Caller ID & Wave files
Does anyone know if the Stamp II is fast enough to RX the phone company caller
ID signal? Also can it generate the original voice signal from a wave file,
with the addition of maybe an D/A converter?
thanks for your input,
Leroy
Leroy
> company caller ID signal?
The Caller ID info is presented via tones over the phone line. A
Stamp could not work fast enough to handle the audio signal
directly. Caller ID chips that decode this info typically provide a
ring detect output and 1200 baud asynch serial output suitable for
SERIN operations. A BS2 is fast enough to keep up with the 1200
baud output and even do a little selective inputting in the process.
Can't help you on this one.
Steve
As I understand it, that's essentially what the Caller ID chips do.
The external decoder circuit would have to work with Bell 202 FSK
where logical 1 = 1200 ± 12 Hz, logical 0 = 2200 ± 22 Hz,
transmission rate = 1200 bps. Caller ID info is provided right
after first ring, so your decoder should look for it then. With the
right interface, it can also all be done with fast uProcessors by
detecting frequencies of signals presented over the phone line. I
wish I could provide more info (schematics, etc.) on how to do that,
but analog gurus will have to take this any further.
Steve
What if we used an external decoder circuit to change the tones you mentioned
to a TTL or CMOS compatible signal? Any possibilities there?
Leroy
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Wednesday, February 12, 2003 12:02 PM
Subject: Re: [noparse][[/noparse]basicstamps] Caller ID & Wave files
: Leroy-
: > Does anyone know if the Stamp II is fast enough to RX the phone
: > company caller ID signal?
: The Caller ID info is presented via tones over the phone line. A
: Stamp could not work fast enough to handle the audio signal
: directly. Caller ID chips that decode this info typically provide a
: ring detect output and 1200 baud asynch serial output suitable for
: SERIN operations. A BS2 is fast enough to keep up with the 1200
: baud output and even do a little selective inputting in the process.
: > Also can it generate the original voice signal from a wave file,
: > with the addition of maybe an D/A converter?
: Can't help you on this one.
: Regards,
: Steve
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
56k ones have it. From there its a simple matter to decode the serial data
stream. Somewhere I have some notes on it -- I'll see if I can find it.
Original Message
converts it to 1200 baud serial which the MCU can read.
Goto http://www.microengineeringlabs.com/products/labxt.htm
Stamp compatible PicBasic Pro sample programs and schematics are provided
that show how to interpret the received caller information string.
Original Message
Sent: Wednesday, February 12, 2003 11:16 AM
Subject: [noparse][[/noparse]basicstamps] Caller ID & Wave files
caller
file,
> Leroy
Thanks so much for your idea!! It's great!!
Does anyone have any idea about how one would Identify a modem as having
caller ID on it? I have a BOCA modem, but have no idea if it has caller ID.
Did a goggle search on it's model number & managed to use up about three
hours.. AS always thanks for your response..
Leroy
Original Message
Sent: Wednesday, February 12, 2003 3:46 PM
: Guys, all you need is an external modem with caller ID -- most of the later
: 56k ones have it. From there its a simple matter to decode the serial data
: stream. Somewhere I have some notes on it -- I'll see if I can find it.
the ones off my Supra 56k external modem:
AT#CID? displays caller ID modes supported.
AT#CID=0 turns caller ID off
AT#CID=1 turns on caller ID -- modem translates data into text
AT#CID=2 turns on caller ID -- modem dumps raw ASCII data
Never did find my notes, but the data stream is fairly easy to translate.
Original Message
ID.
later
data
