by shifting 8E left 4 then
adding 08
You also have to figure out if you're receiving the LSB or MSB first -
wouldn't do to shift the 08 and add 8E.
My 'lectronic Newb site http://members.shaw.ca/pmeloy/
Original Message
To: "Basicstamps Group (E-mail)" <basicstamps@yahoogroups.com>
Sent: Sunday, February 16, 2003 6:43 PM
Subject: [noparse][[/noparse]basicstamps] 16 bit number from VB6 to Stamp/
a
> LTNS & TIA,
> Chris
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
& I was about to shift right 8 to get one byte, then subtract1 and divide by
256. Putting the two bytes back together would do the same, wouldn't it?
> You have to send the number in bytes. 36360 is actually 8E08
> to the stamp.
> you look at it in
> 8E left 4 then
> adding 08
> out how to get
> a
> MSCOMM out,
> larger number, such
> > LTNS & TIA,
> > Chris
> the Subject and
the article (#89 ) at this link:
<A
HREF="http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Download\
s_V3.asp">
http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3.
asp</A>
-- Jon Williams
-- Parallax
In a message dated 2/16/2003 8:44:38 PM Central Standard Time,
chris01@t... writes:
> LTNS &TIA,
> Chris
Thanks. This link is not live any longer - I will check to see if I have the
magazine here.
Do you know if the content of this link has been removed or just moved?
Thanks again, Chris
> I wrote an article for my Nuts & Volts column about doing
> this. You can find
> <A
> uts_Volts_Downloads_V3.asp">
> lts_Downloads_V3.
> asp</A>
> -- Jon Williams
> -- Parallax
magazine here.
Thanks again, Chris
> this. You can find
> <A
> lts_Downloads_V3.
> asp</A>
> -- Jon Williams
> -- Parallax
to word-wrap chopping them off.
V3.asp
http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV89-Data_Exchange
_with_Visual_BASIC.pdf
Original Message
the
> magazine here.
> > this. You can find
> > <A
> > lts_Downloads_V3.
> > asp</A>
>magazine here.
The 2nd link certainly works - I just tried it after fixing up the wrap
problems.
BTW - enclosing links within angle brackets seems to help with the wrap
problems:
<http://www.parallax.com/html_pages/resources/nvcolumns/Nuts_Volts_Downloads_V3.\
asp>
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 19 years of Engineering Innovation (1984 - 2003)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Got a 404 msg from the parallax server - 'file not found' Hmmm....
NTW, though, I found the article in the Sept '02 issue.
Imagine that - ink on paper....still works.
C
select the Resources menu, then click "Nuts & Volts Columns" and then select
Volume 3. You'll find a links to each column and code file.
-- Jon Williams
-- Parallax
In a message dated 2/17/2003 4:03:46 PM Central Standard Time,
> Not for me - no word wrap prob. Even took off the "." at the end of the url.
> Thanks,
> C
VB6 is rejecting characters from your code snippet though.
Particulaly the underscore - debug function says that it is an
'unrecognizable character'..
any further insight? What version of vb did you use?
CL
> Hmmm ... I pasted the link from my browser. Go to the
> Parallax web site,
> and then select
> -- Jon Williams
> -- Parallax
> the end of the url.
> > Thanks,
> > C
serial lines.
-- Jon Williams
In a message dated 2/18/2003 9:00:39 AM Central Standard Time,
> tks, Jon. I have it now.
> CL
