Help! Hyperterminal stamp modem connectivity problems
I am having problems getting hyperterminal to connect to the stamp
modem. I am using the appmod modem board from parallax with the
Cermetek ch1786 modem. The modem will call hyperterminal.
Hyperterminal will begin the try to connect but no handshake occurs
so I can't send data. I have hyperterminal set to 2400 bps 8 data
bits, no parity, 1 stop bit and no modulation. Any help would be
greatly appreciated!
Jayme
Jayme
This probably requires sending "AT" commands to the PC's modem to get it out
of its normal auto-sense mode.
2. An alternative is to set a long time-out for the connection interval.
When modems connect they go through a sequence of "whistling" exchanges to
find a common speed and analog protocol. When using modern high-speed
modems with older protocols (anything at 2400 baud) this can take a long
time (60+ seconds). I've often seen the connection interval time-out before
this is completed and solved the problem by extending the interval. I think
this setting is in MS Windows control panel modem properties, but my memory
may be fading. By locking the modem to a fixed baud rate with AT commands
you get a faster and more reliable connections.
I did a Google search with "modem at baud rate" and this
http://www.sixnetio.com/html_files/tech_notes/tn606.pdf came to the top of
the list. It seems to be very close to what you need. There is probably
more helpful information farther down the list. These instructions may not
be exactly right for your modem, so you may need to fiddle a bit. You
should be able to find your modem's AT commands on the net, but these
particular commands are fairly consistent across all models.
I like knowing what sorts of things people are doing with Basic Stamps. If
you don't mind sharing, what is your application?
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
Original Message
[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=q2oNUqzI10bE_UjHhEw8JiHJwZs104QvcAfDlnvoXgYVIEdSBwkPk8wwNg1BozWjUjHBBBGgUplBFaU5DkZUcFTv]taunting_pamola@h...[/url
Sent: Saturday, February 08, 2003 9:18 AM
To: basicstamps@yahoogroups.com
Subject: [noparse][[/noparse]basicstamps] Help! Hyperterminal stamp modem connectivity
problems
Jayme
To UNSUBSCRIBE, just send mail to:
basicstamps-unsubscribe@yahoogroups.com
from the same email address that you subscribed. Text in the Subject and
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Thanks,
>Jayme
Hi Jayme,
Be sure you disable error checking and data compression on the
hyperterminal end. Most modern modems leave those advanced features
ON by default, but they always (in my experience) prevent connection
with the Cermetek ch1786. The AT commands are:
AT \N0 %C0 ^M
I have more stuff about my own take on the modem connection posted at
http://www.emesys.com/BS2rs232.htm#modem
-- Tracy
found in the nuts and volts article "calling all stamps"
http://www.parallaxinc.com/Downloads/Documentation/nv/v2/col/NV60-
Calling_All_Stamps.pdf
There are a few minor differences. I am attempting to have the stamp
call a central computer at a set time and send temperature data it
has gathered. This way you can program the stamp when to take data
and sent it back to a central computer. By approaching data gathering
this way you can get the precise data you want at the time you want
without sitting at the central computer.
Jayme
--- In basicstamps@yahoogroups.com, "Al Margolis\(TX\)" <al@b...>
wrote:
> 1. Triple check that both modems are locked for the same
speed/stop/parity.
get it out
interval.
exchanges to
speed
long
out before
interval. I think
my memory
commands
top of
probably
may not
You
these
Stamps. If
Original Message
> From: jaymebirken <taunting_pamola@h...>
> [noparse][[/noparse]mailto:taunting_pamola@h...]
> problems
> Thanks,
> Jayme
Subject and
Oh, I gave an old link to my modems page. It is:
http://www.emesys.com/BS2modem.htm
In hyperterminal you can enter these settings in the connection dialog:
properties/connect to/configure/advanced-extra settings=\N0%C0
and you can lock the baud rate at 2400 for faster more reliable connection:
properties/connect-to/configure/general="2400baud"+"connect only at
this speed".
-- Tracy
I am still having difficulties with the electronic handshake with
hyperterminal. At my last attempt I configured hyperterminal as
follows:
Connect using: hsp56 micro modem (the modem I am using)
Port speed: 2400
Data protocol: disabled
Compression: disabled
Flow control: none
Then I instruct hyperterminal to wait for calls.
