Instruction execution time
Hi
Does any one know how much time does the BS 2 take
between two instructions ?
__________________________________________________
Do you Yahoo!?
Yahoo! News - Today's headlines
http://news.yahoo.com
Do you Yahoo!?
I think you mean each instruction. Depends. Some become HUGE asm
subroutines, while others down to a couple.
--- In basicstamps@yahoogroups.com, harshit suri <suri_list@y...>
wrote:
> Hi
> Thanks
> Do you Yahoo!?
anode505@y... writes:
> time 'between' 2 instructions?
Just as written above the times will be different depending on the
instructions. One way to find out the time to execute the instructions for
your particular application is to bracket the unknown time with a pulse and
read the pulse with an O-scope.
Example....
high 6
your code
your code
your code
low 6
See how long pin 6 is high....
> wrote:
> >Hi
> >Thanks
Original Message
and
> Example....
> high 6
> your code
> your code
> your code
> low 6
http://www.emesystems.com/BS2speed.htm
>From: harshit suri <suri_list@y...>
>Reply-To: basicstamps@yahoogroups.com
>To: stamp <basicstamps@yahoogroups.com>
>Subject: [noparse][[/noparse]basicstamps] Instruction execution time
>Date: Fri, 31 Jan 2003 19:09:49 -0800 (PST)
>Hi
>Thanks
>Do you Yahoo!?
>To UNSUBSCRIBE, just send mail to:
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
--- Rodent <daweasel@s...> wrote:
> http://www.emesys.com/BS2speed.htm
Original Message
> depending on the
> and
> > Example....
> > high 6
> > your code
> > your code
> > your code
> > low 6
> take
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
Rodent, I was intrigued by your reference to the web
page, so I checked it out. But I do have a
question...On there it states:
Copied text
For example, in this sequence:
loop:
high 1 ' 140 microseconds high
low 1 ' 140 microseconds low
high 1 ' 430 microseconds high
goto loop
pin P1 stays 140 microseconds high, and then 140
microseconds low, then 430 microseconds high, and then
the sequence repeats . One can infer that the low and
the high instruction each take 140 microseconds to
execute. And what about the goto? Since high itself
uses 140 microseconds, we can infer that the goto
takes 430-140 = 290 microseconds.
End copied text
If you are measuring the high/low changes on pin 1,
then I don't see how that analogy above could be
correct. Because pin 1 is already "high" at the end
of the loop, when the program branches back to loop
again, there will be no change in the state of pin 1
to gauge from the last "high" statement in the code.
Based on the first 2 instructions, I would infer that
the "goto" instruction takes 430-280 = 150
microseconds, which sounds about right...
Someone else wanna help me out here? Or is it just
the fact that I just got home from a 12 hour work day
and my brain has turned to mush?
Chris Savage
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
Do you Yahoo!?
might email info@e... and see what they say.
Original Message
> I merely provided the link -- I have no ties to the
> page whatsoever. You
> say.
I understand...I was just wondering if you agreed with
that conclusion...? I think if the second "high"
statement was taken out, then a more accurate
calculation could be obtained.
BTW, I see I'm not the only one up late tonight...
Chris Savage
Knight Designs
(607) 535-6777
Do you Yahoo!?
I've never messed with the timing -- nothing I do with my Stamps is
time-critical, I just happened to have saved the link from when this subject
came up about 6 months ago.
Original Message
> > say.
Thanks for taking the "time", late at night, to think that through.
I always appreciate corrections for my web pages. I always surprises
me when something I have had there for a long time and stared at
turns out to have a bug byte.
This one I think is correct in substance, but I messed up the
exposition. Sometimes I try to combine things that took several
steps in the experiment into one paragraph.
The total time taken for the following loop was 710 microseconds:
loop:
high 1 '
high 1 '
goto loop
That is measured from one rising edge to the next. That total loop
time breaks down as follows: time LOW in each cycle is 140
microseconds and the time HIGH is 570 microseconds.
I know from this and similar experiments that the time for "high 1"
and for "low 1" are each 140 microseconds. So 710 - (3*140) =
710-420 = 290 microseconds for the goto.
In my explanation I jumped the gun and attributed 140 microseconds to
the first "high 1", plus 140 microseconds to the "low 1", plus 430
microseconds to the second "high 1". That also adds up to the total,
710 microseconds. Your confusion came because you were thinking that
the 430 microseconds included the "high 1" at the top of the loop,
but it doesn't.
