Help on running a LCD
hey,
i have a 2x16 LCD screen and a BS2, i have tried to get them to talk
but it appears that they arn't. I'm pretty sure its my code that is
not working, and i don't really understand the initialization
sequence stated in the manuel.
(http://www.jameco.com/Jameco/Products/ProdDS/171715.pdf) Or it might
be the pin connections. Any help would be greatly appreciated.
thanx
-mike
thanx
-mike
BS2:
http://www.lennard.net.nz/electronics/lcd.html
Assuming your LCD is a Parallel LCD?
> From: "laxboy687 <laxboy687@e...>" <laxboy687@e...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Mon, 10 Feb 2003 22:33:20 -0000
> Subject: [noparse][[/noparse]basicstamps] Help on running a LCD
> hey,
> thanx
> -mike
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
> of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
discouraged, just keep trying.
According to the documentation, it looks like it is a parallel display with
a standard contrast adjustment. Not sure about the compatibility with the
Hitachi chip set though. Page 10 of the referenced Jameco document explains
the contrast bias circuit. Nuts & Volts column #31 on the Parallax web site
explains how to use an character-based LCD with a BS2.
http://www.parallax.com/Downloads/Documentation/nv/v1/col/NV31-Demystifying_
Character-based%20LCD's.pdf
Original Message
> This page contains my own notes on getting a HD44780 based LCD to work on
a
> BS2:
-mike
work on a
> BS2:
> > hey,
talk
is
might
> > thanx
> > -mike
Subject and Body
