Controlling 12V DC Fans
I've been working on a project now to create a fan controller for my computer
using the BS2. While I have figure out how to read the tach with the stamp,
speed control has alluded me. I tried PWM, using one of Al William's Pak
coprocessors and was able to control the fan's speed but failed to get tach
feedback, which in it's place I would get a count of the current pulse rate. I
also heard that PWM causes interference... is this true? I've considered trying
linear control but have failed to get that to work and from what I understand
linear produces excess heat. Any suggestions on how I might best control the
fan's speed and if possible be able to read the tach output as well?
BTW the fans I'm interested in controlling are mainly those standard 80mm X 80mm
case fans, which typically run at 12VDC and usually consume less then 3 watts of
power.
Also I noticed that on the PWM Pak that there is two PWM modes. From the scope
screen shots on Al's web site I see the difference between the two, but I don't
understand in which situation each would be most appropriate, could someone
elaborate this for me?
Any help is much appreciated!
Chris
power.
Chris
to read the tach with the stamp, speed control has eluded me.
> standard 80mm X 80mm case fans, 12VDC ...usually consume less than
3 watts of power.
Of course if you just want a slower fan, put a 50 ohm 1 watt
resistor in series with it. Or even wire it to 5V instead of 12V,
but be aware that as the bearing grease gunks-up it will stall much
sooner on 5V than on 12V.
Do you really want to control fan speed, or case temperature?
Generally you want to stay cool. Who cares how fast a fan spins? It
is not likely to over-speed and burst like a dive-bomber propeller.
If it is noisy, try a simple resistor, a diferent fan, put wool or
foam sound absorption around the PC (leave air-flow), or long cables
to a PC in another room. While you can slow a fan, you generally
can't slow a hard drive, which is what you hear after you quiet the
fans,
If you do want to control fan RPM:
Bang-bang it. If the fan is slow, turn it on; if the fan is fast
turn it off. The self-inertia of a quality PC fan will keep it
spinning pretty constant. You only need the Stamp, 2 parts, and 12V
power.
Get a 500milliAmp NPN transistor and a 470 ohm resistor. Ground the
transistor Emitter. Connect the transistor Base through the 470 ohm
resistor to Stamp pin 7. Connect the (-) fan power wire to
transistor Collector. Connect the (+) fan power wire to +12V power
supply.
I don't know what the tach output looks like but I'll assume one
pulse per turn with enough amplitude to trip the Stamp's inputs. And
I'll assume 1,000 RPM speed goal.
Connect the tach output to Stamp pin 0.
Pseudo-Code--
(Must be checked for logic errors and translated to PBasic syntax)
IF PulseIn 0 > 60 milliSeconds ' if less than 1,000 RPM or 16
revs/second
THEN
Make Pin 7 High ' turn transistor and fan ON
ELSE
Make Pin 7 Low ' turn transistor and fan OFF
END IF
Repeat forever
> I've considered trying linear control but have failed to get that
to work
Not knowing what you tried (a zillion ways to "linear control"),
can't say what's wrong.
It wastes the excess power. In many cases this is no big deal. At
worst in this case, you might be wasting 3 watts, which is not going
to over-heat the house and is small inside a 100-watt PC. However it
is large compared to the 0.5W-1W rating of power transistors without
heatsinks, so it would be nice to either prove the motor can be
controlled with less than 1W of waste or avoid linear.
Also, you will have big trouble getting the usual brushless PC fan
to run at very-low voltage and RPM, because it needs a certain
minimum voltage to start at all. For super-slow speed you will end
up running bang-bang mode anyway: up to 5V to get started, rev-up to
too-fast, drop to 0V to kill speed, repeat. The brushless PC fan is
not linear at very slow speed, so why try to handle it as a linear
controller?
> I also heard that PWM causes interference... is this true?
With a 12V fan, you have 12V spikes repeating at the PWM rate. Using
the Stamp-style PWM, this is a few KHz with harmonics well up into
the AM radio range. Using my bang-bang technique, it might be a
pulse every second though that will still make ticks in the AM
radio. For perspective, the whole PC is full of 3V and 5V spikes
from KHz to GHz which tend to wipe-out radio from AM all the way
past the TV and cellphone bands. So you have a forest full of
croaking bullfrogs; if you add one more frog will anybody notice? If
we must have digital machines, we have to have metal cases to try to
contain the Smile they radiate. Mostly that works.
-PRR
the stamp, do you use a separate 12V supply, and run the stamp with
a 9V battery, and just connect the grounds together so the
transistor can control it? Or do you just run the stamp on 12 volts?
Bill
--- In basicstamps@yahoogroups.com, "paul54reid <preid@r...>"
<preid@r...> wrote:
> > create a fan controller for my computer... I have figure out how
than
> 3 watts of power.
much
It
propeller.
cables
the
> fans,
12V
> power.
the
ohm
> supply.
And
> Pseudo-Code--
> revs/second
> THEN
> ELSE
> END IF
> Repeat forever
that
> to work
going
it
without
to
is
> controller?