To settle it in my own mind, I tested it again. (Ask the Stamp how
it thinks, don't ask me.) This round (using a BS2e), I came up with
145 microseconds for the LOW and the HIGH periods, and 285
microseconds for the "goto". There are small differences from Stamp
to Stamp because of the tolerance of the resonator. I am depending
on the calibration of my 'scope timebase and on eyeballing the
transitions. Steve Parkis made more accurate readings using his
"time machine" and had come up with 146 microseconds for the HIGH and
the LOW commands on BS2s he tested.
I know that later on my web page I list a figure of 245 microseconds
for the "goto label" command, and that is different from the 285 or
290 microsecond figure just above. I honestly don't remember why
there is that discrepancy. It may be a mistake, or it may be due to
a different method for testing the "goto" timing. For all of the
BASIC Stamps, the latency is due to the time that it takes for the
interpreter to read from eeprom the necessary bits to execute the
command. PBASIC tokens are highly compressed. So the timing can
depend on exact numerical values, the size of a number or address.
The point is, if you really depend on the timing, you have to test it yourself!
I hope that clears up the mud a bit!?
-- best regards
Tracy Allen
electronically monitored ecosystems
mailto:tracy@e...
Copied text
>loop:
>goto loop
End copied text
>Chris Savage
>Knight Designs
>(607) 535-6777
> Hi Chris, and Rodent,
> think that through.
> always surprises
> and stared at
Hi Tracy,
I wanted to first point out that you've proably
noticed I don't say much in the group here. Running
my own business has kept me pretty busy the last few
months and I kinda "skim" through the group postings
for the interesting stuff.
When someone posts a link that looks like it might
have some useful knowledge, I almost ALWAYS check it
out...I have found so much valuable information that
way. When I looked at your code example, I was
thinking logically about the numbers, and the states
of the pin in the example, and somewhere in the back
of my mind, something said it didn't jive, and I'm
sure I over-analyzed it too...But I was hoping someone
could set me straight on it. I appreciate you redoing
the test to be sure too.
I set some projects aside a few months ago when I
was posting more in the group, and just in that time
until now I have lost my "groove" (For lack of a
better word) on some things I was doing with the
BS2...So now I am paying a bit more attention, I
think...Anyway, thanks again. Don't mind me being a
bit winded...
> messed up the
> took several
> microseconds:
> loop:
> high 1 '
> high 1 '
> goto loop
> That total loop
> is 140
> time for "high 1"
> (3*140) =
> 140 microseconds to
> "low 1", plus 430
> up to the total,
> were thinking that
> top of the loop,
> but it doesn't.
> (Ask the Stamp how
> and 285
> I am depending
> eyeballing the
> readings using his
> for the HIGH and
> 245 microseconds
> from the 285 or
> remember why
> it may be due to
> For all of the
> takes for the
> to execute the
> timing can
> number or address.
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> web
Copied text
> >loop:
> >goto loop
> then
> and
End copied
> text
> end
> 1
> code.
> that
> day
> >Chris Savage
> >Knight Designs
> >(607) 535-6777
> ignored.
Chris Savage
Knight Designs
(607) 535-6777
Do you Yahoo!?
It sure seems that 3/4 of a second is a little slow for that loop.
Original Message
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qhPBK9HmHbVSBOH43Bzm9UDkYpkBdT_ofBO16--koIa2AYvs28hdvwY8UuWszY0SQ7RE41tHq4tKOk2F]tracy@e...[/url
Sent: Sunday, February 02, 2003 5:54 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Instruction execution time
loop:
high 1 '
high 1 '
goto loop
but it doesn't.
yourself!
-- best regards
Tracy Allen
mailto:tracy@e...
Copied text
>loop:
>goto loop
End copied text
>Chris Savage
>Knight Designs
>(607) 535-6777
You know dumb sliderule ( decimal point) errors.
Original Message
Sent: Monday, February 03, 2003 8:29 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Instruction execution time
Are you sure your talking MICROseconds.
Original Message
From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Rz4sZR7qO0pW060ErYP_mQ3MFKQ1iWGXwMCGgu_L-AnJdoaELCb6DngHgxd_m4NY5awrm4A_4G378A]tracy@e...[/url
loop:
high 1 '
high 1 '
goto loop
but it doesn't.
yourself!
-- best regards
Tracy Allen
mailto:tracy@e...
Copied text
>loop:
>goto loop
End copied text
>Chris Savage
>Knight Designs
>(607) 535-6777
uS = .000,001 micro
Original Message
To: <basicstamps@yahoogroups.com>
Sent: February 03, 2003 5:29 AM
: Are you sure your talking MICROseconds.
: It sure seems that 3/4 of a second is a little slow for that loop.