The part of my program that deals with communication is as follows
counter var byte
RX1 con 14
TX1 con 15
T2400 con 396
kal con 26726
lf con 10
ff con 12
rct var word
tk var word
tc var word
tpav var word 'temp averaging var
tpct var word 'temp counting var
ttotal var word 'temp sum var
dcd_ var In13
yes con 1
dial:
DEBUG "Initializing Modem",cr
PAUSE 1000 ' allow modem
to power up
SEROUT TX1, T2400,[noparse][[/noparse]"AT", CR] ' setup modem for
speed
SERIN RX1, T2400, [noparse][[/noparse]WAIT ("OK")]
PAUSE 250
SEROUT TX1, T2400, 15, [noparse][[/noparse]"ATDT,5,6301;", CR]
DEBUG "Dialing" , cr
pause 20000
goto carrier_connect
carrier_connect:
debug "waiting for carrier detect",cr
pause 10
if dcd_= YES THEN communicate
GOTO carrier_connect
communicate:
pause 30000
debug "sending data to hyperterminal"
SEROUT TX1, T2400, [noparse][[/noparse]FF]
SEROUT TX1, T2400, [noparse][[/noparse]"==================================", CR, LF]
SEROUT TX1, T2400, [noparse][[/noparse]"Remote Stamp - Temperature Station", CR, LF]
SEROUT TX1, T2400, [noparse][[/noparse]LF]
SEROUT TX1, T2400, [noparse][[/noparse]"Temp at set time....... ", DEC tc, CR, LF]
pause 1000
goto hang_up
Jayme
the modem to connect at low speeds. The settings in Windows and
HyperTerminal are totally different and only affect what is directly
connected to the PC -- not what the device is connecting to at the other
end. We ran into similar problems trying to use a 56k modem to connect to
equipment using Hayes 1200 and 2400 baud modems. The protocol negotiation
took so long the software or modem on the PC would give up.
Original Message
> Tracy, Thanks for your help and the link to your site. Unfortunately
> follows:
There are a couple of things that puzzle me about your program, but
they may not be relevant. Let's see.
>speed
> PAUSE 250
After the CH1786 receives the "AT^M", I had thought that it sends
back the "OK" response very quickly, so quickly that the Stamp would
not be ready to receive it and would become locked in the serin
waiting for "OK". I've never actually tested that. (I usually use
the stamp modem in answer mode with both echo and result reporting
turned off.) Did you ever have any trouble with it locking up at
that point?
The phone number is funny. delay, "5", delay, "6301". Is this some
sort of PBX phone number?
Assuming the phone number is good, I am puzzled by the semicolon ";"
at the end of the dial string. I think the ";" keeps the modem in
command mode, while the line stays off hook. That allows you to
enter more AT commands before data flows from the Stamp to the line.
In order to complete the connection to the line so that the Stamp can
send data, you have to end a dialing command without a ";". But I
don't see any need for it in your program in the first place.
How about this sentence:
>The modem will call hyperterminal. Hyperterminal will begin the try
>to connect but no handshake occurs so I can't send data.
Does that mean that your stamp did dial out correctly and
hyperterminal picked up the line? Maybe the Stamp is still in
command mode because of the ";".
Where is your stamp program getting stuck? Is it stuck in the DCD
loop, or does it get past that? It should not be necessary to wait
30 seconds after DCD_ to send the data.
One more thing, I have found that many modems will instantly
disconnect, if, during the negotiation phase, they receive command of
data input from the DTE or DCE side. That is, while the two modems
are negotiating a connection, don't press any keys on your
hyperterminal keyboard, and don't let your program send any
characters to the modem, until data carrier detect is active. It
doesn't look like that is a problem in your program, because you are
waiting for DCD_ in a loop. But it is something to watch out for.
-- regards,
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
http://www.emesystems.com
>follows:
>Port speed: 2400
>Flow control: none
>counter var byte
>RX1 con 14
>TX1 con 15
>T2400 con 396
>kal con 26726
>lf con 10
>ff con 12
>rct var word
>tk var word
>tc var word
>dcd_ var In13
>yes con 1
>dial:
>to power up
>speed
> PAUSE 250
>pause 20000
>carrier_connect:
>pause 10
>communicate:
>pause 30000
>pause 1000
>goto hang_up
Jayme