Using
If
to
> -PRR
billak@f... writes:
> Just thought I'd butt in here...when controlling 12V DC stuff with
> Bill
Both will work, but running the stamp on 12 volts will result in more power
dissipated by the stamps 5 volt regulator. If your Stamp will not be sinking
or sourcing much current, then 12v is ok to run the stamp.
Power stamp regulator = 12v - 5 volts / Total current used by stamp
but I do tie the grounds together in order to use a transistor.
Chris
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, January 25, 2003 3:35 AM
Subject: [noparse][[/noparse]basicstamps] Re: Controlling 12V DC Fans
> Bill
> than
> > 3 watts of power.
> much
> It
> propeller.
> cables
> the
> > fans,
> 12V
> > power.
> the
> ohm
> > supply.
> And
> > Pseudo-Code--
> > revs/second
> > THEN
> > ELSE
> > END IF
> > Repeat forever
> that
> > to work
> going
> it
> without
> to
> is
> > controller?
> Using
> If
> to
> > -PRR
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
it runs 24/7 with in 5 feet of my bed.
So based on what you said would it be a better idea just to simple turn the
fan off when the system is cool and on when it's hot? Cause according to
what you said it's not always the best idea to run them at a slower speed?
As for tach output, it's two pulses per turn actually, and they're 12v
pulses. Hmm your suggestion would work but I want the stamp to be available
to do other things, such as check temp sensors and output the current stats
to a serial LCD.
Hmm... you gave me a lot to think on, I have gotten it to work as a basic
temp based on and off controller... system is too hot? turn the fan on...
system cool? turn the fan off.
Chris
Original Message
Sent: Saturday, January 25, 2003 1:53 AM
> 3 watts of power.
> fans,
> power.
> supply.
> Pseudo-Code--
> revs/second
> THEN
> ELSE
> END IF
> Repeat forever
> to work
> controller?
> -PRR
Recently I have been working on a project which requires thermal
managment of enclosed environment utilizing a 12vdc fan. In my
travels I came across two very inexpensive chips either which are
targetted to perform exactly what you are looking to do.
They are a TC646 or MIC502. Both are very inexpensive, rather easy to
deploy and will pwm the fan and such.
Hope this helps.
Dennis
--- In basicstamps@yahoogroups.com, "Chris Shuster" <cpuman3@h...>
my computer using the BS2. While I have figure out how to read the
tach with the stamp, speed control has alluded me. I tried PWM,
using one of Al William's Pak coprocessors and was able to control
the fan's speed but failed to get tach feedback, which in it's place
I would get a count of the current pulse rate. I also heard that PWM
causes interference... is this true? I've considered trying linear
understand linear produces excess heat. Any suggestions on how I
might best control the fan's speed and if possible be able to read
standard 80mm X 80mm case fans, which typically run at 12VDC and
usually consume less then 3 watts of power.
From the scope screen shots on Al's web site I see the difference
between the two, but I don't understand in which situation each would
be most appropriate, could someone elaborate this for me?
> Thanks,
> Chris
hot?
No; I said "If the fan is slow, turn it on; if the fan is fast turn
it off."
You could do as you say: on for hot, off for cool. But that would be
annoying "with in 5 feet of my bed".
What I said was: if it hits 1001 RPM, turn it off, if it hits 999
RPM turn it on. (You will have to experiment to find an RPM that
cools well.) The result is that it hovers around 1000 RPM. And
unlike trying to run on reduced voltage, this way the fan always
gets full 12V or zero, no wimpy 3 or 5 volts which may or may not
work smoothly.
If you tried this with a REAL fan, couple-horsepower, it would be
nasty. HRNNNN-coast-HRRNNN-coast. (Why the technique is called "bang-
bang".) But with the low-power motors and large blades on PC fans,
there is no big start-up bang and plenty of inertia. It may work as
I said: just pick an RPM (or a time-between-tach-pulses, which the
Stamp can do easily) and on/off the motor is it is under/over that
RPM. If that does sound "twitchy" because it is constantly cycling,
you might want to add some hysteresis. Simplest is to add a PAUSE
250 in the loop, so it can't on/off faster than 4 per second.
The "pretty way" is to have two set-points: ON at 950 RPM, Off at
1050 RPM, and let mechanical inertia be the delay.
> I want the stamp to be available to do other things, such as check
temp sensors and output the current stats to a serial LCD.
But most "run forever" programs (at least in PBasic) are going to
have that same "Loop forever" structure. You can check the fan,
check the temperature, send output to LCD, check for buttons,
whatever, and loop.
As long as you are checking temp anyway, your fan set-RPM should be
a variable that has a minimum, but high temperature will raise that
set-RPM if things get hot.
TachRate = 60000
IF Temp < 100 THEN Skip
TachRate = 30000 ' speed-up if hot
Skip:
As others are pointing out: I didn't really think about the power
connection and my plan for the switch transistor will not work for a
fan with common ground for Tach and Motor. You will need another
transistor or some kind of 250mA switch chip.