Original Message
: From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s75H0brFsdimDEnXhC_PtRk2I19LDbWWLH5XnAo_Au8_m423CH5daSrp2ORkO9VUYp3VofGGSn9lgmQi]tracy@e...[/url
: Sent: Sunday, February 02, 2003 5:54 PM
: To: basicstamps@yahoogroups.com
: Subject: Re: [noparse][[/noparse]basicstamps] Re: Instruction execution time
: Hi Chris, and Rodent,
: Thanks for taking the "time", late at night, to think that through.
: I always appreciate corrections for my web pages. I always
surprises
: me when something I have had there for a long time and stared at
: turns out to have a bug byte.
: This one I think is correct in substance, but I messed up the
: exposition. Sometimes I try to combine things that took several
: steps in the experiment into one paragraph.
: The total time taken for the following loop was 710 microseconds:
: loop:
: high 1 '
: low 1 ' 140 microseconds
: high 1 '
: goto loop
: That is measured from one rising edge to the next. That total loop
: time breaks down as follows: time LOW in each cycle is 140
: microseconds and the time HIGH is 570 microseconds.
: I know from this and similar experiments that the time for "high 1"
: and for "low 1" are each 140 microseconds. So 710 - (3*140) =
: 710-420 = 290 microseconds for the goto.
: In my explanation I jumped the gun and attributed 140 microseconds
to
: the first "high 1", plus 140 microseconds to the "low 1", plus 430
: microseconds to the second "high 1". That also adds up to the total,
: 710 microseconds. Your confusion came because you were thinking
that
: the 430 microseconds included the "high 1" at the top of the loop,
: but it doesn't.
: To settle it in my own mind, I tested it again. (Ask the Stamp how
: it thinks, don't ask me.) This round (using a BS2e), I came up with
: 145 microseconds for the LOW and the HIGH periods, and 285
: microseconds for the "goto". There are small differences from Stamp
: to Stamp because of the tolerance of the resonator. I am depending
: on the calibration of my 'scope timebase and on eyeballing the
: transitions. Steve Parkis made more accurate readings using his
: "time machine" and had come up with 146 microseconds for the HIGH
and
: the LOW commands on BS2s he tested.
: I know that later on my web page I list a figure of 245 microseconds
: for the "goto label" command, and that is different from the 285 or
: 290 microsecond figure just above. I honestly don't remember why
: there is that discrepancy. It may be a mistake, or it may be due to
: a different method for testing the "goto" timing. For all of the
: BASIC Stamps, the latency is due to the time that it takes for the
: interpreter to read from eeprom the necessary bits to execute the
: command. PBASIC tokens are highly compressed. So the timing can
: depend on exact numerical values, the size of a number or address.
: The point is, if you really depend on the timing, you have to test
it
: yourself!
: I hope that clears up the mud a bit!?
: -- best regards
: Tracy Allen
: electronically monitored ecosystems
: http://www.emesystems.com
: mailto:tracy@e...
: >--- Rodent <daweasel@s...> wrote:
: > > http://www.emesys.com/BS2speed.htm
: >> > > time 'between' 2 instructions?
: >Rodent, I was intrigued by your reference to the web
: >page, so I checked it out. But I do have a
: >question...On there it states:
Copied text
: >For example, in this sequence:
: >loop:
: >high 1 ' 140 microseconds high
: >low 1 ' 140 microseconds low
: >high 1 ' 430 microseconds high
: >goto loop
: >pin P1 stays 140 microseconds high, and then 140
: >microseconds low, then 430 microseconds high, and then
: >the sequence repeats . One can infer that the low and
: >the high instruction each take 140 microseconds to
: >execute. And what about the goto? Since high itself
: >uses 140 microseconds, we can infer that the goto
: >takes 430-140 = 290 microseconds.
End copied text
: >If you are measuring the high/low changes on pin 1,
: >then I don't see how that analogy above could be
: >correct. Because pin 1 is already "high" at the end
: >of the loop, when the program branches back to loop
: >again, there will be no change in the state of pin 1
: >to gauge from the last "high" statement in the code.
: >Based on the first 2 instructions, I would infer that
: >the "goto" instruction takes 430-280 = 150
: >microseconds, which sounds about right...
: >Someone else wanna help me out here? Or is it just
: >the fact that I just got home from a 12 hour work day
: >and my brain has turned to mush?
: >Chris Savage
: >Knight Designs
: >324 West Main Street
: >Montour Falls, NY 14865
: >(607) 535-6777
: >http://www.knightdesigns.com
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the
Subject and
: Body of the message will be ignored.
: Your use of Yahoo! Groups is subject to
: [noparse][[/noparse]Non-text portions of this message have been removed]
Subject and Body of the message will be ignored.
