input question
Hi ,
I want a program for bs2 that could check the value of input2 and if in2 = 0
then blink a led , if in2 = 1 then doubleblink a led . How could I do this ?(I
know that I must connect a pullup resistor to P2 but doing this the value of P2
would be high until I press the button connected to ground).
Thanks for your help ,
Thomas
Do You Yahoo!?
Thomas
Do You Yahoo!?
th_sak@y... writes:
> Hi ,
> 0 then blink a led , if in2 = 1 then doubleblink a led . How could I do
> this ?(I know that I must connect a pullup resistor to P2 but doing this
> the value of P2 would be high until I press the button connected to
> ground).
Can you give a little more information...
Do you want both LED's off until some event (like pushing a button)? Please
give a more detailed description. What you want to do is very easy though,
just need more information...
Ken
= 1 I want the led to lit until in2 = 0.
Thanks again ,
Thomas
Do You Yahoo!?
>I want a circuit with a two state button and 1 led.When I press
>the button in2 = 1 I want the led to lit until in2 = 0.
>Thanks again ,
>Thomas
>Thomas -
Unless I'm misunderstanding your requirement, you just need a switch with
maintained contacts, as opposed to momentary ones. The action would be PUSH
ON, PUSH OFF.
Bruce Bates
